Old 07-14-2008, 03:33 PM   #1
1972CST
1972CST's Avatar
Pics and specs of lifted blazers
I have a good idea of how much I want to lift my blazer thanks to a few members in an earlier post. Lets see some lifted blazers w/ specs!
1972CST is offline   Reply With Quote
Old 07-14-2008, 04:06 PM   #2
LUV2XCLR8
"Square Corvette"
LUV2XCLR8's Avatar
Re: Pics and specs of lifted blazers
Well for just a few more months it will look like this
4/6 Spring Lift (Offset to counter top weight, no rear sag)
No body lift, and 35 x 12.5 x 15's on 8" Rally's. Doesn't rub
for street cruising but would rub if you were to wheel it
The Toy: "Square Vette" 72 C5 Blazer
Toy Puller: "Burakkubyūtī" 12 Tundra
Toy Hauler: "Feathers" Aluma 8218T
Owner "TN Classic Transport Carriers"
LUV2XCLR8 is offline   Reply With Quote
Old 07-14-2008, 04:24 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
4" of lift, stock 16" wheels and P235/85R16 tires (approx 31.5" tall)
a few more in the signature link...
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-14-2008, 05:13 PM   #4
Long Roof
Old School, New Style
Long Roof's Avatar
I *think* I have 6" spring lift (installed by previous owner) with 36x12.50x15's (34 3/4" tall) & 4.56 gears.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 07-14-2008, 06:36 PM   #5
1tonblaze
1tonblaze's Avatar
Here is a pic of mine . it started out with 4 inch springs with 4 inch blocks in the rear with broken leaf packs . I took all that out threw it all away got new 6 inch springs for the front with ORD shackels and shackel hangers for a total of 7 inches in the front . the rear is the ORD shackel flip kit with 3 inch rear springs and a one inch zero rate block to recenter the axle and that is for a total of 8 inches . The axles are a 3/4 dana 44 with 4:10 gears and the rear is a 1 ton 14bolt with 4:10 gears . The tires i have on it now are 36/14.50/16 on 16x10 procomp rims . also there is a one inch body lift in the truck to from ORD so the total lift is around 9 + inches give or take .
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires
1972 nova plane jane 6 clyinder might sell might keep dont know
2004 chevy s-10 crewcab zr5 sold
1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me
2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went .
1999 k1500 suburban 350 vortec 4l60e leather land yacht .
Last edited by 1tonblaze; 07-14-2008 at 06:38 PM. Reason: forgot another inch of lift
1tonblaze is offline   Reply With Quote
Old 07-14-2008, 07:10 PM   #6
bigbadchev72
People know me
bigbadchev72's Avatar
Heres mine, 8" 73-87gm front springs,8" rear shackles, 1" zerorate, rear 6" springs and 3" block. 38x14.5x16 toyo m/ts on polished 16x10 rock crusher wheels. The ones with the boggers are 35" x16x15 on 15x10 white spoke 8lug rims.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 07-14-2008, 07:28 PM   #7
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
2 inch in front and custom3 inch blocks in rear whant to do 4 inch all spring lift some day
49 chevy 5 window 20 year project
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 gmc 305 v6 custom
72 k5 highlander blazer 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
Matt's k5 is offline   Reply With Quote
Old 07-14-2008, 08:51 PM   #8
vtblazer
vtblazer's Avatar
Couple pages of good reading for ya, welcome to the board.
http://67-72chevytrucks.com/vboard/s...archid=1285837
vtblazer is offline   Reply With Quote
Old 07-14-2008, 10:53 PM   #9
1972CST
1972CST's Avatar
VT, I could not get that link to work?
Old 07-14-2008, 10:57 PM   #10
1972CST
1972CST's Avatar
bigbadchev72, Do you know any details to use 73-87 front springs? That is one sharp truck!
Old 07-14-2008, 11:09 PM   #11
bigbadchev72
People know me
Not too much too it really, just bolted thm in place and used some 3/8" flatbar for the rear shackles on the front springs, i have no alignment/caster/front driveline problems running this setup. the thing drives straight and rides nice.
