Old 12-01-2007, 09:02 AM   #1
tkeduk8r
tkeduk8r's Avatar
Camper wiring harness???
I was underneath my C20 the other day and the PO has "kind" of hacked what looks to be the original harness.... I am familiar with the tradtional four wire harness that runs from just outside hte firewall to the rear bumper area, but I have never seen a unmolested camper harness... does anyone OR can anyone take a pic or two for me... does any one reproduce them???? thanks,
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 12-01-2007, 04:58 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Camper wiring harness???
the stock camper harness that was on my longhorn came up in front of the bed. I don't think I have any pics of it though. I'll try to remember tonight when i have some extra time.
Old 12-02-2007, 08:29 AM   #3
Rakort
I deleted my pic, but I had a nice one I sold some time ago. Basically it runs an extra set of tail light wires, ground, and unfused 10 gauge power to the rear of the truck for a camper.
--Mike
Rakort
Parts for Sale: Pictures
Awesome Elec. Schematic Available: Picture
Rakort is offline   Reply With Quote
Old 12-02-2007, 10:51 AM   #4
Mt Man Chad
Mt Man Chad's Avatar
I have two complete nice camper wiring harnesses If you need one?
72chevytrucks.com/vboard/showthread.php?t=455875"]build thread[/URL]
68 CST SWB - Gold/White 50th anniversary. "010-020" 4 bolt main 383, AFR heads, SCAT forged large journal/TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/4.11 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 12-02-2007, 04:06 PM   #5
tkeduk8r
tkeduk8r's Avatar
Mt. Man sent PM...
Yeah, the PO has four wires wirenutted on to a harness that is tapedup with electrical tape near where the aux fuel tank resided... then it is tapped into again beneath the rear of the bed with a "four wire" trailer harness nutted to that.... the rear taillights work as necessary, but it is definetly a birdsnest of wires... I would like to return the camper wiring as the factory had it, and then correctly add a "7-wire" electric trailer brake outlet to my rear opening. I guess thats just the anal retentive shop teacher in me ... thanks for the replys...
--Mike
Old 12-02-2007, 06:41 PM   #6
Rakort
the thing with the camper harness is that if your not going to use it, it is just a liability hanging under your truck. One of the wires is a 10 ga unfused (maybe there is a fusible link I forget) power lead that comes off of the terminal block by the battery. If that shorts out your truck could go up in flames. The harness basically is a duplicate set of taillight wires + power wire that hooks or terminates to nothing....they are dead ended unless you have a camper with lights to hook them into. The taillight wiring is for when the camper overhangs the factory taillights and the camper has its own taillights. So if you don't have a camper it hardly makes sense even if you are trying to be anally original. My 2 cents..
Brian
Rakort
Old 12-02-2007, 06:47 PM   #7
Rakort
One further thought...I guess if you need the power wire for a electric trailer brake then maybe it would make sense....
Brian
Rakort
Old 12-02-2007, 08:19 PM   #8
JimKshortstep4x4
Here are a couple of pictures of the stock camper wiring harness, (out of the truck). There are a total of (6) wires that end up running back to the front of the bed where they terminated to the camper. The harness plugged in between the existing front to rear (4) wire harness that feeds the tail/stop/backup lights and in addition there was a #10 red power wire that routed to the battery in the radiator support wire channel to the terminal on the fender. To protect the power wire would require a fusible link between the + post of the battery and the terminal.
Also, there was a #10 white ground wire that grounded to the firewall very close to where the taillight wiring exited from inside.
The first picture shows the overall view of the harness and the second picture shows a closeup of the ends that plug into the existing taillight harness.
The original camper harness is not long enough to go from the front to the rear so extending the wires will be necessary.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-02-2007, 08:23 PM   #9
Longhorn Man
And here is a close up of the other end.
Old 12-02-2007, 08:37 PM   #10
WorkinLonghorn
WorkinLonghorn's Avatar
LM mine comes out at the rear of the bed as shown.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 12-02-2007, 08:57 PM   #11
Longhorn Man
interesting. Was that listed on the SPID, or was it installed by a camper dealer?
Old 12-02-2007, 09:41 PM   #12
WorkinLonghorn
No SPID but it is badged a Custom Camper. Here is a '69 Data Book reference to the camper wiring location. It looks like mine but the pic isn't too clear.
Old 12-02-2007, 10:08 PM   #13
Pont406
On my 69 I have a harness on top of the cab and also some kinda harness on the back. Does any of this look factory?
Pont406 is offline   Reply With Quote
Old 12-02-2007, 10:08 PM   #14
Longhorn Man
The harnes was a seperate option, not part of the cutom camper package... so if its not on the spid, then it is an after production instalation.
You can see my longhorn has that option listed on the SPID;
Old 12-03-2007, 10:06 AM   #15
JimKshortstep4x4
Andy,
Is that a factory terminal on the end of the harness?
I have never seen the end of the harness that actually connected to the camper. The (5) harnesses that I have were all cut off.
Jim
Old 12-03-2007, 10:28 AM   #16
Longhorn Man
while I am not positive, I am pretty sure it was original.
Old 12-03-2007, 07:02 PM   #17
WorkinLonghorn
My truck didn't have a SPID but the factory book shows it at the same location (pretty much) as mine,passenger side rear bed wall behind the wheel well.I would guess that anything else was added after delivery.
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
