Old 11-05-2008, 01:54 PM   #1
steverino66
visor dimensions?
Anybody know if visors/mounts from a 67-72 truck will fit a 66?
I have nothing but 1 bare driver's side arm, can't find dimensions of whole visors anywhere.
steverino66 is offline   Reply With Quote
Old 11-05-2008, 03:59 PM   #2
502tripower
502tripower's Avatar
Re: visor dimensions?
I am not sure if the 67-72 visor will work but, the dimentions on the 60-66 visor are 21-7/8" X 6-1/4". I am including some pics as well. Hope this helps. Good Luck.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 11-05-2008, 04:55 PM   #3
steverino66
Thanks, 502-
I can't see enough difference to worry about in the pics - if no one knows for sure I'll probably just buy the ones on the parts side I'm looking at.
BTW - your engine avatar is amazing - one of several here that make me realize how much work my engine bay needs! (just test-fitting/connecting the 454 now)
Old 11-06-2008, 09:10 PM   #4
ConnDemned
the part that mounts to your inner roof is different, not by much. I think I just bent the mounting area to work for the time being, one is flatter than the other if I remember correctly. I also want to say that the inside edge hits the roof of the truck, which could be a problem with the bending of the "flange" either way I'd try to get the proper ones if you could.
ConnDemned is offline   Reply With Quote
Old 11-07-2008, 01:14 AM   #5
502tripower
Originally Posted by steverino66 View Post
Thanks, 502-
As ConnDemned said, I think if you can find the correct visors you would be happier and Thanks. Good Luck
98' FXD
2002 2500HD
Old 11-07-2008, 11:28 AM   #6
jason65
Registerd User
jason65's Avatar
LMC sells them and they are not expencive. You can get them in 6 or 8 different colors. The rod is sold seperate from the visor.
jason65 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
