Old 09-20-2007, 09:27 PM   #1
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
72 suburban "3drdwn"
I wanted a project page for this and since there isn't one for burbs I'm hoping I can hang in here with you truck guys. I already posted a little about the burb here: http://67-72chevytrucks.com/vboard/s...d.php?t=255958
I'll post pics as fast as I can.
Josh
RunninLo is offline   Reply With Quote
Old 09-20-2007, 09:33 PM   #2
RunninLo
RunninLo's Avatar
Re: 72 suburban "3drdwn"
These pics were sent to me by the PO about 3 weeks before I picked it up.
even though the body is rough in the pics the price was right so I agreed to drive up and pic it up.
Old 09-20-2007, 09:40 PM   #3
RunninLo
RunninLo's Avatar
these pictures are what I ended up with after the trip home:
Old 09-20-2007, 09:44 PM   #4
RunninLo
RunninLo's Avatar
more:
Old 09-20-2007, 09:53 PM   #5
RunninLo
RunninLo's Avatar
last four:
As you can see the body is rough but I have seen worse. Once PO wrote it off as a work truck it served duty as a firewood hauler then once the carb let out it was a rolling storage shed. Sold stock 307 to a someone wanting a period correct motor. I have a TBI350/700R4 from a 94 2wd burb going in.
concentrating mostly on frame/susp./drivetrain first then tackle the body.
more to come.
Josh
Old 09-20-2007, 10:07 PM   #6
RunninLo
RunninLo's Avatar
most recent work included installation of the world famous Dropmember. I started with a stripped front clip and previously removed and sold motor leaving easy access to the stock front susp.
After removing a few brake lines and some bolts I was left with bare rails. I'm basically doing a test fit this time around and plan on stripping and powdercoating the frame later so POR-15 will help keep things looking good for now.
the next step was to lay out the cuts for the steering notches as per the instructions sent with the dropmember.
Old 09-20-2007, 10:23 PM   #7
RunninLo
RunninLo's Avatar
out of excitement these next pics skipped some of the steps. After cutting out frame and welding in notches for steering I decided to smooth the notches to the outside edge of the frame. they're fully welded inside and out and I decided to leave the welds on the inside. figured it would look better with the frame smoothed. the drop member is actually easier to install than the factory cross member. just followed the instructions. here is a pic with the DM, frame gussets, and upper bag brackets installed.
close ups of the notches:
Old 09-20-2007, 10:26 PM   #8
RunninLo
RunninLo's Avatar
then the first oops. once I started installing the LCA's I noticed a lil irregularity. this is the pasenger side:
all is looking good until:
things don't line up right at all on the driver side.
Old 09-20-2007, 10:43 PM   #9
RunninLo
RunninLo's Avatar
turns out that due to a small error I had recieved two passenger side control arms from ART.
After a quick phone call to ART and about 2 weeks turn around I had my arms replaced. On a positive note I was upgraded to the new style ART lower with the updated shock mount. Thanks guys!
After that minor delay I was back on track. YAY!
Slid the mustang II rack into place while I was waiting for the arms. It's basically two alumin. bushings and a pair of bolts to secure the rack to the dropmember. It's self locating.
Old 09-20-2007, 10:49 PM   #10
RunninLo
RunninLo's Avatar
didn't take any after shots but here's the 2.5" MacGaughey's spindles getting prepped for a coat of high temp black.
got excited and forgot to man the camera during the next few minutes but I was so excited to be completing the install. I got all the pieces together and a set of wheels bolted up.
Old 09-20-2007, 10:59 PM   #11
RunninLo
RunninLo's Avatar
grabbed some spare line and fittings I had and plumbed it up. couldn't wait to play.
one of the things you'll notice in that pic is the wheel is slightly toed out. After talking with Nathan at Porterbuilt it was determined that approx. 1" needed to be cut off the ends of the steering rack. I moved the jam nut a lil farther up the rod and taped the threads marking off the inch. using a cut-off wheel made quick work of the job and then I backed the jam nut off to clean and restore the threads.
first air put in.
Old 09-20-2007, 11:09 PM   #12
RunninLo
RunninLo's Avatar
the back end has the stock frame sitting on the axle tubes but this is the front aired out.
went ahead and test fit the front sheet metal. Needed to trim the inner fenders for tire clearence. here's a pic of it air'd up:
and down:
a couple more with the rest of the clip on.
well that's pretty much where I sit. I'm working on the rear suspension and will add more to this thread as things progress. I still need to button up a few things up front too. I'll try my best to keep the pics coming.
