Old 11-05-2008, 01:54 PM   #1
nyncompute
nyncompute's Avatar
Tallest skinniest tire for 8x15 inch rim
I have a stock height 4x4 and I like the look of tall thin tires. As the post says, I need to know what tall / thin tires are made for a 15 inch rim. I now have 31 inch tires that are , I believe, 10.5 inches wide. I like the height but not the width. Some of the 16 inchers look great to me but the 15 inch selection leaves a little to be desired. Thoughts?
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 11-05-2008, 03:15 PM   #2
mekdad
mekdad's Avatar
Re: Tallest skinniest tire for 8x15 inch rim
33x9.50 dont know if they are 15 or 16
you never know what you can do until you have to undo something you have done!
mekdad is offline   Reply With Quote
Old 11-05-2008, 03:42 PM   #3
d10s69c10
Built 4 Speed
d10s69c10's Avatar
theres a whole lot of options tire wise.... Super swamper LTBs are designed to be tall and thin..
are you leaving the truck stock? or are you lifting it..
stock i think you will be stuck somewhere around a 32"inch tall by a 9-10.5 (9 is kinda pushing it on a 8 inch rim tho)
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 11-05-2008, 04:12 PM   #4
Dooley
Dooley's Avatar
Interco has a
34/9.50-15LT Bias ply 33.80" diameter
9.50"section width
8" tread width
GM used to offer 16" wheels as an option for 6 lug half tons. Maybe locate a set of them for more tire options. Not much help from pic but, I like the 255/85-16's on my 86 with no lift. The rims are 6.75 wide.
Dooley is offline   Reply With Quote
Old 11-05-2008, 05:29 PM   #5
nyncompute
nyncompute's Avatar
I should modify my post to say I need to stuff them under stock height (no lift planned. This is an old pic of my truck. Like I said I like the tallness of it but not the width.
Old 11-06-2008, 11:24 AM   #6
1-tonmudder
Modern day Fred Sanford
1-tonmudder's Avatar
38/11/15 TSL boggers.I had a set of the 34/9/16 TSL's one time and they worked good.
EDIT,sorry I missed the stock height part.
1-tonmudder is offline   Reply With Quote
Old 11-06-2008, 12:43 PM   #7
1969K10
1969K10's Avatar
my truck is supposed to be stock, but i've got (2) extra springs on the front from what i think i've learned. I'm running 33X10.5 BFG AT's.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 11-09-2008, 09:48 PM   #8
msgross
msgross's Avatar
Mine is stock in this pic with HD front 1/2ton springs (stock) and 33x10.5x15 BFG AT's on 8x15 Mickey Thompson Classic II's.
The pics with the new bed have a 1.5" add-a-leaf and no weight on the truck...
I think they work great and like them... no rubbing.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-10-2008, 12:09 AM   #9
jrdv
jrdv's Avatar
This is my 69.. I had the local tire shop order some new steele 16 inch wheels and the tires are a 235/85/16. It has a 4 inch lift.
jrdv is offline   Reply With Quote
Old 11-11-2008, 10:02 PM   #10
nyncompute
nyncompute's Avatar
Hey JRDV can your rims accept dog dish hub caps?? If so where did you buy the rims and , if you don't mind... cost
Old 11-11-2008, 10:09 PM   #11
jrdv
jrdv's Avatar
I have some 70's chevy dogdish hubcaps on it right now. I will get you a picture in the next day or two. I think the rims were around $90 a piece, but I will have to dig around to find out. If my local dealer can get them, any dealer should be able too ( I live in the boonies ). I will post some pics later.
john
Old 11-11-2008, 10:56 PM   #12
nyncompute
nyncompute's Avatar
john
Thanks for the pics. I hate to be a pita, but if you can... a manufacturer and/or part#
Old 11-11-2008, 11:19 PM   #13
jrdv
jrdv's Avatar
No problem. I will see what I can find.
john
Old 11-12-2008, 08:35 AM   #14
OLDCHEV4X4
OLDCHEV4X4's Avatar
The 34 /9.50 go on a 6 or 7" rim. I think 8" is too wide. With no lift and 8" rims, i would go with a 33 10.50. (they recomend a 7" for this size, but a 8" would do.)
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 11-12-2008, 01:37 PM   #15
jrdv
jrdv's Avatar
Here are some quick pictures. The rims don't have a maker on them,and there is no part number.
Stamped on Rim: USA MADE 16X6 DOT........ HEAVY
Old 11-12-2008, 03:12 PM   #16
nyncompute
nyncompute's Avatar
Thanks... looks great! I'll see what I can find out.
Old 11-13-2008, 09:19 AM   #17
In 15s I`d say there are BFG M/Ts in 9.50/33.In 16" you can go to BFG M/T 255/85s.I`m not sure if Maxxis still makes Q78 Buckshot Mudders.
Here`s my`92 with 255/85s on newer trucks with stock rims.I can only find them in BFG M/Ts,now:
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
"Don't call me a rough cut country gentleman. I'm just a redneck"
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 11-13-2008, 12:52 PM   #18
OLDCHEV4X4
OLDCHEV4X4's Avatar
Tim, The Q-78-15 is a 36" tall tire. I think you mean a P-78-15. That is a 33" 10.50 /15. Gateway/Buckshot still makes them. Thats what i run on the race truck. But they are biasply and dont have very good road manners.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 11-14-2008, 08:42 AM   #19
O K I C.We used to run 9.00-16s.I think they were 34".You "could" run w/no lift w/stock wheels and taking it easy.My unlifted trucks have always had some sort of spring work and would sit up an inch or two,plus not flex as much.
Old 11-14-2008, 10:21 AM   #20
nyncompute
nyncompute's Avatar
So how careful do you think I would have be running a 33" tire at say 10 or so inches of width at bone stock height.
Old 11-14-2008, 10:35 AM   #21
msgross
msgross's Avatar
Originally Posted by nyncompute View Post
So how aggressive do you think I could be with a 33" tire at say 10 or so inches of width at bone stock hight.
That's what mine is and although I haven't taken it our yet, I would think that only in turns on a landing you would encounter any rubbing. I tried wider rims but they would have rubbed. and 12.5's would more than likely rub easily...
If you saw issues you could easily install an add-a-leaf or zero rate leaf to assist...
The Garage:
Old 11-15-2008, 01:09 PM   #22
That should be fine.I have 12.50/33s on 8.25" wide wheels mounted on my unlifted`72 K3500.It`s even lower than stock and they clear for normal driving.
Old 11-15-2008, 08:52 PM   #23
1tonblaze
1tonblaze's Avatar
my buddys dad has 33 12.50 15 on truck rallys the later model ones and he has no rubbing problems at all .
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires
1972 nova plane jane 6 clyinder might sell might keep dont know
2004 chevy s-10 crewcab zr5 sold
1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me
2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went .
1999 k1500 suburban 350 vortec 4l60e leather land yacht .
1tonblaze is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
