Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 04-24-2008, 05:16 AM   #1
Free88
Free88's Avatar
Question 91 Chevy cab mounts
Well I went to change the cab mounts on the wifes 91 Silverado today and to my surprise the mount was right through the frame support. Does anyone have a good fix for this or a thread explaining what to do? I was thinking of cutting a piece of plate and drilling i to fit the bushing and mount it from underneath. Is this a good idea or what? Thanks for the help in advance.
1986 Silverado Short box fleet side. project
2005 VW Tiguan 4 Motion
1997 Blazer S10 4x4
1990 Chevy Silverado K1500 Extended long box
Free88 is offline   Reply With Quote
Old 04-24-2008, 05:21 AM   #2
ed2552
One Ton X2 Club!!
ed2552's Avatar
Re: 91 Chevy cab mounts
It is rusted through?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-24-2008, 06:13 AM   #3
Free88
Free88's Avatar
ya, the mount drops through the frame support.
1997 Blazer S10 4x4
Old 04-24-2008, 02:41 PM   #4
Storm Chaser
Storm Chaser's Avatar
Your idea will work... for a while... until it rusts out around your plate. The metal for these things isn't real thick and they seem to rust easy. The best way would be to cut the whole cab mount bracket off and weld on a good one. I don't know why truck manufacturers have decided to weld them on instead of bolting them on like they used to.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 04-24-2008, 04:52 PM   #5
ed2552
One Ton X2 Club!!
ed2552's Avatar
Could probably bolt one on, just drill holes and use grade 8 hardware
Old 04-24-2008, 04:54 PM   #6
ed2552
One Ton X2 Club!!
ed2552's Avatar
give it a decent coat of paint, help prevent rust
Old 04-25-2008, 03:02 PM   #7
Storm Chaser
You could, except this bodystyle doesn't have flanges to bolt to like the previous body style (the way the riveted). This style, the body mount brackets weld to the frame at a right angle with no flanges.
1988 R2500 Crew Cab
Future plans-
Old 04-26-2008, 12:05 AM   #8
ed2552
One Ton X2 Club!!
ed2552's Avatar
I didn't know that, thx for the info
Old 04-26-2008, 03:44 AM   #9
Metal
Metal's Avatar
I had the same problem so I had these made to sit on top of the stock frame support..
Turns out my frame was bad so I did not need them after the new section of frame was welded on..
They are 1/4 thick and could be cut to fit for the under side if need be..If you want I will let you have them for whatever it costs to ship to you..
I still think the best way would be to replace the whole frame support..
Let me know and good luck......
"If at first you don't succeed use more duct tape" Red Green....
Danger --if you meet it promptly and without flinching -- you will reduce the danger by half. Never run away from anything. Never!
-Winston Churchill
A few of my holsters.............
Metal is offline   Reply With Quote
Old 04-26-2008, 04:18 AM   #10
ed2552
One Ton X2 Club!!
ed2552's Avatar
I got that exact tool kit for x-mas last year! lol, small world
Old 04-26-2008, 04:20 AM   #11
Metal
Metal's Avatar
Thats how I got mine too........
-Winston Churchill
Old 04-27-2008, 05:05 AM   #12
Zappafan
Zappafan's Avatar
I haven't owned my 90 for all that long and obviously didn't look it over all that well. When I had the fuel pump replaced, the mechanic pointed out that someone had slid a piece of 2x4 in as a cab mount. The longer I have this truck the more I'm glad I haven't got rid of the 71 yet. I guess I'll have to adapt something.
Zappafan is offline   Reply With Quote
Old 05-29-2008, 06:29 PM   #13
chevy1990
i send out that money order for them cab mount checked on the status today and still outstanding status so when you get it please send them to me
George Viens
chevy1990 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
