Old 07-27-2008, 05:08 PM   #1
TR65
TR65's Avatar
T56 Shifter Location Change
Hey Guys,
I am putting a T56 6-speed in my 65C10. I am keeping the interior stock looking including the bench seat. I want to make it look like I have the stock 4 speed floor shifter. (I have an orginal shifter rod and black knob.) The T56 shifter is located very far back on the transmission and will come up under the seat.
Kiesler Engineering makes a kit that allows you to move the shifter to the "front" position which is really an inspection port and access to the shifter guide and detent plate. The kit is $200 and includes a new shifter. You can DIY it but it is a bit involved.
Here is my experience installing the kit. I hope it can help someone else with the same problem.
Here are some links I found helpful:
http://www.keislerauto.com/index.php...emart&Itemid=7
(This is the Keisler kit)
http://www.ttcautomotive.com/English...vice%20Manuals (The Tremec service manual for the T56)
Use the above manual or a GM unit repair manual for the T56
http://www.thegearbox.org/T56.html (snap ring kit)
http://www.gmhightechperformance.com...ild/index.html (good T56 rebuild article)
http://www.ls1tech.com/forums/showthread.php?t=925032 (another good T56 rebuild article)
http://0174de9.netsolstores.com/inde...PROD&ProdID=58 (another kit I know nothing about)
http://www.clubcobra.com/forums/show...ter+relocation (more on T56 shifter location change)
http://www.popularhotrodding.com/tec...ion/index.html (another T56 rebuild article)
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-27-2008, 05:11 PM   #2
TR65
TR65's Avatar
Re: T56 Shifter Location Change
More pictures
1965 C10 SWB Fleet
Two owner
Old 07-27-2008, 05:18 PM   #3
TR65
TR65's Avatar
More Pictures
1965 C10 SWB Fleet
Two owner
Old 07-27-2008, 05:24 PM   #4
TR65
TR65's Avatar
More Pictures #3
1965 C10 SWB Fleet
Two owner
Old 07-27-2008, 05:26 PM   #5
TR65
TR65's Avatar
More Pictures #4
1965 C10 SWB Fleet
Two owner
Old 07-27-2008, 06:54 PM   #6
swb85
On a budget like Fred Sanford
swb85's Avatar
Great post!!! I've always been curious what it took to change shifter locations. You got lucky if that 5/6 driven gear came off easily, most of them are really hard to remove without chipping teeth......I've had to cut two of them off they were so tight. I assume you're doing an ls series motor?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 07-27-2008, 10:18 PM   #7
TR65
TR65's Avatar
Thanks SWB85,
I guess I was lucky. The 5/6 gear had a little fretting corrosion on the fit so maybe the tolerance was not right on it. I put it back with a locktite product made for that. I probably won't be able to get it off again.
I have a complete 6.0 LS2 drivetrain out of a 2005 SSR.
TR
1965 C10 SWB Fleet
Two owner
Old 07-28-2008, 10:24 AM   #8
swb85
swb85's Avatar
That'll be a really cool truck when you're done, you'll love that LS2. I'm building a nasty 6.0L for my camaro this winter.
Old 02-20-2010, 11:45 PM   #9
TR65
TR65's Avatar
Hey guys,
Time for an update. I got the engine and trans mounted. I have a low hump cab and thus need to mount the tranny as close to the cab floor as possible. To do that I let the shifter housing extend up into the cab. I cut 3-1/2" hole in the cab floor and the shifter housing is 3" so I have 1/4" clear all around.
My aim is for the T56 to look like the original granny gear 4 speed. I got an original shifter rod and fabbed a tang to bolt it to the T56. The original type boot won't fit around the shifter housing so I got a boot for a Kenworth on e-bay.
So you can see where the shifter ended up. A little further back than the original 4 speeds but close. So I am ready to take it back apart to paint the shifter rod. For reference the LS engine is mounted 1" forward of the old 283 and 5/8" higher (oil pan clearance) with the usual 3-4 degree tilt toward the back.
TR
1965 C10 SWB Fleet
Two owner
Old 07-25-2010, 11:31 PM   #10
TR65
TR65's Avatar
Truck is running now. Shifter and tranny work fine. Bit of a long throw with the long shifter rod but thats OK.
TR
1965 C10 SWB Fleet
Two owner
Old 07-25-2010, 11:48 PM   #11
cableguy0
Thats a very good write up. This should be added to the faq and moved over to the new lsx section as well. Nice clean work btw.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-09-2010, 07:06 PM   #12
lrader99
FYI these transmissions are an utter PIA to take apart. let alone trying to slide the entire case back over the shift rail and not knock it out of alignment...Be prepared to try it more than once
lrader99 is offline   Reply With Quote
Old 10-11-2010, 07:47 AM   #13
MB_70
Wow !!!
