05-17-2008, 12:55 AM | #1 |
Timing Marks on 1972 350 Pick up
Hello All,
Well you finally have me straightened out on my HEI conversion, now I only have one question remaining and it is concerning the timing marks, On my marks, it looks like on the counter clockwise most part of the marks there is an "A" then a bunch of hash marks, then on the furtherst clockwise, there appears to be a "B or 8" Cannot really make it out and then one in the middle of the 2 that I would assume is TDC, which mark should I try to align the timing light to to get 8 to 10 degrees BTDC? Thanks so much everyone for you help previously and now Rick |
05-17-2008, 01:48 AM | #2 |
Between Trucks...
Re: Timing Marks on 1972 350 Pick up
The B is is BTDC the A is ATDC. The one in the middle is TDC. Get the mark to line up with B.
Beat it to fit, Paint it to match... |
05-17-2008, 07:48 AM | #3 |
Hello All,
So the A is not for advance? That is how it was originally timed. What I mean is just counter clockwise of the TDC mark is an A, that would be retarded, is that what you are saying, and I want to be 8 degrees, on the B, Correct? thanks all, Rick |
05-17-2008, 01:34 PM | #4 |
yes good luck mine wont runa t 8 btdc dont know why
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-17-2008, 05:00 PM | #5 | |
Between Trucks...
Click on the picture. It looks like advanced is to the left. Maybe someone who knows for sure will chime in.
05-17-2008, 07:12 PM | #6 |
Between Trucks...
05-17-2008, 10:09 PM | #7 |
Yeah,that's right.Advance is to the left ON THE TAB. If you are running timing TAPE on the balancer then it will look the other way relative to "0" on the tab.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
05-17-2008, 10:29 PM | #8 |
Between Trucks...
So the A is for advanced, anybody know what the B stands for?
05-17-2008, 10:34 PM | #9 | |
The balancer is rotating clockwise, so if the engine was stopped with the balancer mark aligned with the "0" (TDC) anything to the left (counter clockwise) would be "before" (advanced).
B= before (advanced) Before Top Dead Center A= after (retarded) After Top Dead Center There shouldn't be much marking on the ATDC side (2 degrees usually) It was only in the begining of the emissions regulations of the late 70s-early 80s that they did that. Last edited by LONGHAIR; 05-17-2008 at 10:39 PM. |
05-17-2008, 10:38 PM | #10 |
Between Trucks...
Well, I just went out and checked my timing and it was right on the money. Must of had a brain fart. On my timing tab though, the A is to the left of TDC, and the B is to the right, which seems counterintuitive. My apologies to the original poster for the miscommunication...
Beat it to fit, Paint it to match... Last edited by Sinister; 05-17-2008 at 10:40 PM. |
05-18-2008, 12:30 AM | #11 |
Hello All,
So, correct me if I am wrong, 8 Degrees BTDC is to the left, or counterclockwise of the zero mark, or TDC on the tab? Thanks all P.S. Did we figure out what the a and B stand for on the tab? Rick |
05-18-2008, 12:38 AM | #12 | |
Between Trucks...
I think the jury is still out on what A and B mean.
05-18-2008, 12:48 AM | #13 |
Clean it off with a rag. That "B" is actually an "R" which stands for "Retard".(Which is what I feel like 'cause I had to actually go out and look,after all these years)
05-18-2008, 12:48 AM | #14 |
Thank You Sinister and workinlonghorn, now it all makes sense!
That helps a whole bunch Rick Last edited by Momboy007; 05-18-2008 at 01:04 AM. |
05-18-2008, 03:00 AM | #15 |
05-18-2008, 03:12 AM | #16 |
Sorry Longhair,
I forgot to mention you as well and I apoligize. Your help was greatly appeciated and I feel like now I CAN DO THIS! Thanks again, Rick |
05-18-2008, 03:17 AM | #17 |
It's not about that..........There are two conflicting answers here. If mine wasn't one of them, I would be as lost as when it started?
B is advanced (Before Top Dead Center) A is retarded (After Top Dead Center) Last edited by LONGHAIR; 05-18-2008 at 03:18 AM. |
05-18-2008, 03:40 AM | #18 |
On mine,and lots of others I've worked on it's A=Advance and R=Retard.
05-18-2008, 03:40 AM | #19 | |
Between Trucks...
A = Advanced R = Retarded And I feel a little retarded myself at this point.
05-18-2008, 03:54 AM | #20 |
Well that would make sense if the A was on the left (counter clockwise), but I don't think I have ever seen one that way? They always have a deeper V-notch at 0* and smaller notches on the advanced side in 2* intervals.
05-18-2008, 04:29 AM | #21 |
O.K. all, so now I really confused, is BTDC counter clockwise on the timing tab, or counterclock wise, or is it Clockwise, or to the right on the tab?
05-18-2008, 04:44 AM | #22 |
Before (advanced) is counter-clockwise ....to the left of the 0
05-18-2008, 05:17 AM | #23 |
Thanks Longhair, Now I can definately do this
Rick |
05-18-2008, 02:30 PM | #24 |
Just to prove to myself that I hadn't lost it entirely....I went out to the garage and looked at my Chevelle. Now, I realize that this is not a '72 350, but the markings are clear. Not only is it marked as "Before - After" it is not just the letters, but the entire word. It doesn't, however have the deeper mark at TDC? It shows from 12* before to 8* after.
05-20-2008, 12:20 AM | #25 |
Thanks Longhair,
That about puts the final nail in the Which way is advance Coffin" I timed it right after and now it is beautiful!!!! Thanks again Rick |
