Old 06-12-2008, 11:50 PM   #1
sandking
.....I am working on it.....
sandking's Avatar
Here is a "Not Your Typical" 4wd Blazer build
I bought this 1972 Blazer last summer to fulfill my "ultimate" vehicle needs. The catch was a limited budget (Do those words even work in the same sentence???). My goal for this is for the Blazer to be able to go in just about any terrain that I want it to. It will not be "the best" at anything, but at least I can do it all to a point. I like the dunes, hardpack desert and street. I come from high speed desert vehicles, trucks and buggies. This Blazer will also prerun and chase for a Class 1 truggy that a friend of mine is also building and hoping for a 2010 season of racing in the MDR series (local So Cal desert racing). Again, this will be a street friendly, all around vehicle. It will have a lower center of gravity then most of the 4x4 you typically see..............
I will be doing 95% of this work myself. The only things I need to send out to be done will be the transmission work, gearing in both axles and then the machining in the motor. Enough of the boring stuff, here are my plans.........
Full cage front to rear, top to bottom. All to be done in 1.75x.120 DOM tubing.
The front will be using the stock 44 axle (until it breaks), 14" coilovers, raduis arms, pan hard and x-over steering. It should pull about 15" of travel (not articulation).
The rear will also use the stock 12 bolt (until it breaks) and have a 4-link design with a cantileever shock set-up. I do not want the shocks to go through the bed, thats the reason for the canti design. I should be able to pull 20"-22" of travel easily with this setup.
The motor will be the original motor, but I will build it to about 400-420 hp. It will have a nice cam, aluminum heads, intake, upgraded valve train, headers, etc.
For the trans, I will be removing the 4-speed and the 205 it has now and replacing it with a th350 with the 205 xfer case. I will have the trans fitted with upgraded cltches and a manual/auto valve body. I want the auto for the luxury and the ability for my wife to drive occaisionally (sp?)
The interior will have PRP suspension seats. Buckets in the front and a 42" bench in the rear. I will have four 4-point harnesses also.
Tires are 35x12.50x15 BFG A/T with cheapie steel "Soft 8" wheels.
Here are some pics. I only have limited time and budget to do this, it will be a long build. These first pics are how it looked before I started............
sandking is offline   Reply With Quote
Old 06-13-2008, 12:01 AM   #2
sandking
sandking's Avatar
Re: Here is a "Not Your Typical" 4wd Blazer build
Although these pics may not be in order, here are some progress pics........
Old 06-13-2008, 12:16 AM   #3
sandking
sandking's Avatar
More.............
Old 06-13-2008, 12:23 AM   #4
sandking
sandking's Avatar
More...........
Old 06-13-2008, 12:27 AM   #5
19gmc67
19gmc67's Avatar
thats one hell of a cage,keep up the great work
19gmc67 is offline   Reply With Quote
Old 06-13-2008, 12:30 AM   #6
sandking
sandking's Avatar
More.........
Old 06-13-2008, 12:39 AM   #7
uno67
uno67's Avatar
very sweet
subscribing to this one
uno67 is offline   Reply With Quote
Old 06-13-2008, 12:40 AM   #8
sandking
sandking's Avatar
These last few are the way it sits now...........
Old 06-13-2008, 12:46 AM   #9
sandking
sandking's Avatar
And last for now.............
Old 06-13-2008, 12:49 AM   #10
sandking
sandking's Avatar
Thanks for the kind words!! It is a work in progress. Some parts still need more bracing and/or plating. Someday, someday..............
Old 06-13-2008, 01:15 AM   #11
PBFAB.COM
PBFAB.COM's Avatar
VERY impressive!!!!
First off... you have some tube bending skills! What notcher are you using?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-13-2008, 05:24 AM   #12
vtblazer
vtblazer's Avatar
Very sweet front section!
Definitely watching this one and steeling some ideas.
X2 on the tubing skills, nice.
vtblazer is offline   Reply With Quote
Old 06-13-2008, 06:25 AM   #13
Rokcrln
Rokcrln's Avatar
WOW!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 06-13-2008, 07:00 AM   #14
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Very nice...and impressive as well.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 06-13-2008, 08:02 AM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Great job....I was going to ask about the notcher as well....in the market for a good one...
John
What the Heck is that ??
60-66 on FACEBOOK
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
My DOOM Buggy Build
Project 'Z069' LS7 Powered '69 Stingray(Father-n-laws)
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 06-13-2008, 08:57 AM   #16
sandking
sandking's Avatar
Thanks for the kind words. The notcher is the JD Notchmaster. The best $249 I have ever spent.
Old 06-13-2008, 09:05 AM   #17
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Cool man...I have a JD model 4 bender....have had it for about a year, and still haven't used it...still need a pump for it.
I will look into that notcher, when the time comes.
John
60-66 on FACEBOOK
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My DOOM Buggy Build
ACC on FACEBOOK
Old 06-13-2008, 09:15 AM   #18
nightmare
nightmare's Avatar
Very nice indeed. Should be a very stout rig once finished.
One question though, how are you going to be able to get to the engine? From what I can tell, there's only one removable piece to allow for access.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 06-13-2008, 10:32 AM   #19
sandking
sandking's Avatar
You're right. The front bar right now is removable. The bar going across from shock mount to shock mount will have "tube connectors". I have not installed those yet untill my upper shock mounts are officially in place. These are the connectors.......
Old 06-13-2008, 03:02 PM   #20
Jtrux
I'm a poor spectator
Jtrux's Avatar
That's pretty impressive.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 06-13-2008, 03:10 PM   #21
Big J
Its lookin' like a Blazer!
Big J's Avatar
Awesome project. Looks like a solid start to a solid rig. How much room would it take up if you did go through the rear floor to mount the coilovers? Just wondering.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 06-13-2008, 03:27 PM   #22
nightmare
nightmare's Avatar
Cool. I figured that this was thought of, but it never hurts to ask. Good build.
Mike
67-72 FAQ
Old 06-13-2008, 03:49 PM   #23
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Holy cow! That's a lot of tubing Looks good
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-13-2008, 06:05 PM   #24
tdkosta
tdkosta's Avatar
Wow- I can't wait to see this one finished. How much time do you have into this one? Nice job!
Can you build a tube around my 4 year old for me? He's always getting banged up after running full speed into everything. It doesn't have to have the tube connectors to let him out, I'll just leave it permanently attached to him.
tdkosta is offline   Reply With Quote
Old 06-13-2008, 06:33 PM   #25
sandking
sandking's Avatar
Its not really a space issue, its just that in order for a 2.5 coilover to go through the floor, you need at least a 6" hole. This being somewhat street legal and my daughter sitting in the back, I dont want debris going through the hole. Besides, it will allow alot more noise too. I suppose I could box around it, but I think the cantileever would be a different touch while being quite affective.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
