Old 11-29-2007, 12:53 AM   #1
Rokcrln
Rokcrln's Avatar
What fleet side tailgate latches are out their?
Looking for somthing other that chains. Also I would like a center handle for latches if they make such a thing. Any info would be great and pics are alway welcome!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-29-2007, 02:12 AM   #2
BIG CTY
Between the earth and the sky
BIG CTY's Avatar
Re: What fleet side tailgate latches are out their?
I have these pins in my tailgate, but I want chains as I have nothing to hold the gate up with when it's open.
Chris - 1966 C10 Shortbed Fleetside, 1991 GMC Sierra 1500 Extended Cab, 1993 Blazer Sport 4x4
My other rides:
1969 Chevrolet Impala SS427 Convertible
1976 Dodge Tradesman B200
2002 Nissan Maxima 6 speed
2004 Mercedes Benz CL500
BIG CTY is offline   Reply With Quote
Old 11-29-2007, 06:52 AM   #3
Rokcrln
Rokcrln's Avatar
Yeh that would be a pain! Nice looking truck. What I am after is a clean looking out side with out any visable latches like the 67 and up. I wonder if I can gut out a 67+ fleet side and make it work in one of these. If not than maybe small bear claws with a center inside latch.
Kevin
LFD Inc.
Old 11-29-2007, 08:03 AM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
What I have seen alot of is the use of GM seat belts....on the inside of the gate.
The catch/button part was mated to the bed, and the male part was welded to the gate. Lift the gate up, and it clicked right in. Works pretty good.
Then the scissor type hold back was used.
That reminds me, I went to a CarShow a while back in Nevada City, and this old guy had a SUPER clean blown 64...and he was so proud of his power tailgate that he had made, (using actuaters)...it was cool, but that stupid thing took a hour to open !!!
SlepySal used slide latchs on his truck that worked pretty well too.
John
What the Heck is that ??
60-66 on FACEBOOK
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
My DOOM Buggy Build
Project 'Z069' LS7 Powered '69 Stingray(Father-n-laws)
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-29-2007, 08:10 AM   #5
68MoneyPit
I don't know about the latches adn the handle but I have seen people use cables to hold the tailgate when it is open like what is on newer model pickups
68MoneyPit is offline   Reply With Quote
Old 11-29-2007, 07:53 PM   #6
nimrocker
I bought a pair of manual dead bolts for a for a regular house door. They are called barrel bolts, and you have to install them on the inside of the tailgate. Only problem is you will have to shade tree some kind of piece to hold the tailgate up when you open. I am not sure, but you might want to check a 67 hardware[hinged] to see if it works. oh, i bought galvinized barrel bolts, look much nicer. I will take some pics and post them.
john
nimrocker is offline   Reply With Quote
Old 11-29-2007, 10:13 PM   #7
SIR
SIR
SIR's Avatar
...hope some of this helps,all easy to do ,questions,just ask....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 11-29-2007, 10:46 PM   #8
brawley
Easy Does It
brawley's Avatar
check out mar-k.com they have kits for this. Sir with the green truck could you tell me what you used? thanks
brawley is offline   Reply With Quote
Old 11-29-2007, 10:47 PM   #9
fchava
fchava's Avatar
here's mine, just a later model setup extended to fit our tailgates. Latch is centered on the inside.
fchava is offline   Reply With Quote
Old 11-29-2007, 11:00 PM   #10
SIR
SIR
SIR's Avatar
...the latches are from "brothers" and the cable came from "auto-zone",just lay the tailgate down flat measure from the existing bolt holes I think these where fo** but it does not matter then trim out the inside edge of the tailgate grind down and weld the seam closed grind to taste the pins come with easy instructions you just need a drill a die grinder and a small stack of round washers welded together to the inside of the bed,for the "latch to attach"..just takes time.OH the bolts are fine thread.
Old 11-29-2007, 11:43 PM   #11
Rokcrln
Rokcrln's Avatar
Yeh I have udes the seat belt set up before but on this one I want a clean one hand set up.
This is just what I wanted to see! I know that ECE sells a relocator kit that puts the handle on the inside of 67-72's with out needing to skin the tailgate. This means it should fit in the upper boxed section of the tail gate. I might order one and see how I can make it work. I think I will also order two small bear claw latches. It would be nice to have an old truck were the tail gate goes "CLICK" and shuts.
