Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 08-29-2007, 11:08 PM   #1
trailwart
trailwart's Avatar
99 vortec 5.7 issue???
well ive had an issue with the wifes truck a few times now. it will run rough intermitantly. was on the highway hauling my 20ft enclosed car hauler and she was under load going up hill and started missing, kicked the ses light on. well i checked the ses and it had a random misfire. well thismorning we got up bright and early to take the kids to an amusment park on the other side of the state and it ran fine with a miss here and there. truck sat it the parking lot for 11 hours and we went to leave and the thing wouldnt start. i had to give it a ton of pedal to run and it ran like crap, if i let up it would stall. did this for about 5 minutes and started to run fine. truck has 155k on it with a new fuel pump and filter in the last 5k, plugs-wires- 20k ago. not sure what could be causing this. do ya think its the egr? anything i could clean some sensors with to try to fix? what sensors? im clueless
72 chevy 3\4 ton 4 speed 4x4
84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories)
1999 suburban 4x4
1982 chevrolet S-10 V-8 (Thanks uncle EARL)
trailwart is offline   Reply With Quote
Old 08-30-2007, 06:22 AM   #2
speedygonzales
speedygonzales's Avatar
Re: 99 vortec 5.7 issue???
Since you have misfires and sluggish performance. It's time to check the plugs and the fuel pressure both running and when shut off. See that the pressure comes up to the proper level and that it stays there long enough after being shut down.
If you find the plugs are all fouled on one entire side of the engine, you know the problem is fuel related. If you find less than 4 fouled, it's ignition related.
The fuel pressure regulator is located under the plastic plenum. If the diaphragm is ruptured, it will leak fuel into the intake causing rich running and misfires.
Pressurize the fuel system after removing the plenum. You will have to disconnect and reconnect the fuel lines. They bolt on the top and at the rear of the intake. Be sure to check all the connections for leaking under pressure.
While there, also plan on replacing the gaskets between the intake and the heads. I believe these gaskets are different than the crappy plastic ones on there now. http://store.summitracing.com/partde...5&autoview=sku
You'll see those old intake gaskets are not worth a flip.
There are a few other things you will want to check and at least 1 you will now NEED to check.
The rotor and cap need to be changed once per year. Despite what you may have read or heard. Check them for signs of white corrosion.
If the wires have over 50K on them. Change them also. Brand name only.
If the O2s are older than 60K, change them. Don't use Bosch. OEM only.
If you have been running rich, need to check the cats if you still have them. Running rich screws them up big time.
speedygonzales is offline   Reply With Quote
Old 08-31-2007, 12:20 AM   #3
HtownPapiJc
my CheVy TrUcks
HtownPapiJc's Avatar
Seems like this has been a common problem...thru out some of these threads. I would check the cap 1st. Mines did exactly what yours is doing but w/o hauling anything. Had new plugs and wires but still had the orginal dist. cap lol Changed and running great. Good luck
J.Garcia
1998 Chevy Silverado V-8 305/5.0 liter
2005 Pontiac Grandam V-6/3.4 liter
1989 Chevy 1500 Suburban (Aug/2007 Project)
HtownPapiJc is offline   Reply With Quote
Old 09-01-2007, 01:35 AM   #4
Daniel U
Daniel U's Avatar
My wife's 99 Tahoe has a similar problem. She cranks over, runs for a second and dies. It seems to only happen 2 times a year. It never runs bad. I'll replace the plugs and wires. When I do the fuel cap, should I go OEM? The dealership says , but I don't want it to fail CA. SMOG either. Sorry to thread jack Daniel
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2006 (Vortec 5.3/4L60E/10 bolt 3.73)4X4 Silverado LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 09-03-2007, 03:56 PM   #5
memphismatt
memphismatt's Avatar
check the cam position sensor. my 99 yukon had the same problem 6 months ago. misfire code and everything. the cam position sensor is under the dist.cap it was +/- $25. better have some torx bits before you can pull it
memphismatt is offline   Reply With Quote
Old 09-03-2007, 04:04 PM   #6
72freak
Rottenwood Garage Member
72freak's Avatar
You gotta love those Vortecs......Ive never been so dissapointed in an engine in my whole driving career. I even bought more than 1 to better the ods. I lost and then gave up!!!
