Old 03-21-2008, 11:20 PM   #1
Greg63
Enjoy your truck
Greg63's Avatar
Question front sway bar on '63-'66
I am adding a front sway bar to my '63.
Can someone provide me a picture of the sway bar mounting location on the lower "A" arm from their '63-'66 or '67-'72 ?
Greg
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 03-22-2008, 05:45 AM   #2
64Magoo
Re: front sway bar on '63-'66
Its uncanny that you asked this question. I came on here today to ask the exact same thing! Where did you get your sway bar from? I just put the shocks and springs on and am trying to find the exact spot to mount the sway bar too
64Magoo is offline   Reply With Quote
Old 03-22-2008, 06:52 AM   #3
LILRED66
LILRED66's Avatar
Here are a few photos of a factory sway bar on my '66 Chevy C20 Custom Camper lwb fleet. Hopefully, they will give your the information you need. Good luck and make sure to post pictures of your progress.
Sorry about the size of the photos. I haven't mastered the attachment feature yet...apparently.
LILRED66 is offline   Reply With Quote
Old 03-22-2008, 03:10 PM   #4
Greg63
Enjoy your truck
Greg63's Avatar
Maybe we are living in parallel universes?
I am typing right now - what are you doing?
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 03-22-2008, 03:11 PM   #5
Greg63
Enjoy your truck
Greg63's Avatar
Thanks Tony.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 03-22-2008, 03:19 PM   #6
psychorodder
psychorodder's Avatar
I took one off a 73 truck bolted right up on mine but I did have the front end off a 72 to start with so holes were already there.
psychorodder is offline   Reply With Quote
Old 03-25-2008, 06:57 PM   #7
Greg63
Enjoy your truck
Greg63's Avatar
Okay, now I need help with another issue - the frame bracket dimensions.
I just priced the GM frame brackets and they came out to $34 each (I used the part # found in another thread).
I am going to make my own but need to know the rise and run dimensions for them.
Can anyone grab a tape measure and see how high they rise and how long the flat is?
Greg.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 03-25-2008, 07:04 PM   #8
Greg63
Enjoy your truck
Greg63's Avatar
This is the bracket I am talking about:
The GM # 6271375 is now $34 in Canada.
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 03-26-2008, 07:56 AM   #9
protrash64
Resistance is Futile
protrash64's Avatar
........for which one? the stock or lowered mount? I have some lowered mounts I could measure.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-26-2008, 03:17 PM   #10
Greg63
Enjoy your truck
Greg63's Avatar
Lowered would be fine.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 03-27-2008, 03:48 AM   #11
protrash64
protrash64's Avatar
Thumbs up Re: front sway bar on '63-'66
.....heres a pic of the bracket I measured. Its a CPP item I believe. I think any thing in the ballpark should get you running just fine.
the total length is: 9 + 11/16's
from the bottom( against the cardboard in your pic) 5/8" for the low bend
2" for the high bend toward rear.
My complete measurements for the bracket were: 1.5"+5/8"+4 9/16"+2"+1 3/8"=9 11/16".
Hope this helps.........
Old 03-27-2008, 03:49 AM   #12
protrash64
protrash64's Avatar
Pic didnt come out.................
Old 03-27-2008, 06:09 AM   #13
Greg63
Enjoy your truck
Greg63's Avatar
Thanks - that helps.
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 09-11-2013, 10:09 AM   #14
1963c-10
1963c-10's Avatar
Hey Greg, I know this is an old thread, Im about to install my front sway bar also....how did your install go? Any issues drilling the lower a arms with the truck siting on the ground?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-11-2013, 11:27 AM   #15
1963c-10
1963c-10's Avatar
I ordered a set of sway bar brackets from CPP and will order new MOOG bushings once the bar is measured. I got the factory bar off ebay for $25.00
Old 09-11-2013, 01:14 PM   #16
ACK
ACK's Avatar
I installed a sway bar on my C10 over the summer and had no issues drilling the a-arms with the truck on the ground. I purchased a right-angle adapter for the drill and went to town with a step bit. I spent more time triple checking where I was going to drill than actually drilling. The improvement was like night and day.
My truck ain't dead, it just smells funny.
“Beer’s intellectual. What a shame so many idiots drink it.” — Ray Bradbury
A collection of Chevy C10 ideas, fixes, and mods ... https://www.pinterest.com/ack215/
ACK is offline   Reply With Quote
Old 09-11-2013, 01:23 PM   #17
1963c-10
1963c-10's Avatar
Thanks ACK. Ive heard the difference is quite noticeable from several people. I hadn't thought of an angle drill, I was going to go MarkB's route of a pilot hole, raise the truck and use a step drill, I'll look into both.
Old 09-12-2013, 10:57 AM   #18
luvbowties
luvbowties's Avatar
Wink Re: front sway bar on '63-'66
You may wanna double-check addition from post #11.
Where it says, "My complete measurements for the bracket were: 1.5"+5/8"+4 9/16"+2"+1 3/8"=9 11/16" ", some where, some thing does not add up; just in case it matters! My calculator added up to a total of 10 1/16"--3/8" greater.
Kinda funny, tho'. It "stood" for almost 5 8/16 years!
sam
luvbowties is offline   Reply With Quote
Old 09-12-2013, 03:03 PM   #19
Greg63
Enjoy your truck
Greg63's Avatar
I was fortunate enough to have upgraded the front suspension from a '70 C10that already had factory holes for the sway bars.
The install went fairly well once I had the correct height for the frame mount brackets.
Greg.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