MB_70 is offline   Reply With Quote
Old 10-15-2010, 11:36 PM   #14
LEEVON
LEEVON's Avatar
Hope you don't mind, I posted this on LS1tech.com. Amazing write-up, hope I get to use it someday soon!
'17 Sierra Regular Cab ~ '15 Challenger R/T Scat Pack 392 ~ '11 Escalade ESV ~ '71 Cheyenne swb ~ '66 Country Sedan ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 10-16-2010, 08:32 PM   #15
raycow
Subscribed.
Ray
raycow is offline   Reply With Quote
Old 10-16-2010, 11:18 PM   #16
ccreddell
ccreddell's Avatar
Sure wish I could buy the new shifter receiver all by itself......
ccreddell is offline   Reply With Quote
Old 10-17-2010, 02:35 PM   #17
TR65
TR65's Avatar
LEEVON Re: T56 Shifter Location Change
Nope, I don't mind, thanks.
ccreddell Re: T56 Shifter Location Change
ccreddell - Call up Keisler, they would probably sell you just the receiver. The problem is that you still need a special shifter, since the bolt pattern is different than the rear one.
raycow Re: T56 Shifter Location Change
Subscribed.
MB_70 Re: T56 Shifter Location Change
Wow !!!
Thanks guys.
I have not had any problems with this set-up and I have 2000+ miles daily driving. I did paint up the shifter rod.
TR
TR
1965 C10 SWB Fleet
Two owner
Old 10-18-2010, 01:54 AM   #18
ccreddell
ccreddell's Avatar
Actually, Im very interested in seeing if I can make an adapter plate and use the Hurst shifter from my MG5. Its pivot point is about 3" higher than all the T-56 shifters, and with the long stick, should make for very short throws.
EDIT: Ive heard that Keisler wont sell any parts of this kit separate.......
Old 10-19-2010, 08:29 PM   #19
TR65
TR65's Avatar
Got it CCRED,
That is a valuable piece. If you were really into it you could machine one using the existing receiver for some of the dimensions.
There was a guy that used to do this mod in his shop and I think he was machining the receiver. He finally stopped answering questions and deleted all his posts about how to do it. Too much hassle.
TR
1965 C10 SWB Fleet
Two owner
Old 10-19-2010, 08:41 PM   #20
ccreddell
ccreddell's Avatar
This is true. And it would allow me to make allowances for possible ball diameter differences and make up for adapter height............
Old 04-04-2011, 11:32 PM   #21
chevy71c10
chevy71c10's Avatar
Nice! Just found this thread on the T-56 swap and plan on installing one in my 71 C10 SWB. I have the tranny but have been really concerned about shifter location, throw, and hump mods to cab. I have a low hump cab and plan on installing late model buckets with center foldable console. Thanks for the great write-up on the shifter mod and I plan on contacting Keisler soon on their kit. Please post more pics of the shifter position to seat if available.
Thanks,
Justin
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904
chevy71c10 is offline   Reply With Quote
Old 04-05-2011, 10:57 PM   #22
TR65
TR65's Avatar
Thanks,
Justin
Thanks Justin. 4000 happy miles later no problems with the tranny or shifter. Here is a better picture with the seat in.
TR
1965 C10 SWB Fleet
Two owner
Old 04-07-2011, 11:53 PM   #23
chevy71c10
chevy71c10's Avatar
Hey TR65, Thanks for the additional picture. Very setup you have going! I may have questions in the future regarding how you setup the hydraulic clutch and pedal assembly, but still aways from that work.
Thanks,
Justin
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Old 04-08-2011, 09:53 PM   #24
TR65
TR65's Avatar
Thanks,
Justin
Justin,
Here is the thread on the hydraulic clutch.
http://67-72chevytrucks.com/vboard/s...d.php?t=300087
Enjoy, TR
1965 C10 SWB Fleet
Two owner
Old 04-24-2012, 08:27 PM   #25
theastronaut
theastronaut's Avatar
TR65, this how-to (well, all of your write-ups really) is extremely well put together, easy to read and understand, and extremely helpful! I'm currently looking for a T56 for my '66 C10 and this will be super helpful when it's time to relocate the shifter. Many thanks for taking the time to carefully document the process! I'm right down the road in Anderson; I'd love to meet you and take a look at you truck sometime!
theastronaut is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
