Old 09-20-2008, 08:15 PM   #1
lolife99
Old Member
lolife99's Avatar
Classic Parts Replacement Dash Pad Install,... (long story)
I recently purchased a replacement "Urethane" 81-87 style dash pad for my crew cab from Classic Parts of America. I didn't want to use a "cap" style replacement and I didn't want to spend the mega bucks for an NOS one,... so I thought this would work. The idea sounds like a good one. Urethane material with the color dyed all the way through. Soft so it won't crack,... and no dye to peel off or fade.
I purchased dash pad part #30-823R and a new dash moulding part#32-060. I already had 2 new vents from GM. OK,... now for the bad. This thing is too flexible. It's like trying to install a "noodle" and making it look flat and straight. (I think I could bend it into a "U-shape" if I wanted to) If the metal underneath the dash was completely flat, it would work perfect. But it's not. First you have to dig the urethane out of the slots for the dash clips. (Also cut the extra blobs of urethane off in the general clip area) The repop dash panel moulding appeared to be too long,... even though it was the same length as my original. (see the pics where it hangs off the end) The clips pull down on the pad,... but everything underneath pushes up on the pad. This ends up with the dash being somewhat wavy across the top. I did the best I could do. My truck only has the 2 smaller speakers out by the edges. I have no speaker in the middle. Guess where the dash sags down? Right in the middle. It's in. It looks better than my old cracked one. Next time I will dye an original. Glad I didn't buy two. (I need one for my '86 also) Heres' some pics.
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 09-20-2008, 08:18 PM   #2
pcmcobra
pcmcobra's Avatar
Re: Classic Parts Replacement Dash Pad Install,... (long story)
ya, can see some waves, but from the pics, does not look too bad.
1986 C10 SWB 6.0/4L80e
2010 GMC Sierra CC
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 09-20-2008, 09:07 PM   #3
LMDGUY
LMDGUY's Avatar
could you have put something in the middle to keep it from sagging? looks goo other wards
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 09-20-2008, 09:18 PM   #4
lolife99
Old Member
lolife99's Avatar
I think when I replace the stock stereo and speakers I will fix it.
Keith
Old 09-20-2008, 09:31 PM   #5
rod86
great southern land
rod86's Avatar
yea u could maybe try put a length of fiberboard/mdf under it for support?
dosnt look too bad but..
rod
86 chevy c10 silverado
rod86 is offline   Reply With Quote
Old 09-20-2008, 09:55 PM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Is it the "Urethane" 81-87 version that comes with a board in the middle of it? If so, there isn't any metal in it, it is all molded Urethane. I have those for like $200 + shipping and they aren't advertised because well, I wouldn't put them on my truck. The 73-80 version isn't any better.
The company that makes them have a skinned vinyl version that is MUCH better.... I have those too, but they only come in Black and Blue.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD)
Captkaos Customs
Old 09-20-2008, 09:56 PM   #7
bigblock73
yeller
bigblock73's Avatar
I purchased one a while back too...experienced the same problems. I was very unhappy and sold it. I will only use GM dash pads for our trucks.
Didn't I sell you a brown 81+ pad?
bigblock73 is offline   Reply With Quote
Old 09-20-2008, 10:17 PM   #8
lolife99
Old Member
lolife99's Avatar
Yeah Jeff,... I still have it. I'm saving it. Captkaos,...I guess I should have asked on the board first. You are correct. It comes in a triangle shaped box and when you open it it has a 1x2 board screwed to it to keep it straight, I guess. When I went to the All Truck Nats I stopped by Classic Parts. The one on the shelf looked nice. So since I was there I decided to save some freight. It was $224. Live and learn. I guess that's what I get for impulse buying. Ha. I wouldn't put it in a show truck but it's much better than those stupid caps or my old cracked one. How much for the "skinned vinyl" version?
Keith
Old 09-20-2008, 10:19 PM   #9
wildmanaaron
I have one of the Vinyl ones also. The replacement dashes are made by Dashes Direct/Universal Urethane out of Las Vegas.
FYI-The arm rest pads that Dashes Direct/Universal Urethane makes are NOT made of vinyl and they do not make any in vinyl. The urethane parts CAN NOT be dyed successfully so make sure you check that before ordering something only to find out it won't take paint to match a special interior color that you are using.
wildmanaaron is offline   Reply With Quote
Old 09-20-2008, 10:32 PM   #10
andresco50
andresco50's Avatar
Check mine man. I reupholstered the dash pad with a kind of vinyl like Ultra-Leather you'll love the finish.. I only used bondo to fix the cracks.
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 09-20-2008, 10:40 PM   #11
lolife99
Old Member
lolife99's Avatar
Looks nice!
Keith
Old 09-20-2008, 10:43 PM   #12
ChaseDale3and8
ChaseDale3and8's Avatar
Here is what I feel is a better alternative to any repop. Check this site out: http://www.justdashes.com/Products.htm I'm not sure what they charge to do it, but this company can restore your original GM dash to better than new condition with original colors and grain patterns.