Thanks for the motovation
Kevin
LFD Inc.
Old 11-30-2007, 01:16 AM   #12
fchava
fchava's Avatar
As I said, mine is just a stock unit turned around.
Sort of rough, but works great
Old 11-30-2007, 02:00 AM   #13
sick69
sick69's Avatar
Someone on here is using later model nissan latches and straps on a stepside. That might be something to look into aswell.
Didn't you use something like that on Lemondrop?
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 11-30-2007, 06:33 AM   #14
Rokcrln
Rokcrln's Avatar
Frank~ Lemond drop had a kit from Mar-K that was the sissor hold opens but used the spring loaded pins on each side. It worked well but took two hands and you could not just close the gate and walk away. Like I said on this truck I want that "CLICK" feeling.
fchava~ Very clean truck! Any links to your truck I can check out?
Kevin
LFD Inc.
Old 11-30-2007, 08:12 AM   #15
sick69
sick69's Avatar
Ok I remember now. What about wondering around a junkyard looking at different tailgates? Could look at all the options at once. Foriegn and domestic setups, I'm sure something will jump out at you as a good plan on what your looking for.
Btw,,, I'm headed to the jy this week end if you want me to look at those hinges, let me know.
Frank
70 chevy lwb c10
Old 11-30-2007, 10:17 AM   #16
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Kevin
LFD Inc.
Mar-K does offer the folding linkage to hold the tailgate in the open position, and also the spring loaded sliding latches. These can both be installed on the stock tailgate. Our latches can be latched in the open position so you can close the tailgate then release them to hold the tailgate closed, two hands not required. http://www.mar-k.com/installation_hints.html and scroll down to "hidden latch instructions" and "link assembly instructions"
We are developing a replacement tailgate for these trucks with a center handle and "bear claw" type latches. This will be similar our stepside tailgates with the latches and handle. We hope to have these available in 2-3 months. These will have that "click" that you desire.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 11-30-2007, 11:24 AM   #17
slepysal
slepysal's Avatar
This is what I came up with cheep and easy
http://67-72chevytrucks.com/vboard/s...light=tailgate
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Headers with dual exhaust and bellflower tips. 3 speed on the floor and finally power disc brakes !
"Excuse the chips,dents and scratches, I drive my truck."
slepysal is offline   Reply With Quote
Old 11-30-2007, 04:56 PM   #18
Rokcrln
Rokcrln's Avatar
Frank
Yes please see what you can find in the not too warn out section of the yard! Let me know what you find, I'll cover ya!
Mar-Ktech
Yes I used your keeper and spring pin kit on LemonDrop (68 step side). And yes they can be loked in the open position so one hand can be used but you know theat is not what I am looking for I can tell that it is not your first choise ether since you are working on a gate like what I want! I think it is great that people like you (Mar-K) are spending good money to create these parts for everyone.
I was talking with Stan down at ECE today (he is one of my local guys I call while sitting in trafic) and I checked with him and they (you may also) offer a handle relocator kit for teh inside of teh 67-72 fleet side's. Thekit comes with the mounting plate, handle, bell crank and rods for like I said a 67-71. This should work out great for the 60-66's and with some Small Bear claws and alot of fab time it should work. If I was normal I would wait for thenew Mar-K gate but that just is not me. Plus if I just bought it how would I justify all my welders and tools
Looks like it works well! Nice truck.
Kevin
LFD inc.
Old 11-30-2007, 09:12 PM   #19
fchava
fchava's Avatar
Kevin
LFD Inc.
here's some pics
http://www.picturetrail.com/fregon
Old 11-30-2007, 11:30 PM   #20
sick69
sick69's Avatar
Kevin
LFD inc.
I'll drop you a pm this weekend with what I picked up.
Frank
70 chevy lwb c10
Old 12-01-2007, 04:32 PM   #21
Shorty Cox
I had the "no chains" look with the "seat belt buckle" latches on mine. Never liked to looks. I picked up a tailgate with chains a couple months ago, and went back to chains. Just call me "old school", but I like the looks of the chains.
Shorty Cox is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