Throttle body and before for me!!!!
2001 Chevrolet 2500HD Crew 6.0
1999 Chevrolet Tahoe 4x4
1999 Harley Davidson Electra Glide
1996 Chevrolet C3500 Ex-cab 5.7
1980 Toyota Corolla "Rock-n-Rolla"
1972 Chevrolet Ex-cab K-30 Dually Cummmins 5sp
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A, "Hot Rod"
1931 Ford Model A Tudor "Silverback"
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is online now   Reply With Quote
Old 09-12-2007, 11:22 AM   #7
azfab
azfab's Avatar
fuel injectors. if you havent got a tsb from the dealer. the injectors should be under warenty. gm now makes an updated model for the 5.7. the same thing happend to my 97 k1500. it would miss like crazy at high speeds or load. ping like hell too. but if you let this go too long the cats will suffer cost me 1500 just for the repacement cats. that sucked! good luck..
azfab is offline   Reply With Quote
Old 09-13-2007, 02:33 AM   #8
Daniel U
Daniel U's Avatar
I've otherwise had no issues with this Vortec? It's on it's second time around with 170,---+ on the ticker. Passed CA. smog just fine last month.
Old 04-17-2008, 03:50 AM   #9
trailwart
trailwart's Avatar
well just to give an update on my old thread here. i had a bad head gasket. pulled th motor and installed a new gm goodwrench motor. gonna do somthing sick with the 1 i pulled, not sure yet maybe a 383?.
1999 suburban 4x4
Old 04-18-2008, 02:27 PM   #10
ed2552
One Ton X2 Club!!
ed2552's Avatar
I would've put some money in it and got the HT383E, that's what i'm gonna do when my tahoe goes
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-18-2008, 11:57 PM   #11
trailwart
trailwart's Avatar
the sub is my wifes daily driver, so that wouldnt of flew with her. got the gm godwrench for around 2k and it has 100k mile warranty. i havnt worked in almost a year and have 4 kids so my piggy bank isnt that big anymore. the engine i pulled will get a 383 kit for a later project thou..
1999 suburban 4x4
Old 04-19-2008, 12:24 AM   #12
B52fizzle
B52fizzle's Avatar
my 99 5.3 did this, wouldn't start, and sounded like it was missing or dieing out, wasn't constant though just here and there it was the fuel regulater, dealership part cost me 65 bucks, mechanic put it in for 10 because he had the same problem and knew what he was doin and his boss made him charge me somethin took him 10 minutes to pull in shop and change. apparently common on these years and approximate mileage.
B52fizzle is offline   Reply With Quote
Old 04-19-2008, 02:52 AM   #13
ed2552
One Ton X2 Club!!
ed2552's Avatar
Yeah, a lack of cash is getting to be a bigger problem now days
Old 04-27-2008, 03:44 PM   #14
toplesskayfiver
K5-2WD=C5
toplesskayfiver's Avatar
sounds like the same thing my 99 5.7 vortec is doing. plugs, wires, cap, and rotor are about 1 year in with few miles, i replaced the fuel pump and filter just a week ago. now ses light comes on and off?? it also has a k&n fuel injection performance kit air filter intake and a borla muffler catback 3" exhaust with 125,000 miles
toplesskayfiver is offline   Reply With Quote
Old 04-27-2008, 07:38 PM   #15
trailwart
trailwart's Avatar
well when i first installed the new engine i still had the problem. since i had replaced the cap, rotor, plugs and wires when istalling the new engine i ruled that out. i also had a new fuel pump so that wasnt the isse. had a code of low voltage on tps, changed it and it didnt fix it. my buddy that work at the proving grounds told me to run 4 bottlrs of injecter cleaner in the tank, so i did it and with in 50-60 miles the studdering was gone, hasnt come back either. he figured it is the poppits dirty/clogged and said if the cleaner worked, that i should then take my upper plenum off and clean all of them by hand or get the upgraded spider. well i havnt done that as i havnt seen the problem come back, but if it does i will put the upgraded spider in.
1999 suburban 4x4
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
