Old 03-05-2008, 05:31 AM   #1
beachblazer72
Simple Question from a rookie. Where is the temp. sensor located?
I cannot find the temp. sensor or the wire that runs from the guage to the sensor? I have a 1972 Chevy Blazer K5 V8 350. Thanks!
beachblazer72 is offline   Reply With Quote
Old 03-05-2008, 05:59 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: Simple Question from a rookie. Where is the temp. sensor located?
I'm gonna move this where you'll get more views. On a 2wd the temp sensor is on the front of the drivers side head. It has a nail head style head on it and the wire going to it is supposed to be green iirc.
Being stupid ain't illegal.
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger"
96 S-10 "Pop's Truck"
03 GMC 3500 van drivetrain donor for the Green Booger
Old 03-05-2008, 06:32 AM   #3
DANTES JIMMY
DANTES JIMMY's Avatar
It May Be Covered In A Type Of Cloth Loom
Looks Like A Woven Material
DANTES JIMMY is offline   Reply With Quote
Old 03-05-2008, 08:32 AM   #4
jaros44sr
jaros44sr's Avatar
Could also be on the front of the intake manifold
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
Jim
jaros44sr is offline   Reply With Quote
Old 03-05-2008, 09:48 AM   #5
Mint68
Mint68's Avatar
I've had my stock one fall off because they are not a very good clip design. Its been a long time, buy I think I could see the wire dangling in my wheel well.
Mint68 is offline   Reply With Quote
Old 03-06-2008, 06:41 AM   #6
beachblazer72
I will look after the tornado blows through the beach. It is 4wd.
Old 03-06-2008, 08:50 AM   #7
CJ5 Convert
CJ5 Convert's Avatar
Hey welcome to the board. You acme to the right place for answers I could find my t-stat or temp sensor when i got here just check out this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=244492
I'm betting that temp sensor is on the drivers side manifold of that 350 if you need me to I'll take a pic tonight. looks like a mini spark plug. if there is no wire on it.
Heck this next thread ought to make you laugh. I felt stupid as a rock after they pointed out the obvious and nobody out here made fun of me. They just helped out.
http://67-72chevytrucks.com/vboard/s...d.php?t=250799
Welcome again and let me know if you need a pic. -J
- Jason
Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT
1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint
CJ5 Convert is offline   Reply With Quote
Old 03-06-2008, 09:16 PM   #8
MiniD
My temp sensor is between spark plugs 1 and 3 (front two on the drivers side) and a little above them. It's right between the two exhaust ports. If there are headers on your truck, the header could block the port. I dunno where it would be if that were the case.
The wire is a green wire with a black cloth insulator around it. If the insulator is over 30 years old, there might not be much of it left. It get's kinda brittle over time. It should run down the driver's side of the intake manifold, around the front of the head and down to the sensor. However, on both of the trucks I have, a previous owner re-routed them to between the steering box and the exhaust manifold pretty much just hanging there.
MiniD is offline   Reply With Quote
Old 03-12-2008, 07:35 AM   #9
beachblazer72
I appreciate yalls help and understanding. I am trying to learn as I go which takes lots of time. Everything worked fine up until about a 3 months ago. I will get pics up before I really get into working on the truck. I found the temp. sender between the 1 and 3 spark plugs. My only problem now is that the one from NAPA does not fit. I have a gauge not a light in my consol but the bad temp. gauge in the truck is one for a light???? A new temp. sender for a light looks like it may fit does this make any sense to anyone???
I was wondering if anyone has tried the glove box lock and the in dash speakers from the LMC magazine? Is it worth the hassle?
Another question… I am planning on trailering my K5 about 500/600 miles. Can I do this with v8mangnum 4 door Dakota???? U-haul says its okay but I am not sure I will be looking numbers of both vehicles. Towing will be mostly flat ground..
Old 03-12-2008, 10:50 PM   #10
pound41
Check the other side/head I am doing the heads on my 71 now and it has a temp guage sensor on each side one for a guage and one for a light. One is a square plug on and the other a circle slip. i ask my dad about it, He is a retired mechanic and restorer. He said that he had seen it many many times. Guess they weren't sure which dash it was getting so they installed both
pound41 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
