Old 11-29-2007, 10:21 PM   #1
danzka4u
danzka4u's Avatar
Jeep Coil Spring Drop
Hey guys Im new to yor site and I had been looking through the pages and saw a discution on lowering by using jeep coils in the rear and cutting the coils in the front. So I said what the heck lets do it. Here are a couple of photos of my 65. I cut one full coil plus 3 inches in the front I figured I can allways cut more buts its hard to add.
before and after attached I hope
danzka4u is offline   Reply With Quote
Old 11-29-2007, 10:30 PM   #2
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Re: Jeep Coil Spring Drop
Congrats & Welcome to The Board from Indiana..........
Truck Looks Real Good, What Coils did you use in the Rear??
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 11-30-2007, 10:38 AM   #3
danzka4u
danzka4u's Avatar
I used 98 wrangler springs. Now that I look at the pictures they don’t really do the drop justice it must be the different angle but the lowered the back about 4 inches.
Old 11-30-2007, 11:15 AM   #4
slepysal
slepysal's Avatar
Thats funny I felt the same when I snaped a few before after pics of my 60.
The jeep springs are a cheep easy swap, but don expect to haul a huge load.
Nice truck and Welcome from Nor Cal !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Headers with dual exhaust and bellflower tips. 3 speed on the floor and finally power disc brakes !
"Excuse the chips,dents and scratches, I drive my truck."
slepysal is offline   Reply With Quote
Old 11-30-2007, 12:09 PM   #5
mtburg71
mtburg71's Avatar
What did you pay for the rear springs?
1964 GMC SWBFS
2005 Dodge Magnum RT
mtburg71 is offline   Reply With Quote
Old 11-30-2007, 12:20 PM   #6
toomanytoyz
Luv the Crewcabs
If you look a`t the 1st Pic you can see all the tire from top of Rim up & in the 2nd Pic it is just Top of Rim, Anyhow it Looks Great................
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 11-30-2007, 12:21 PM   #7
65 on 24's
65 on 24's's Avatar
did it bolt in or did you have to mod them any
ridin big yo
5in cpp lowerin springs in back
lowered 3in in front with cut springs for now
5 lug swap and disk in front
5 lug and disk in the rear with 3.23 gears
mild 350/400heads
7547weiand intake
600 Edelbrock
chrome block hugger headers
2 1/2 pipes in to a x pipes
super 40 flows and turn downs
turbo 350 with shift kit
65 on 24's is offline   Reply With Quote
Old 11-30-2007, 12:42 PM   #8
danzka4u
danzka4u's Avatar
Thanks for the welcome.
I dont realy put much in the bed. But I do pull a small trailer with my lawn equipment on it. I just have to take it a little easy over the bumps
Old 11-30-2007, 12:45 PM   #9
danzka4u
danzka4u's Avatar
I gave $20 for them but Im sure I could have got set for free if I would have put a little effort into it.
Old 11-30-2007, 12:47 PM   #10
danzka4u
danzka4u's Avatar
they bolt right in but the spring it self is bit thiner so the hold downs may need a little motification.
Old 11-30-2007, 02:03 PM   #11
slepysal
slepysal's Avatar
I got them for 5.00 +10.00 shiping off of e bay. look around for a 4wd shop that works on jeeps, chances are they will give them to you.
Oh and mine went in with no mods!
Old 11-30-2007, 06:09 PM   #12
04Xrider
Registered thread killer
04Xrider's Avatar
It looks great. I would like to do this to mine, but I would like a bit more drop in the front. How much did the front drop? Also what do you mean by 1 full coil plus 3 inches? I understand the one full coil, it is the plus 3 inches that is throwing me. Never mind, I figured it out.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
Old 11-30-2007, 08:15 PM   #13
danzka4u
danzka4u's Avatar
You know I didn’t measure the drop in the front but I would say about 2 inches. I put the rear coils in first and the truck sat lower in the back. After I cut fronts it now sits with a slight rake. I did have to cut some off the stops in the front.
Old 11-30-2007, 08:58 PM   #14
Stepside65
Still Truckless!
Stepside65's Avatar
Nice truck. Looks good with the new drop.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 11-30-2007, 09:18 PM   #15
04Xrider
04Xrider's Avatar
OK thanks, and welcome to the board from Cookson OK.
Old 11-30-2007, 10:48 PM   #16
Super73
Super73's Avatar
Are you using Jeep springs in the front? Wrangler, Cherokee, grand Cherokee??
