Old 09-28-2008, 09:20 PM   #1
Jtrux
I'm a poor spectator
Jtrux's Avatar
1972 GMC 3/4 ton rear axle ????
A friend of mine (72LEVI) picked up a 72 3/4 ton GMC with a Dana rear axle. My question is, which one is it, a 60, 70 or ??? I don't know them a part by looking at them. Also I always hear of 3.54 gears in these axles, are those the only ones they came with?? Are they worth keeping in a truck?? If it's a 60 or 70 it should have lots of aftermarket support right??
Thanks.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-28-2008, 11:45 PM   #2
hdflstf
hdflstf's Avatar
Re: 1972 GMC 3/4 ton rear axle ????
Should be stamped on one of the webs as viewed from the rear.
hdflstf is offline   Reply With Quote
Old 09-28-2008, 11:57 PM   #3
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Being a GMC it should be a leaf sprung Dana 60. 3:54 cogs is all I have ever seen but I am sure there were other gear ratios available.
DirtyLarry is offline   Reply With Quote
Old 09-29-2008, 12:06 AM   #4
72Levi
Active Member
72Levi's Avatar
I might need to jack it up and turn wheels, mark driveshaft, etc... Jtrux is right its a Dana and other guys tell me its a 3.54 but Longhorn Man says it has rear suspension mods and most likely used as tow rig. The gears may have been changed, i will look. The leaf springs looked modded and it even has coils on shocks. See parts section, I am thinking Dana 60.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum
2004 FORD FX4 SuperCrew
2005 CTS-V 12 sec family car
2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it!
72Levi is offline   Reply With Quote
Old 09-29-2008, 05:49 AM   #5
You`d know a Dana70 from a D60 if you saw one.That would be a way big rear.Like comparing a D44 front to a D60 front.The D60 came in the lower 4.10 and 4.56 as well.You hear alot about the 3.54 because it`s unusual for back then and great for today`s needs.Was that a big block originally?I saw the pics you sent,nice truck for the money,and noticed a later small block was dropped in and it has alot of options.The 1/2t big blocks trucks with automatics only came with 3.08s.I`d assume a big block/auto 3/4t would only come w/3.54.
You`ll find a "60",as mentioned,on the lower web in the center section.
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
"Don't call me a rough cut country gentleman. I'm just a redneck"
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 09-29-2008, 06:01 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
tim, if you look at the photoi, it's a 3/4 ton (no 3.08 gears) and the truck has the remote power steering deal.
Old 09-29-2008, 06:33 AM   #7
Gotcha,but I already knew that and it shows in my post.I only mentioned the 1/2t BBC ratio as part of my reasoning for assuming it would be 3.54s "if" it was in fact a BBC originally.
Old 09-29-2008, 03:31 PM   #8
Longhorn Man
my bad man... I was scanning posts quickly before work.
Old 09-29-2008, 03:39 PM   #9
CPNE
Resident Curmudgeon
CPNE's Avatar
If that truck was originally a BB with a 4 speed transmission, it was probably a 4:10 (4:11) ratio. That's how my 72 Chevy longhorn BB was configured, with not option on spid IIRC. Granted mine was a 1 ton SRW so your mileage mary vary.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-29-2008, 04:55 PM   #10
dfosh
I dont want to hijack , but i have the same problem .68 gmc 1/2 ton 250 six
im sure its a dana it has 354 gear. But i don't know which dana ? can someone post pictures of the different ones . My spid is gone .
dfosh is offline   Reply With Quote
Old 09-29-2008, 05:12 PM   #11
jamie72
jamie72's Avatar
gettin old...bud
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 09-29-2008, 05:20 PM   #12
Dooley
Dooley's Avatar
My 72 GMC (model noted as "wideside pickup" on title), 402 BB/T400 equipped C 3500 pickup had 3.73 Eaton rear gear. This was a special order truck with factory tach, spotlight, passenger side underbed toolbox, drivers side underbed fuel tank, rear overload springs and was a 8.5' bed. It was Fleet yellow with black interior. I had owned a 69 C20, 396/T400 Longhorn previous to this truck.
Dooley is offline   Reply With Quote
Old 09-29-2008, 07:54 PM   #13
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
3.54 Dana 60; yes there's some lube on the inside as well. At one time, it had a metal tag with 3.54 stamped on it.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 327-4 speed LWB C20; grandpa bought it for the farm in '71.