This is the route that I plan to take when the time comes to redo mine rather than try to track down a good used original GM dashpad to either dye, or fork out even more for a new GM one that may need to be dyed my color anyway. Thought that I'd pass this along as another alternative. Even if it costs a little more to go this route, it sure beats one of those ill fitting repops in my opinion. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 09-21-2008, 12:44 AM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Even though the product was lacking in function, it definintely looks better than the original cracked dash. Nice work Keith!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-21-2008, 02:14 AM   #14
Captkaos
Captkaos's Avatar
Just dashes charges about $500 (last I knew) for a dash.
For the people I know of that got them from there they said they are great.
BUT, I sell OEM GM dashes for 81-91's for $355 + shipping.
It is $225 for the "skinned" vinyl dashes...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 09-21-2008, 09:16 AM   #15
Red_69
Red_69's Avatar
I bought one of those and promptly called them to let them know it was coming back. You need an archeologist to dig out where the screws go and the part above the gauges was saggier than a nursing home pool party. You made it look nice by the way, but I thought $200 plus was too much to pay for something I had to "customize". I ended up getting a perfect one from a buddy and dying it.
1986 Chevy 3/4 Ton 4X4
Red_69 is offline   Reply With Quote
Old 09-21-2008, 09:47 AM   #16
lolife99
Old Member
lolife99's Avatar
I should have sent it back. But I thought how hard could it be? I'll fix the center by the speaker. Also the repop dash bezel had issues. The plastic studs were a little shorter. The speed nuts that hold it on just barely grip them. I don't know if the urethane dash is thicker in this area or what the problem is. It was a b*tch to install the a/c vent pieces behind it.
Keith
Old 09-22-2008, 02:06 PM   #17
nico
nico's Avatar
I had similar problems... After months of research, I purchased a brown replacement dash from Cheyenne Pickup (believed to be the best reproduction). I personally took it back to the factory, who admitted that it was molded incorrectly. They offered me a black one and said they could still sell the faulty one for $150 at a swap meet... I was shocked they would intentionally sell junk.
I then purchased a NOS GM dash from GMPartsdirect... The one I received after several weeks wait looked like it had been crushed. There were multiple dimples and depressions in the top of the dash. They took it back, no questions asked and now I have a third dash ready for installation. It only took three months and cost three times what a plastic cover would have, not counting $60 worth of Dupont dye.
nico is offline   Reply With Quote
Old 09-22-2008, 04:44 PM   #18
AceX
>130dB Moderator
AceX's Avatar
I just replaced mine. I leaned my lesson earlier and dropped some serious money on a new one. $550 later and a few modifications, the dash looks amazing...
www.classicindustries.com
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 09-23-2008, 09:03 PM   #19
bowtiecb
bowtiecb's Avatar
how did you get it to lay down and not wrinkle where the dash hump is
bowtiecb is offline   Reply With Quote
Old 09-23-2008, 11:17 PM   #20
andresco50
andresco50's Avatar
I spent 30$ on mine
2001 silverado 2wd
2003 silverado 4wd
Old 04-25-2009, 07:13 PM   #21
trenchwarfare
What exactly did you use and where'd you get it?
____________________________________
trenchwarfare is offline   Reply With Quote
Old 04-25-2009, 09:02 PM   #22
slugish
Slugish
cHRIS > What is a skinned vinyl dash pad
do you have one in a med. or charcoal gray
If you dont can a skinned pad be dyed or painted .
As you maty know Ihave been trying to sell my black dashes direct pad (urathane ) changed my mind on color & kept it too long to return it . Called sem & they daid it could be painted but not wiythout spending a nother hundred or so in prep materials & still not knowing how it will turn out .
slugish is offline   Reply With Quote
Old 04-25-2009, 10:37 PM   #23
SBTork
Garage wrench
SBTork's Avatar
$355 for a new GM one is a good price. It's a lot for what it is, just a dash pad, but they're just about the best you can buy.
-Adam
85 C10 Suburban 5.3 / 4L60E on air, three season DD, rockin the southern GA patina.....
01 Saturn SL1 stock DD.....
83 K5 Blazer awaiting a 4.8 swap.....
SBTork is offline   Reply With Quote
Old 04-26-2009, 12:38 PM   #24
Captkaos
Captkaos's Avatar
Skinned vinyl dash is one that is made like the factory with skinned vinyl.
The aftermarket ones only come in Blue or Black.
I have painted them without any issues.
Factory GM dashes that I sell ONLY come in grey (as pictured on my site) When they replaced them at the dealership the painted them to match the interior of the truck it was going in. It would be just like painting a used dash to match.
If you have the rubbery urethane version, there is NO WAY you can paint it and it stick, trust me...
In perspective that isn't THAT bad a price, they aren't just about the best you can buy, they are the best, they are GM dashes new in the box. In perspective, the aftermarket ones I have cost $265 + shipping.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-26-2009, 04:52 PM   #25
OrangeAnimal
OrangeAnimal's Avatar
I got the urethane dash pad as wel what a PITA to get installed and it still doesn't look right. I used a die grinder with sanding wheels on it to trim it down in places and could never get it just right. I was not impressed in the slightest bit with the fitment. I spent about 4 hours working with it and it just doesn't fit good. There is not much I can do about it.
But.... It looks way better than a cracked up piece of crap dash that already had one of those caps on it and that was cracking too LOL.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
