Old 06-02-2008, 04:49 PM   #1
Ole Blue 68
Ole Blue 68's Avatar
Anybody use Percy's Aluminum Header Gaskets
I've given up on Mr. Gasket so I think I'm gonna try a set of Percy's and see how they work. Anyone use them? If so, what did you think?
Ole Blue 68 is offline   Reply With Quote
Old 06-02-2008, 06:00 PM   #2
Orange
Licensed to Thrill!
Orange's Avatar
Re: Anybody use Percy's Aluminum Header Gaskets
That's all I will settle for on my collector flanges. (assuming we are talking about the dead soft aluminum type). Of course, I have only had 1 set. (They have never failed - whereas all the other did).
I haven't had any problems with my header gasket's, but if I ever do, that's exactly what I would use.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 06-02-2008, 06:23 PM   #3
AllenKarber
I've had a set of their collector gaskets on my truck for two years,and their going strong! Of course the truck hasn't run yet either.
AllenKarber is offline   Reply With Quote
Old 06-02-2008, 08:55 PM   #4
Musclerodz
We use them and sell them. Nothing better on the market.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 06-02-2008, 10:21 PM   #5
Mudder
Mudder's Avatar
I have been using the regular ole manifold gaskets that you can get for about 8 bucks. They have the little ears on them, u can start all your bolts then just slip them in and the can even be reused sometimes if you need to take them loose for some reason. One side is a metalic. (silver) I've never had em leak.
Mudder is offline   Reply With Quote
Old 06-03-2008, 07:20 AM   #6
70GMCer
70GMCer's Avatar
same here......never had them leak......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-03-2008, 07:50 AM   #7
caminokid
Chevy nut
caminokid's Avatar
I have been using the Mr. Gasket ones. The only time I have had a blow out is when the bolts have backed off.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-03-2008, 08:02 AM   #8
Mudder
Mudder's Avatar
camino kid if you cut the flanges on each side of the center tubes the bolts will keep the bolts from coming loose.
Old 06-03-2008, 10:58 AM   #9
Ole Blue 68
I saw your post on this Mudder; it's a great idea. I'm gonna give the Percy's a shot and if they don't work, I'm gonna cut the flanges.
Old 06-03-2008, 12:28 PM   #10
Mudder
Mudder's Avatar
Look close at the flanges on the side of the center tubes. Cut each flange twice. When I bought these headers I took them half way out of the box and cut the flanges before I sent them to Air Borne Coatings to have coated.
Old 06-03-2008, 12:37 PM   #11
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
I've been hooked on them for a few years now.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 06-03-2008, 03:25 PM   #12
Ole Blue 68
Good to know there's some fans out there. I'm gonna install a set this weekend.
Old 06-03-2008, 05:44 PM   #13
mbgmike
We sell them $27.00 per set. for small block chevy.
800-398-0537
mike
mbgmike is offline   Reply With Quote
Old 06-03-2008, 05:48 PM   #14
chevy72blu
chevy72blu's Avatar
They are great... I could never get a set of Hooker SBC headers to seal until I decided to spend the cash on Percy's.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 06-03-2008, 06:32 PM   #15
steelhorse
steelhorse's Avatar
I bought some copper ones from advance or somewhere and have never had a prooblem with them
steelhorse is offline   Reply With Quote
Old 06-03-2008, 08:13 PM   #16
tjvending
tjvending's Avatar
I got this small ticking noise coming from the headers , top or bottom, I'm not sure which it is. It makes the most noise (Ticking)from stepping on the gas. What do you think? Coming from header to engine or header collectors? Let me know. My collectors are not that great, I put double gaskets on them and still have this ticking noise. I had one bolt backed out a few treads on the passenger rear header to engine
TJ
tjvending is offline   Reply With Quote
Old 06-03-2008, 11:18 PM   #17
Mudder
Mudder's Avatar
You have a leak somewhere. Probably around where that bolt is coming loose. The bolts back out because th flanges were warped when they welded the flanges to the tubes. Cut the flanges like I expained and use the gaskets I told you and I bet you wont have anymore problems.
Old 06-06-2008, 12:42 PM   #18
tjvending
tjvending's Avatar
What or how did you cut the headers with?
TJ
Old 06-06-2008, 05:13 PM   #19
BarryB
BarryB's Avatar
TJ
When I saw this I was thinking just a plain hacksaw would do the trick. But I have cutoff wheels for my grinder so thats what I will use for mine WHENEVER I find the time to full with my truck.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 06-09-2008, 09:33 AM   #20
Ole Blue 68
Installed the header gaskets this weekend (in 95 degree heat, fun) and I could tell the difference right away. I'm gonna do the collectors (Percy's again) next and hopefully that solve my exhaust issues.
Old 06-09-2008, 11:57 AM   #21
chevy72blu
chevy72blu's Avatar
Dont forget to torque them back to spec after bringing it up to operating temp a few times! After that, you shouldnt have to worry about them again.
RIP EastSideLowLife
Old 06-09-2008, 01:34 PM   #22
SoCal71K20
Yeah, they do a good sealing job. I think Summit also sells their own named brand too.
SoCal71K20 is offline   Reply With Quote
Old 06-10-2008, 08:49 AM   #23
Ole Blue 68
Thanks! Re-torqued them after a good run on Saturday and will do it again in a week or so.
Old 06-10-2008, 09:11 AM   #24
samwise68
FarmBoy.
samwise68's Avatar
Just my 2 cents: I was going to go with Those dead blow soft aluminum gaskets, but when the Autozone tried giving me the most expensive set, which were round port big block, I decided to go elsewhere.
I'm using the normal little eared buggers, and haven't had an issue yet. Bought header bolts, and put loc-tite on them. torqued them down. heated it, re-torqued, despite not being able to get any more turns. and she's sittin' pretty at the moment.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