I bought a set of front 6cyl cherokee springs and mine goes to the bumps (front). If I put 100lbs of lift it sits at the ride height I want so I think I'll build a spacer. I'm running a LS1/4L80E combo so I would think my front weight should be lighter than a SBC/TH350 combo.
Shaun
Super73 is offline   Reply With Quote
Old 12-01-2007, 11:59 AM   #17
danzka4u
danzka4u's Avatar
Not in the front just the back I cut the ones in the front.
Old 12-01-2007, 12:11 PM   #18
fchava
fchava's Avatar
drop springs are so cheap and allow you to carry the same load as stock, why use jeep springs?
fchava is offline   Reply With Quote
Old 12-01-2007, 01:03 PM   #19
Super73
Super73's Avatar
I'll tell you a few reasons to not use drop springs
A long light spring rate is the way to go. It stores more energy for launces. It alows the front to rise rapindly and depending on how the rear is set up (relationship to antisquat) it will help plant the tire harder allowing more seperation in the rear.
Another thing to take in to consideration with a stiff spring is the fact that your tire does not stay with the road as well. A light spring allows your tire to follow bumps better and not throw you out of a corner when a bump is introduced. Vehicles actually handle much better with a lighter spring and stiff sway bar set up. Again allowing the tire to follow the road better. Herb Adams who is a road race / circle track guy talks about this in his book Chassis engineering and Dave Morgan NHRA Chassis vetran also talks about under springing a car.
Also, just because it is a lighter weight spring does not mean you can't carry the same load. If your not itroducing coil bind or smashing down on the bumps, there is no advantage to a stiff spring IMO.
Not to mention a smoother ride.
Old 12-01-2007, 09:38 PM   #20
66trkbldr
LIGHTMUP,BURNMDWN!
66trkbldr's Avatar
I Am Using A Set Of Front Springs Out Of A V6 Honda Accord That Are Cut In Half For Rears ,using The Top Half Wich Is The Progressive Side.used The Oe Spring Hold Downs With A Little Mod.truck Launches Hard With A Cad Motor,and Hooks Way Better Than The 5" Lowering Springs That I Had Before!!! Brand New 1/2 Ton In Front Chopped To A Slight Rake, Using A Sway Bar Out Of A 454 C10. Very Nice Ride Now!!!!! Just A Little Insight For Guys Who Are Heavy Hearted Up Front,keep It Light Out Back,{spring Rate}
66trkbldr is offline   Reply With Quote
Old 12-02-2007, 06:23 AM   #21
63 & 64 Bowties
and a few others
63 & 64 Bowties's Avatar
I used 70ish Chevelle springs in the rear of my 63. They're a lot thinner gauge than the stock C10 springs. But they give a nice ride.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 12-02-2007, 07:45 AM   #22
sick69
sick69's Avatar
I know the wrangler springs work but what about the cherokee and grand cherokee springs? Also what years of chevelle springs work and how much drop do they give?
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 12-02-2007, 08:29 AM   #23
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Welcome man...from a little ways up !!!
That's the best looking lawn truck I've seen in a long time !!!!!
The drop looks perfect !!!
John
What the Heck is that ??
60-66 on FACEBOOK
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
My DOOM Buggy Build
Project 'Z069' LS7 Powered '69 Stingray(Father-n-laws)
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 12-02-2007, 12:12 PM   #24
Super73
Super73's Avatar
I'm speaking for front springs I tried a set of 6cyl late 80's Cherokee springs. The truck bareley rested on the bumps. Next week I am going to put that spring back in with a 1 inch spacer.I'm guessing it will no longer sit on the bumps and have even more stored energy getting the front in the air fast fr drag racing.
I was on a 4x4 board and was told the V8 Grand Cherokee springs have a little more spring rate in them and would probably take the truck off the bumps with out the spacer.
But from my experience a longer softer spring lifts the front faster. So if the spring is too short, just use a spacer. Just make sure you don't get in to coil bind.
Old 12-02-2007, 12:18 PM   #25
greenmtnboy
greenmtnboy's Avatar
FREE vs cheap
We all know drop springs are relatively cheap, but free is better.
As a WARNING FYI Here is mine with front springs cut TOO MUCH
I cut 2 full coils, then ended up with rubber spacers under the springs and some 1" bumpstops in place of the stock ones. In hindsite 1.5 coils would probably be ok.It rides like crap and bottoms out, but it was FREEEEE and allowed me to save my $ for '32 ford parts
I got a set of wrangler springs for the rear for free but have not gotten around to installing them yet.
greenmtnboy is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
