Old 06-20-2008, 03:37 PM   #1
Quadtrax
Time for tires
Ok, got my rally's (15X8) sandblasted and all painted. Now it's time for tires. I want something that looks good but still drives good.
Tell me your story!!
72 LWB C10 Project
93 K5 Blazer driver
Quadtrax is offline   Reply With Quote
Old 06-20-2008, 03:42 PM   #2
estig70
estig70's Avatar
Re: Time for tires
You know the rules.........................
I don't think you can beat a good set of BFG's.
Now lets see those freshly painted wheels.
Eric
estig70 is offline   Reply With Quote
Old 06-20-2008, 03:57 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Time for tires
What width rims??
I have 15x8's on the front and 15x10's on the back. All tires are T/A's, with 245-60 up front and 275-60 out back.
Early Classic used the 245-60's all the way around on their trucks with 15x8 rallye's.
I had previously run a 235-60 on a 15x7 aluminum wheel, but they are too short, especially with the 2.5-inch drop spindles I have.
Member Nr. 2770
Old 06-20-2008, 06:57 PM   #4
463
463's Avatar
Re: Time for tires
went from the 275/60 on 8" to the 235 /70 15. found that the 275/60's ware to fast in the center of the tread for me.
Trueman
463 is offline   Reply With Quote
Old 06-20-2008, 07:08 PM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: Time for tires
255-60-15 look pretty good on 15x8 rally rims.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 06-20-2008, 08:03 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Time for tires
Walked into Jegs with $400, came out with 4 tires and enough for a real cheap date. 2 275/60s for the rear, and 2 245/60s for the front. (BFG's)
15X8 rallys like yours.
I don't have them mounted on the burb yet... but I will here in a few more days.
Here's my old GMC with the same size tires. 10 inch rims in back, and 6.6 up front. The width of the rim makes a HUGE difference in the height of the tire.
Old 06-20-2008, 08:50 PM   #7
chevguy7
chevguy7's Avatar
Re: Time for tires
I'm going to go with 255/60 15 BF Goodrich Radial TA's on the front. They are getting mounted on my ralleys tomorrow. When my truck is done I will probably run 275/60 15's on the rear.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
Old 06-20-2008, 09:22 PM   #8
pat123
Pat
pat123's Avatar
Re: Time for tires
i just painted my rallys chevy orange and am putting ta radials on it
pat123 is offline   Reply With Quote
Old 06-20-2008, 09:42 PM   #9
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Time for tires
Another vote for BFG's on Rallys - Hard to beat, IMO!
'68 C-10 Custom SWB, 89,000 mile survivor
'69 C-30 Car Hauler (Ramp Truck) 383, SM465
'67 C-30 Dually Project 6.2 Turbo Diesel, NP435
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-20-2008, 09:48 PM   #10
Longhorn Man
Re: Time for tires
The BFG's aren't the best tire on the market, HOWEVER... They last pretty good if your front tires are pointed int he same direction and you keep the burnouts to aminimum, they are fairly quiet, stick fairly good, and they look good with white letters in, or out (depending on what look you are going for)
They are fairly inexpensive considering they are pretty good in all the areas I mentioned.
One area they do fall short in, is wet weather. I never cared for them in the rain.
Well, they suck in the snow too... but that's not what they are ment for.
Old 06-20-2008, 10:20 PM   #11
truckdude239
truckdude239's Avatar
Re: Time for tires
i have 255/70r15 daytona Dayton sr tires on my truck best tire i ever rode on but they quit making them
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
1998 Honda Accord 4 door with 318k(brothers car)
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-21-2008, 12:04 AM   #12
MylilBowTie
Right turn Clyde
Re: Time for tires
Firehawk Indy 500 are pretty good also.
Old 06-21-2008, 02:06 AM   #13
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Re: Time for tires
I'm a cheapo, and I wanted to rotate, so I went with BFG 255/60 on all four corners. Having seen it now, though, I wish I would have gone wider on the rear.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 06-21-2008, 02:23 AM   #14
heavy70
heavy70's Avatar
Re: Time for tires
275/60x15's all the way around!!!
heavy70 is offline   Reply With Quote
Old 06-21-2008, 10:27 AM   #15
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Time for tires
I just bought a set of 255-70-15 BFG's for my DD.I really like them and unless I find a much better deal will be running 255-70-15 on the rear and 225-70-15 on the front of the panel.I agree with LHM but figure I will probably have to replace due to age before I wear them out.I usually only put about 5,000 a year on the Panel.
BTW I had 255-65-15's Goodyears on the DD before and they are an awsome tire.I just could not bring myself to spend over $800.00 for them.The first ones lasted 60,000 miles and I'm still using the spare.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-21-2008, 11:14 AM   #16
Custom 68
D.U.F. Member
Custom 68's Avatar
Re: Time for tires
I have 275 60 toyo proxies all the way around they grip good. They are directional so you can rotate front to rear...
Dave
1968 Custom Chevy with turbo charged 5.3 gen III T56 six speed swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-21-2008, 11:52 AM   #17
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Time for tires
Pictures??? I did 275/60's all the way around on my last one. BFG's. I did not know Toyo made Proxies that size. I think I found my new tires.
chevy_mike is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
