Old 03-28-2008, 04:09 AM   #1
daman18
daman18's Avatar
how to replace the window glass run channel?
I'm about to replace the window glass run channels in my doors so i was wondering how big of a job it was and how to go about it. thanks in advance.
daman18 is offline   Reply With Quote
Old 03-28-2008, 09:39 AM   #2
chromyelow1
OPS GUY
Re: how to replace the window glass run channel?
good luck with that, im subscribing to this i need to do this too real soon
chromyelow1 is offline   Reply With Quote
Old 03-28-2008, 12:17 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
1. Aproach the vehicle from it's left side as not to spook it and cause it to fight you.
2. Open the door.
3. Roll down the window.
A. Manual window(I.E. non-electric assist) Firmly but gently grasp the window crank handle and turn it counter-clockwise (Right over left) until the window is retracted safely all the way into the body of the door. Remove the window crank handle taking care not to lose the "OMEGA" shaped spring clip.
B. Power window (electric assist) Insert ignition key into ignition lock cylinder located on the right hand side of the steering column halfway between the steering wheel and the Transmission gear selector lever and turn it to the "IGNITION ON" position by rotating the lock cylinder clock-wise(Left over right) until power is established through out the vehicle. CAUTION!!! DO NOT START THE VEHICLE
Locate the 2 gang window control switch on the inner door panel of the driver's side door and depress the left switch downward until the window is retracted safely all the way into the body of the door.
4. Located on the top edge of the door panel towards the rear of the door is your door lock knob that you will need to remove by twisting it counter-clockwise(Right over left) until it comes off the lock actuator rod. Set this aside as you will be re-installing it later.
5. Remove and save 8-9 retaining screws located in the door panel - 4 across the bottom, one located at the back edge of the door almost level with the arm rest, 2 located in the armrest, and 1-2 located inside the inner door handle recess area.
6. Gently pull out on the lower portion of the door panel and lift straight up. You may have to use a little bit of "gentile persuation" to get the door panel to release from the door at the edge of the window. NOTE... There are a few plastic retainers located on the back side of the panel that will have to be replaced unless you get REALLY lucky and not break them. They can be purchased at any of your better local auto parts stores if needed. Best to take an old one along to match it up
7. Reach up and pinch the window weatherstrip together in the middle of the upper window channel and pull down gently to remove the weatherstrip from the the channel completely. Pull up on the weatherstrip at the back of the door window openingto remove the back edge of the run from the lower channel located inside the door. Repeat this for the front leading edge.
8. The front channel is an integral part of the vent window assembly. To remove it you will need to remove one screw from the top of the door frame, one bolt from just under the vent assembly and one bolt at the bottom of the vent window/channel assembly. Grasp the vent assembly at the top edge and pull it towards the back of the door causing it to tilt. Using a lift and twist motion, remove the assembly from the door.
9. Slide the window forward.
10. Remove the retaining bolts holding the rear channel to the door shell. and remove the rear channel using the same lift and twist method as used on the front. NOTE... this part can be a MAJOR P.I.T.A. and if you have tinted windows, I would STRONGLY RECOMMEND removing the door glass before doing this.
11. Reverse the process to reassemble the door.
12. Invite your friends over to have a beer and admire your work.
Good luck have fun and enjoy.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-28-2008, 01:03 PM   #4
rod86
great southern land
rod86's Avatar
ah hahaha nice work - you should write more tutorials, it would make them fun to read...
rod86 is offline   Reply With Quote
Old 03-28-2008, 05:15 PM   #5
Eyegore
What Hump?
Eyegore's Avatar
I agree w/ rod86, you need to write one for radio removal and glove box lock replacement
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 03-28-2008, 05:44 PM   #6
Rooster's82
Rooster's82's Avatar
great read! Keep it up and you might have your own column.
JG
If you can't find it at the junk yard you don't need it.
Rooster's82 is offline   Reply With Quote
Old 03-28-2008, 09:08 PM   #7
BLE 'BURBAN
That was written at 1:30 a.m. after which I was finally tired enough to hit the sack and get back up @ 5 a.m. for work.
Old 03-29-2008, 09:42 AM   #8
chromyelow1
OPS GUY
wow talk about in detail! but im glad u did it this way im completly new and am learning by what u write and how ur wirte, thanks
Old 03-30-2008, 03:53 AM   #9
daman18
daman18's Avatar
well i got it done on both sides in about 35 minutes since my door panels were already removed. Wasn't as hard as i thought it was going to be.
Old 03-30-2008, 04:38 AM   #10
BLE 'BURBAN
Good deal. I take it you just needed to replace the weather strip then and not the lower channels?
Old 03-30-2008, 04:45 AM   #11
daman18
daman18's Avatar
i replaced the two felts on both sides of the window and the long one that runs up the front over the top and down the back.
Old 04-12-2008, 06:06 AM   #12
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Perfect. I've been trying to get the glass out for about 10 minutes. THis worked great.
Way too many steps just to have your arm out the window.
jayharrell is offline   Reply With Quote
Old 04-12-2008, 07:03 AM   #13
tyjoja
daman18, where did you get the new parts you replaced? thanks and great thread, I'm bookmarking for later, bob
tyjoja is offline   Reply With Quote
Old 04-12-2008, 04:19 PM   #14
daman18
daman18's Avatar
i got mine off of ebay for about 95 bucks.
Old 04-13-2008, 12:03 AM   #15
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Very well put, Glad I changed my ink in the printer. Future notes. Will be doing the same this summer.
Much Thanks
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 04-13-2008, 03:14 AM   #16
andresco50
andresco50's Avatar
nice tutorial
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 04-13-2008, 07:00 AM   #17
SBTork
Garage wrench
SBTork's Avatar
Originally Posted by andresco50 View Post
nice tutorial
very nice, that much detail is hard to come by in a write-up
-Adam
85 C10 Suburban 5.3 / 4L60E on air, three season DD, rockin the southern GA patina.....
01 Saturn SL1 stock DD.....
83 K5 Blazer awaiting a 5.3 swap.....
SBTork is offline   Reply With Quote
Old 04-13-2008, 07:14 AM   #18
BLE 'BURBAN
Dang!!! And here all I was trying to do was convay some personal knowledge/experiance with a bit of levity/humour thrown in for good measure. I never expected this kind of response to it!!!
I'm glad it helped out and if'n I can ever be of verbal assistance again in the future with something I hope I can live up to what I've said/written/done in the past.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
