Old 06-11-2008, 12:38 AM   #1
1975stepside
Stepside Fanatic!
Can you remove leaf springs to lower the rear?
My truck rides better when there is half a load of firewood or a couple engine blocks in the back. So, I was wondering if I can lower it about 4" by removing leaf springs? If so which ones and how many? Thanks for any advice!
1975stepside is offline   Reply With Quote
Old 06-11-2008, 05:14 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Can you remove leaf springs to lower the rear?
Not recommended. Most truck drivers do remove the smallest/thickest leaf. Any more and you risk too much.
You can lower 4" by using arched leafs. The leafs are arched for a 4" drop. I have a set. I'm afraid to install them. The rear may end up lower than the front! I may have to try anyway.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-11-2008, 11:00 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
gchemist is correct. You can lower it 3/4" or a bit more by removing the thick overload leaf. If you start taking springs from the pack they will eventually sag with out support.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-11-2008, 12:25 PM   #4
andresco50
andresco50's Avatar
I love my ride with 2 removed leafs in each side is a little bit soft I have maybe 1 1/2'' of drop
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 06-11-2008, 12:46 PM   #5
dooce
the PO of my truck did it to level the rake out. i hate the way it rides. maybe he took out the wrong leaf? idn, but i have lowering leafs on order now to fix the problem.
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 06-11-2008, 05:16 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
I have a local spring and axle shop, that can take springs and rearch them to what you want. The trick is to not weaken the spring rate, or you take the chance of throwing the alignment of the driveline out of synch.
piecesparts is offline   Reply With Quote
Old 06-11-2008, 08:44 PM   #7
slugish
Slugish
Yea ,I have dearched springs as well done by a spring shop ,along with hangers & shackles. They recommended dearching as opposed to buying lowering springs / hope this helps / the co. has been in business for 40 or more years with a top notch reputation.
slugish is offline   Reply With Quote
Old 06-11-2008, 10:33 PM   #8
xtreme80
Wishin' I had more money!
xtreme80's Avatar
I took out the second from the bottom (not the overload), and it dropped it about 3/4 of an inch... for about 3 months. As of now it's at about an inch and a half drop and probably gonna sag more than that. Even with the C-notch I'm on the bumpstop. Time for a new set of springs!
xtreme80 is offline   Reply With Quote
Old 05-01-2014, 07:12 AM   #9
three80three
So let me get this right if I pull the one right before the last one out it will drop lower than it would if I just pulled the bottom one out ? Or should I just pull the the very bottom one out and leave the other ones in because my brother has a z71 and he pulled the shortest one on the bottom out and he's low but not dragging the ground.
three80three is offline   Reply With Quote
Old 05-01-2014, 09:13 PM   #10
superwade57
Be careful pulling the bottom spring out if You have any kind of power. I have a swb with a flip in the back and I took out my over load...now it wheel hops something nasty. Actually broke the spring perch welds off my axle tube. I'm putting my overloads back in and welding my new perches under the axle to eliminate the flip kit. I think thatt overload acts similarly to a traction bar since its so thick. With out it the springs Just wrap way to much?
superwade57 is offline   Reply With Quote
Old 05-02-2014, 11:16 AM   #11
three80three
So if not the bottom one which one is a good one to pull out because I have a 383 stroker motor and I'm pretty sure its gonna put out some power and I don't kneed the wheel hop but I wanna lower the rear end so which one should I pull out?
Old 05-02-2014, 06:58 PM   #12
c10454
How many leaves are in the pack? Mine have 8 plus the overload, I think most have 3-4 depending on the year for a 1/2 ton.
c10454 is offline   Reply With Quote
Old 05-02-2014, 08:44 PM   #13
three80three
I cant remember I think its 4 but do to the fact that I can't afford to take it to a shop I just want to knkw the most sufficient way to do this without messing up anything.
Old 05-03-2014, 06:44 PM   #14
comegetsome2003
comegetsome2003's Avatar
Buy some drop shackels....I've pulled springs out before on a ton of vehicles.....mostly for high school kids(myself included when I was young) who didn't have much money for lowering kits......as I've gotten older ride quality has become a nessecity with a family....if you already have shackels looked at a set of drop hangers or a flip kit....either one will get you where you wanna be and still ride good
1991 Square CCLB Dually...laid out on 22s with an old noisy 12 valve
comegetsome2003 is offline   Reply With Quote
Old 05-04-2014, 08:32 AM   #15
three80three
I'm gonna check into some drop hangers and see just how much they are but I may still need to do it the cheap way, thats why im trying to determine how to do it without buying anything if I can
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