DD '01 Grand Cherokee Valdez
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
hounddogs! is offline   Reply With Quote
Old 09-29-2008, 08:51 PM   #14
Longhorn Man
3.54 was the standard gear on all big block 3/4 tons, 3 speed, 4 speed, or auto. It was not even avalible on one tons.
Dooley, do you have a spid showing your 3.73 gear? Or was that simply what you found in yours? Now granted, yours is a GMC, and there is little to no documentation on them, but chevy doesn't show 3/73 anywhere for any 3/4 or one ton trucks at all in the 67 - 72years.
dfosh, can you show a pic of your diff? If it's a dana, it should be a 60 (assuming 2 wheel drive here) and I've only heard of one 3.54 that was not in a big block truck... claimed to be original (a respected member, the ONLY reason I believe it is true)
Old 09-29-2008, 09:03 PM   #15
factorystock
factorystock's Avatar
For some reason, Chevy never offered the 3.73 ratio on the C-20 Dana 60 3/4 tons between 68-72, while Dodge and Ford used this ratio in their Dana 60 3/4 tons.
factorystock is offline   Reply With Quote
Old 09-29-2008, 10:13 PM   #16
1969 GMC
1969 GMC's Avatar
our trucks never got dana 70's, either. to visually id a 60 from a 70, the lip on the casting sticks farther down past the diff cover on a 70 than the 60, if for some reason you can't see or find any numbers.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-29-2008, 10:32 PM   #17
My`72 K2500 has 3.54s and a 350.There were 1/2t Dana60s in some GMCs.
Andy,no problem.I hope I didn`t come off wrong there.Besides,it`s not like I make sense all the time.We should get together and check out rears sometime.
Old 09-29-2008, 10:35 PM   #18
Longhorn Man
OK, 2 ppl that I trust about these trucks that have 3.54 rears in non big block trucks.
Old 09-29-2008, 11:20 PM   #19
To your credit,I always thought they were 3.73s until you told me GMC didn`t offer that and did offer 3.54s.I never knew that.I checked mine and there they were.So,if you hadn`t corrected me you`d be right.(now,about what I said about me not making sense sometimes)
Old 09-30-2008, 08:50 AM   #20
dfosh
I will post pic tommrow night . My son will have to do it for me . I did look at it again after seeing the above pic. Mine had a 4 on the web maybe a 44 as i could not make out the second # .tag on the cover was 46-13 3.54 . It also still had the paper sticker around the axel tube next to the backing plate .It was covred in dirt kinda brittle when i was cleaning .Number on it was 3903540 . Hope it showes in the pic when i post them. This truck was from the person that bought it new .
Old 09-30-2008, 10:58 AM   #21
hounddogs!
hounddogs!'s Avatar
46 and 13 are the tooth counts on the ring and pinion, respectively.
46/13 = 3.538 or your 3.54:1 ratio.
Old 09-30-2008, 01:03 PM   #22
DirtyLarry
DirtyLarry's Avatar
3:54 definitely was the standard gear as Longhorn man stated. Come to think of it I have never owned a single 67-72 two wheel drive that didn’t have 3:54 gears… Here is a few of the junk I have owned or still own.
1968 GMC C1500 305 V6/SM435 Dana 44 3:54 (parted). This truck’s rear axle is temporarily in my other ’68 GMC when the Dana 60 broke.
1968 GMC C1500 396BB/TH400 Dana 60(semi-floater: Rare) 3:54 (still have) Still have the broken semi-float Dana 60 as well. Something about those hard 1-2 TH400 shifts will a full race shift kit that tends to knock teeth off ring gears
1970 Chevy C10 402BB/SM465 Dana 44 3:54 (sold)
1972 Chevy C20 350/TH350 Eaton not sure of the gear ratio but the highway RPM’s are consistent of 3:54 (still have). I’ll have to chisel off the axle grime and look for a tag someday.
1972 K5 Blazer 3:73....4x4's were a different ball of gear wax anyway.
Old 01-03-2017, 01:04 PM   #23
Travisarmenta
Back from the dead,
sooooo a 3/4 ton 2WD GMC Burb with a BB402/TH400 should have a Dana 60 with Leaf springs? or Coils?
Travisarmenta is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