Josh
Old 09-20-2007, 11:13 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Nice progress pics! It looks like your off to a great start. When the excitement settles down, give us a laundry list of your plans.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is online now   Reply With Quote
Old 09-20-2007, 11:19 PM   #14
Frizzle Fry
It's only metal
Frizzle Fry's Avatar
You just started and you're already way ahead of the game! Can't wait to see more
Frizzle Fry is offline   Reply With Quote
Old 09-20-2007, 11:35 PM   #15
RunninLo
RunninLo's Avatar
Thanks frizz. this board has been a great source of both knowlege and motivation. As soon as KP is ready I've made plans with Clint to test one of their 6 links for the rear. They are 100% percent on truck applications but haven't tried a burb yet. BTW thanks again for the heads up on the body mount and dip in frame. Once that is complete I'll bolt in the motor and trans with the stuff that came with my DM and then take the burb for a new 1 piece driveshaft with slip yoke to account for varying lengths as the rear suspension swings through its arc. From there it's
1:get the motor wired and firing
2: exhaust
3: windows
4:lighting
5: drive it around in primer a bit to knock out the bugs
6: Body ( shave hinges on barn doors ) suicide hood ( found cool tech here for parts I already have)
7: paint HOK true blue and orion silver two tone. silver top blue middle silver rockers.
also have room for 22's and my wife's 66 conti looks killer with those 20's on it so I may switch wheels.
Josh
PS anybody see any cool rigs in the backgrounds?
Old 09-20-2007, 11:38 PM   #16
PBFAB.COM
PBFAB.COM's Avatar
Looking great Josh!
There's just something about a Burb laying on the ground!
Have the guys at KP got the rear figured out for you?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-20-2007, 11:40 PM   #17
Frizzle Fry
It's only metal
56 effy
Old 09-20-2007, 11:45 PM   #18
RunninLo
RunninLo's Avatar
Originally Posted by porterbuilt View Post
Looking great Josh!
Clint gave me a few dates that they hope to have certain parts ready by and I've got funds set aside. now I just play the waiting game. probably get notch soon since that is ready to go now and that way I'll have something to tide me over till the rest passes KP quality assurance and hits the streets.
Old 09-20-2007, 11:52 PM   #19
RunninLo
RunninLo's Avatar
Originally Posted by Frizzle Fry View Post
56 effy
yup big window custom cab been in my family since I was 4.....
that's one, the other is sneaky....
Old 09-26-2007, 08:36 PM   #20
RunninLo
RunninLo's Avatar
TTT
Old 11-06-2007, 09:58 PM   #21
1sik7t2
dave
1sik7t2's Avatar
Nice Work Keep it "down" Love Em Down Wish I Could Do All That My Self Mite Check Out A Drive Shaft With A "double Cardan" Helps With Vibrations And Angles Lots Of Race Cars Use Them It's Like A Double Jointed U-joint Works Great L8tr
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
Old 11-06-2007, 10:18 PM   #22
67_C-30
I have a radical idea!
67_C-30's Avatar
Awesome! Nice project!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-06-2007, 10:42 PM   #23
Cyclone44
Step Brother
Cyclone44's Avatar
That's nice, You made that look so easy....George
Cyclone44 is offline   Reply With Quote
Old 11-07-2007, 12:20 AM   #24
68burb
josh- those are 20"? any fitting issues with your heater box?
so you only have drop spindles with drop member and bags?
I'm converting my 68 and I'm trying to see how low i can go without spindles.
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's
1995 K2500 Burb as daily driver 350 with 193K miles
1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse
68burb is offline   Reply With Quote
Old 11-07-2007, 11:51 AM   #25
RunninLo
RunninLo's Avatar
they are 20's. I'll admit there isn't much sidewall there as they are a 245/35/20. These didn't get into the heater but I yanked it anyway since I'm thinking about 22's. The spindles are McGauheys 2.5" units . The rear still being up a few inches is putting more tilt to the front so it is sitting a little lower than it will once the whole thing sits level then I can see how much more room for larger rollers there will be. Hope to see the rear suspension peices before christmas but my vendor hasn't even started production yet. The order has been placed though so as soon as they're ready so am I. DropMember is a nice piece with the only draw back so far being the stock hood hinges will no longer work. I found a FAQ on the board for a forward flip hood using a stock buick hinge. Since I have a few of them around that's what my plans are.
Josh
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
