Old 06-09-2008, 07:41 PM   #1
byrd
Union Electrician
byrd's Avatar
Pics of plug wire routing with hei and ram horns
I need some ideas on how to cleanly run my new custom fit plug wires and I still have my ramhorns and am using HEI any help will be greatly appreciatede
TIA....Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 06-09-2008, 07:48 PM   #2
JimKshortstep4x4
Re: Pics of plug wire routing with hei and ram horns
We make wire separators out of electrical ties and use 180 degree ends on the spark plug wires to keep them away from the Rams horn manifolds. Here is a picture to show you the idea.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-09-2008, 07:54 PM   #3
OhioDan
OhioDan's Avatar
Randy, Here's the way I routed mine with HEI and ramshorn exhaust. Pic shows point dist. instead of HEI, but it routes the same. Hope this helps? You can get the plugwire stands from GMCPauls. He has them in stock.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 07-02-2010, 10:04 AM   #4
msgross
msgross's Avatar
bringing this one back from the dead... borrowed a pic from Bruce88... I already have 90 degree boots on my wires or i'd go this route... looks nice.
40200 - JEGS 8.0mm Red Hot Power Wires
RNM-1101S - R&M billet wire looms
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-02-2010, 10:20 AM   #5
dznucks
dznucks's Avatar
I used the plug wire off of a vette when i had rams horn manifolds. they are much longer than the truck wires which allows you to route the wires under the manifolds.
LMC has some spark plug wire stands/holders that will work for these types of plug wires and you can see how they are routed. on page 158, in the Ignition section, of my LMC catalog, they have the plug wire retainers for the vette style wires with the ram horns manifold.
and depending what version of the manifolds you have, i would grind the manifold casting a bit around plug 6. this was notorious for burning the boots and casuing arching. the manifolds pictured above are much nicer castings than mine were and they clearly dont have the problem. but some do.
dznucks is offline   Reply With Quote
Old 07-02-2010, 11:02 AM   #6
kwmech
I just run them the length of the valve covers (top) and curl them around the front
Old 07-02-2010, 11:23 AM   #7
faribran
OHIODAN has the right idea.... thatz how i did mine..
faribran is offline   Reply With Quote
Old 07-02-2010, 11:48 AM   #8
michael bustamante
michael bustamante's Avatar
alright where are you guys getting these long ol wires from? custom making them? I ordered mine for a 77 chevy truck and they work and clear the ramhorn but they look awful, DZNUCKS: what year vette should I ask for?
1967custom
michael bustamante is offline   Reply With Quote
Old 07-02-2010, 02:39 PM   #9
my67chevytruck
Under Construction
my67chevytruck's Avatar
most use universal, cut to length kits, vs pre-fabbed.......
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-02-2010, 02:58 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Mine are from a 77 Vette, they are long enough to route under the rams horns.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
leddzepp is offline   Reply With Quote
Old 07-02-2010, 03:39 PM   #11
my67chevytruck
Under Construction
Have any pics, or did you route the same as the diagram above?
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 07-02-2010, 04:33 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Same as Ohiodans diagram.
RIP ElJay
Old 07-02-2010, 07:56 PM   #13
k5hart
k5hart's Avatar
This is what I did when I had ramhorns. I had them routed exactly like the diagram. Worked great.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 07-02-2010, 09:45 PM   #14
Rack Man
Here's how I did mine...mostly stock routing except I did not run the front wires behind the manifolds as I couldn't find a good place to the hold them secure and was worried about burning them.....so I used a clip on the frame..
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 07-02-2010, 11:01 PM   #15
OhioDan
OhioDan's Avatar
Been awhile since I saw this thread. I used plug wires for a 75 vette with HEI. Worked good.
Old 07-02-2010, 11:10 PM   #16
Jackal2k9
Enginerd
Jackal2k9's Avatar
I second the billet plug wire holders... I had those on mine and they are coming back unless I do a duramax / allison swap
Jackal2k9 is offline   Reply With Quote
Old 07-07-2010, 10:27 AM   #17
faribran
on the front plug wires, i routed mine between the engine and the motor mount...
Old 10-01-2010, 11:55 PM   #18
dabruce15
dabruce15's Avatar
Wow, what did you paint the exhaust manifolds with? POR15? Looks great!
Beauty is in the eye of the beer-holder.
Praise the lowered!
dabruce15 is offline   Reply With Quote
Old 12-24-2010, 10:47 PM   #19
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I like it.
66 Service truck build:
Old 12-25-2010, 01:57 AM   #20
Rack Man
I used Eastwood High Temp Coating.....Stuff is awesome!
http://www.eastwood.com/factory-gray...ating-kit.html
RM
Old 12-25-2010, 11:21 AM   #21
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Ordered mine from Kingsbonre
and used the original mounting method.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-25-2010, 03:12 PM   #22
yote1234
yote1234's Avatar
ok so the 77 or 75 vette are longer?
1978 2wd blazer
1972 short cheyenne
1968 camaro 327
1965 chevelle malibu 283
1968 honda minitrail z50a #377
1966 uh1-d huey bell 204
yote1234 is offline   Reply With Quote
Old 12-25-2010, 03:56 PM   #23
Mike Bradbury
Mike Bradbury's Avatar
RM
Shoot I was going to use this but in the end I didn't, now i wish I had. looks great.
My wires are run per the diagram. I used what NAPA had labeled as for an RV of that same vintage. probably the same as the vette. Plenty of length to route in various different pathways.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Mike Bradbury is offline   Reply With Quote
Old 03-02-2013, 12:44 AM   #24
jeremy32v
love this thread. going to start my wires over this weekend!
jeremy32v is offline   Reply With Quote
Old 03-02-2013, 02:22 AM   #25
Mike Bradbury
I know I said I ran my wires as per diagram but that was before I rebuilt my engine. After the rebuild I used the billet aluminum wire managers and went over the top of the ram horns. I used the Kevlar wire shields to protect the wires from the high heat stored in the manifold. The wire managers keep the wires far enough away from the manifold that I have not had any trouble.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
