Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-02-2007, 07:38 PM   #1
worthaz
fuel cell in truck bed/ flush mount gas cap
Hay everyone,
I'm not sure if this is the correct spot to post this question, if not maybe someone can redirect me. I was wondering if anyone had an idea of where to purchase either an aluminum or stainless steel fuel tank to mount in truck bed. I've also considered keeping my stock tank in the cab of my 67 and just installing a flush mount fuel cap. Anyone got any cool ideas out there?
worthaz
67 under construction
worthaz is offline   Reply With Quote
Old 11-02-2007, 08:16 PM   #2
copperchevy
copperchevy's Avatar
Re: fuel cell in truck bed/ flush mount gas cap
www.performanceonline.com sells an aluminum tank that mounts inbetween the rear frame rails. A little pricey but looks like a great product.
Mexican
copperchevy is offline   Reply With Quote
Old 11-03-2007, 04:37 PM   #3
worthaz
Thanks for that information. I'm not sure I want to go to the trouble of installing between the frame rails. Has anyone installed one in the bed of the truck and made it look good?
worthaz
Old 11-04-2007, 03:46 AM   #4
Kevin45
Kevin45's Avatar
Best idea is to get the tank out of the cab. I would go with a tank betwen the rails also.
Kevin
'93 Silverado Reg. Cab Shortbox
.060 over 350 Quick and fun!!!
Kevin45 is offline   Reply With Quote
Old 11-04-2007, 09:22 AM   #5
mwinchel
You can get a black polyurethan one out of jaz. The tank comes with a sump and sender unit. Jaz makes some pretty good stuff it is there 16gallon No foam tank they use in dragsters. I am doing a ground up project and this is the one i am going to but it looks to fit right between the frame rails. if you want something like this give me a call 1-888-481-7264. i work at cv products they have a web site cvproducts.com not a very good one yet but they are working on it. i can probably sell it to you for 170 bucks plus shipping.
mwinchel is offline   Reply With Quote
Old 11-04-2007, 10:15 PM   #6
randyjohn
randyjohn's Avatar
you can get or make a beer keg gas tank and mount it in the front of the bed.
i love em myself. old skool
It's peanut butter jelly time.
'74 GMC 3/4 TON 2WD LB
randyjohn is offline   Reply With Quote
Old 11-08-2007, 05:32 AM   #7
impala_631
:( BYEBYE :(
impala_631's Avatar
Originally Posted by randyjohn View Post
you get get or make a beer keg gas tank and mount it in the front of the bed.
thats cool, i had a keg i was going to convert into a tank but ended up just doing a jegs fuel cell
impala_631 is offline   Reply With Quote
Old 01-09-2009, 09:58 AM   #8
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: fuel cell in truck bed/ flush mount gas cap
Here is my fuel cell!
http://mphotos.live.com/9169aad55cfc...1163&mkt=en-US
http://67-72chevytrucks.com/vboard/s....php?p=3047940
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-12-2009, 01:08 PM   #9
superman0414
I have a 67 long wheel base and a 71 short and I order a 20gallon fuel cell from summit racing for 250 for the 67'. It has the gm sending unit for your gauge and foam so you don't have the sloshing problem. Plus it fits nicely between the frame rails. However, on the 71' I decided to make my own from sheet metal to give a better fit and save cash ( that's only if you are a decent welder). I plan on using a stainless steel flush mount boat gas cap in the bed floor for a clean look. I'll see about getting some pictures, but between frame rails is by far the way to go, it only takes a hour or two extra but it pays in the end
superman0414 is offline   Reply With Quote
Old 01-13-2009, 11:41 PM   #10
close-shave70
howdy to a local tucsonian, im a welder by trade and built many custom fuel cells even a 32 gal tank mounted in the bed of my powerstroke even with me doing all the fabrication install and cool tricks i couldn't beat the conviance of an under-bed mounted tank, so i just went with a 72 blazer gas tank mounts to pre-existing holes already in your frame i bought mine not more than 3 weeks ago brand new with sending unit and mounting straps from cpp for 189$=20 gal tank i can snap some photos if you like- Let me know
close-shave70 is offline   Reply With Quote
Old 01-14-2009, 01:33 AM   #11
andrewmp6
Also try http://www.earlyclassic.com/catalog.aspx
andrewmp6 is offline   Reply With Quote
Old 01-14-2009, 05:24 PM   #12
70onB.A.D.'s
70onB.A.D.'s's Avatar
brothertrucks as well as kenny's trucks sell a suburban replacement gas tank kit that goes right up in the frame rails for these trucks. Hope this helps
70onB.A.D.'s is offline   Reply With Quote
Old 01-14-2009, 10:07 PM   #13
my67chevytruck
Under Construction
my67chevytruck's Avatar
bought ours from www.nolimit.net
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-18-2013, 12:38 AM   #14
HiredGun
HiredGun's Avatar
I have the tank under my bed. Mine is from a 72 blazer. Only thing I'm lacking is a proper filler neck. Working on finding a flush mount filler cap. Other than finding a good cap, I'd say do the swap. It's easy and worth it.
HiredGun is offline   Reply With Quote
Old 01-18-2013, 06:19 AM   #15
Dr.Hutch
I'm new to trucks so I'm try to learn as much as possible. But what is the benefit to place the fuel tank in between you frame railing? Is it for weight distribution?
Dr.Hutch is offline   Reply With Quote
Old 01-19-2013, 01:55 AM   #16
HiredGun
HiredGun's Avatar
that and fumes. and some argue for safety as well
Old 05-23-2013, 10:01 AM   #17
Dobster
I am facing the same gas tank replacement issue I am thinking about going with the 72 blazer tank but I have an ls1 motor... I think I would need to replace the in tank fuel pump???
I am wondering about how it would look?
Dobster is offline   Reply With Quote
Old 06-20-2013, 03:23 AM   #18
HiredGun
HiredGun's Avatar
get a normal fuel cell (aluminum) and put the pump in it. not sure if it will fit in the blazer/suburban tank
Old 09-26-2017, 01:33 PM   #19
62 Fleetside Longbed
I am relocating the gas tank to underbed on my 62 fleedside longbed. Does anyone know what year of Suburban might fit.
62 Fleetside Longbed is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
