Old 03-14-2008, 09:59 PM   #1
Kim57
Kim57's Avatar
My 57 Pro Street
Been here for a while reading everyone elses threads and thought I'd start one.
I bought my truck 16 years ago with the intention of building it after raising my kids. One thing leads to another and its taking longer than expected but I try to do a little when I get the chance and funds.
496 BB
Currie 9" w/4 link
4 speed auto
67 Chevelle front clip
Boxed frame
Smooth fire wall
Custom bed
Kim57 is offline   Reply With Quote
Old 03-14-2008, 10:06 PM   #2
Kim57
Kim57's Avatar
Re: My 57 Pro Street
When I removed the old fire wall and rusted floor I needed to replace some metal in the front corner. I couldn't find any replacement parts so I made my own.
Old 03-14-2008, 10:09 PM   #3
Kim57
Kim57's Avatar
I made my own smooth fire wall out of 16 gauge steel. I know when I start setting up the engine I'll have to modify it but I want it to fit around the rocker covers so I'll cross that bridge when I get to it.
Old 03-14-2008, 10:13 PM   #4
Kim57
Kim57's Avatar
I made my own replacement floor also.
I'll post more pics when I get the chance.
Kim
Old 03-14-2008, 10:32 PM   #5
poncho_villa
poncho_villa's Avatar
It looks like you've had some fun! Got any pics of that rear end with 4 link? Did you have to narrow the rear axle?
poncho_villa is offline   Reply With Quote
Old 03-15-2008, 12:16 AM   #6
Kim57
Kim57's Avatar
The axle was narrowed. Heres a couple of the rear.
Kim
Old 03-15-2008, 12:57 AM   #7
poncho_villa
Excellent! That'll look great with those fat meats!
Old 03-15-2008, 01:24 AM   #8
pugs
pugs's Avatar
i like idea of making up my repair panels also, keep up the work looks great
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 03-15-2008, 08:11 AM   #9
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Kim
I'm doing a '73 XJ6 Jag IRS in my '57, it's not too late to change my mind and that sure is tempting.... man that is sweet!
Kenny
87Lowrider is offline   Reply With Quote
Old 03-15-2008, 08:46 AM   #10
Kim57
Kim57's Avatar
Thanks for the compliments guys.
When I first started mine I had a 77 vette rear suspension in it but got worried it wouldn't handle the torque of the big block so I went with the pro street look.
Kim
Old 03-15-2008, 10:37 AM   #11
Kim57
Kim57's Avatar
Heres a custom bed I built for my truck. I'm using the original fenders.
I had some metal bent and then welded it all together.
Old 03-15-2008, 10:42 AM   #12
Kim57
Kim57's Avatar
I wanted to tilt the bed to make it easier to remove the tires so I fabbed up some brackets and a frame for it.
Old 03-15-2008, 07:06 PM   #13
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
that's gona look bad a$$....keep up the great work, and pics
tiggerstoy is offline   Reply With Quote
Old 03-15-2008, 07:47 PM   #14
49studebaker
49studebaker's Avatar
Very cool, nice work. Thanks for sharing. Once the 71 GMC is done, I'd like to tub my Studey a bit more than it currently is.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 03-15-2008, 08:05 PM   #15
CAL 58 GMC
CAL 58 GMC's Avatar
Nice job Kim!
CAL 58 GMC is offline   Reply With Quote
Old 03-15-2008, 10:26 PM   #16
Kabwe
Certified Car Nut
Kabwe's Avatar
Nice work Kim,
Kabwe is offline   Reply With Quote
Old 03-15-2008, 11:08 PM   #17
my67chevytruck
Under Construction
my67chevytruck's Avatar
Looking Good.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-15-2008, 11:56 PM   #18
Daniel U
Daniel U's Avatar
Keep us posted! Looking good. Any chance the "kids" will want to help or be interested in the rod scene?
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 09-10-2008, 02:25 PM   #19
Kim57
Kim57's Avatar
I"ve been able to get a little more done on the bed of my truck.
These are the parts I started with to build the roll pan.
I used 1" tube to create the curve for the rear pan.
I made a jig so I could keep the 2 sides at the same size when they were welded.
Old 09-10-2008, 02:30 PM   #20
Kim57
Kim57's Avatar
The rear was rolled to match the rear fenders as much as possible but didn't quite make it so I had to strap it down before I welded it.
Old 09-10-2008, 02:38 PM   #21
Kim57
Kim57's Avatar
Here are a few more pics of the rear pan and the front bed corners.
I used carriage bolts in the ends of the 1" pipe to clean them up.
Hope you all enjoy the pics and I'll post more when I'm able to get more done on it.
Kim
Old 09-10-2008, 05:44 PM   #22
renegade8720
Looking good! I am in the process of building a 50 five window Pro Street right now. I am using the same TCI crossmember you are. I am going to run a 9" rearend with svo disc brake set up. Good luck with your build!
Renegade
renegade8720 is offline   Reply With Quote
Old 09-11-2008, 10:18 AM   #23
Daniel U
Daniel U's Avatar
Nice work Kim!
Old 09-11-2008, 10:54 AM   #24
CAL 58 GMC
CAL 58 GMC's Avatar
Nice work! Whats your plan for the steps?
Old 09-11-2008, 02:03 PM   #25
Kim57
Kim57's Avatar
Thanks for the compliments and encouragement guys, I do appreciate it.
Kim
Cal, I plan on having my exhaust exit where they would be. When I get to that point in the build I'll have a little more work on the bed but I seem to do that a lot anyway.
Kim
Thread Tools
Display Modes