Old 07-14-2008, 11:26 PM   #12
1972CST
1972CST's Avatar
Did you have to move the front spring mount closer to the bumper? Are the73-87 front springs the same width? Thanks for the pics.
Old 07-14-2008, 11:37 PM   #13
1tonblaze
1tonblaze's Avatar
it looks like me , vtblazer and bigbadchev72 have the tallest blazers in here so far .
Old 07-14-2008, 11:53 PM   #14
bigbadchev72
People know me
nope, they are installed in the stock position front hangers, the only thing i had to do was put the longer shackles in the back of the spring like in the pictures i posted of it to make up for the longer springs, i believe the springs are 2.5" wide as are all aftermarket springs i believe
Old 07-15-2008, 06:00 AM   #15
vtblazer
vtblazer's Avatar
6" Alcans and 42's here, with a set of zero rates on the rear and shackle flips.
36"s to the rock sliders and 22"s of ground clearance under the t-case skid.
*no pics of it sittin' still with the 42's on it so you to see the stance/lift, all the pics are of it twisted up or flopped over...
Old 07-15-2008, 09:57 AM   #16
Yukon Jack
Mechanically Challenged
Yukon Jack's Avatar
Here are a couple pics of my 70 K5 with 4" front Superlift lift springs and the rear is a combination of a 2" block with custom spring perches on a 14 Bolt to level it out. IMO these 4" front springs probably don't measure out to an actual 4" lift - I'd say the have to be closer to 3".
I can't recall the exact height of these tires in the next two pics, I'll have to measure them and then updated this.
And the following are pics while I temporarily have some 35" Super Swamper SSR's on the K5 (they measure closer to 34.5")
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2009 Kawasaki KLR650
2014 Honda CTX700
Yukon Jack is offline   Reply With Quote
Old 07-15-2008, 03:33 PM   #17
epsorenson
epsorenson's Avatar
4" lift, 35" tires
"Some days you're the bug....Some days you're the windshield"
71 Blazer K5
epsorenson is offline   Reply With Quote
Old 07-15-2008, 07:43 PM   #18
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
4" Front springs with home-made 3" lift shackles. 6 " rear springs. 3" body lift. Only 36" tires, for now.
...oh and the most important thing: 8 year old co-pilot!
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 07-15-2008, 10:47 PM   #19
hellrazrblade
Purple People Eater
hellrazrblade's Avatar
~6" suspension lift with 3" body lift sitting on 38" Radial TSL's. This made me realize that I need to take more pics of the truck.
1971 K5 Blazer 396ci/TH400/NP205/Dana 44/GM 12 Bolt/38" TSLs
2004 Chevy 1500 4X2 X-Cab 327ci
hellrazrblade is offline   Reply With Quote
Old 07-16-2008, 12:29 AM   #20
bouncytruck
SKINNY TIRES RULE!
hellrazrblade - It looks like Big Foot is trying to get friendly with your truck.
bouncytruck 1972 K5
Old 07-16-2008, 11:19 AM   #21
fun in dirt
fun in dirt's Avatar
Maybe it's just me..but that looks kind of scary???
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy in progress gasser build https://www.trifive.com/forums/showthread.php?t=173938
'01 2500 Suburban...party wagon
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'07 Classic 1500...DD
Gone but not forgotten:
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 07-17-2008, 06:49 PM   #22
hellrazrblade
Purple People Eater
Didn't you know? He's attracted to iridescent purple.
Old 07-17-2008, 07:32 PM   #23
bigbadchev72
People know me
Care to explain?
Old 07-18-2008, 04:03 PM   #24
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
6'' lift and 35'' tires....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-18-2008, 04:28 PM   #25
Jtrux
I'm a poor spectator
Jtrux's Avatar
Care to explain?
I don't see anything wrong with it, 3/8 is plenty strong for that.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
