Old 11-23-2008, 04:08 PM   #1
hardwaa
hardwaa's Avatar
1966 Chevy SWB Gasser influenced truck
Hi my name is Jeff and this is my truck. Bought 12-24-07 got it home, washed it up and got it running.
hardwaa is offline   Reply With Quote
Old 11-23-2008, 04:15 PM   #2
hardwaa
hardwaa's Avatar
Re: 1966 Chevy SWB Gasser influenced truck
Put a tailgait on it some new chrome bumpers. Basically wanted to get it driver friendly before I started to really work on it. One thing I have learned if you can drive it and work on it you enjoy it and if I cant drive it I always sell it Sorry for pic quality cell phone pic
Old 11-23-2008, 04:22 PM   #3
Cyclone
Cyclone's Avatar
Nice truck!
Saw this Gasser/racer @ the Cow Palace a few years back.
Cyclone is offline   Reply With Quote
Old 11-23-2008, 04:38 PM   #4
hardwaa
hardwaa's Avatar
Ok time to make it MINE.
5 lug conversion FRONT: 73-87 A arms, 2.5 dropped spindles, 4" dropped springs, new rotors, bearings, calipers, hosses, and lines.
REAR stock axles and drums machined for 5 lug. 5"dropped springs.
POWER BRAKES 1972 chevy truck booster master and firewall bracket.
Wheels Front old Sears mags 15x6-5.60 coker classics biasply. Rear Cragar 15x8-10x30 Hurst recapped cheater slicks.
Side note 4 85lb bags of concrete and 2 50lb bags of sand in front of tailgait to help lower rear first time out 4-13-08
Old 11-23-2008, 04:49 PM   #5
Corts60
Corts60's Avatar
Nice. Now it's time to get that straight axle in the front to finish off the stance....
1978 Chevy Silverado 5.7 Diesel/turbo 400/GV overdrive/3:73 posi
1993 Chevy Silverado 4.3L/Getrag MM5/3.42 gears
Old threadhttp://67-72chevytrucks.com/vboard/s...1978+silverado
New threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=650751
Old 11-23-2008, 04:54 PM   #6
hardwaa
hardwaa's Avatar
Big thrash before Goodguys 08. found a set of 15x6 Cragars for front. removed concrete and sand bags from bed and replaced with 2" blocks and C notched rear frame. New winshield and rear window rubbers. tinted rear window YELLOW. Replaced drivers side rocker and front fender panel( it is screwed on over fender and tacked on bottom done at 0130 AM Friday morning before show lower fender is full of bondo)
washed and all cleaned up for Goodguys 08
Old 11-23-2008, 05:07 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
Cool man, started a thread!!!!! Looks like you started with a fairly nice truck, too. All that concrete and sand really helps with the traction in the winter months.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-23-2008, 05:09 PM   #8
hardwaa
hardwaa's Avatar
Future plans Next weekend put my dropmeber in followed by a Turbo 350 trans, shifter on the column.The 292 6 is stayin it runs great and does not leak or use oil. Bag rear install narrower rear end do whatever it taks to get back down more. RIGHT NATE. Also mount gas tank under bed and install raised metal bed floor. I would also like to paint over primer and tailgait (blend in greenstock color) Then drive the F OUT OF IT.
Hopefully MARCH MEET 09
Old 11-23-2008, 05:17 PM   #9
protrash64
protrash64's Avatar
What is March Meet? The only thing I see wrong is that Ford sign in your picture...
Old 11-23-2008, 05:30 PM   #10
Rogue
Airport Bum
Your going the wrong way for Gasser influence.
Lift the front 6 inches with a solid axle and parallel leafs.
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 11-23-2008, 05:53 PM   #11
Dinos63
chevy only
Dinos63's Avatar
I saw your truck at goodguys, very cool nice job .you will love the dropmember
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 11-23-2008, 05:58 PM   #12
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
HOLY CRAP!!! that GMC is so perfect....my chevy is almost its twin
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 11-23-2008, 07:07 PM   #13
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Nice truck, dude. I like the look
-- Will
killthewabbit is offline   Reply With Quote
Old 11-23-2008, 11:10 PM   #14
fchava
fchava's Avatar
so you have 6.5" of static drop in the front? Wow. How close to the ground are the a arms. Nice truck!
fchava is offline   Reply With Quote
Old 11-24-2008, 12:04 AM   #15
Slmd92DIME
Slmd92DIME's Avatar
I like your truck a lot. Looks a whole lot better
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 11-24-2008, 10:52 AM   #16
jchav62
1962 C-10
jchav62's Avatar
Awesome truck! I love everything about it. Those cragars are killer!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
2003 Silverado 2500HD LB7 Duramax
jchav62 is offline   Reply With Quote
Old 11-24-2008, 12:57 PM   #17
stepside454
stepside454's Avatar
cool truck, but thats not at all what Id call a gasser style. That pic Rogus posted was a gasser style. That look is hard to pull off & look right with trucks in my opinion...just my 2cents
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 11-24-2008, 01:15 PM   #18
kizer
Its Deja Vu time again
kizer's Avatar
Still really nice thou.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 11-25-2008, 01:02 AM   #19
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Nice looking truck!
2010 CHEVY Silverado Crew Cab
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
1995 Buick Roadmaster LT1, 4L60-E
1990 CHEVY EXT.CAB 350, 700-R4 (R.I.P)
1966 CHEVY Lwb, 1992 350, VORTEC HEADS, 650 Edelbrock Carb, 350/350 Cam, Long Tube Headers, 30 Series Flowmasters... 4L60..
CHEVY ONLY TEXAS
gulfcoast66 is offline   Reply With Quote
Old 11-25-2008, 08:18 AM   #20
502tripower
502tripower's Avatar
Very nice looking truck...Looks like you went for the commit scrub in the clean up stage...
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 11-25-2008, 09:12 AM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
What a great looking project, can't wait to see it with the dropmember installed.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-25-2008, 09:14 AM   #22
jason65
Registerd User
jason65's Avatar
I like the direction this thing is going.
jason65 is offline   Reply With Quote
Old 11-25-2008, 09:21 AM   #23
lolife99
Old Member
lolife99's Avatar
VERY nice! I didn't look at this thread because I was expecting to see a straight axle. I'm glad you are going in the "Dropmember" direction. Looks more like a 60's tow vehicle. Keep us posted.
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 11-26-2008, 02:03 AM   #24
joeys66pickup
Dr. Frankenstein
whats wrong with a straight axle? best invention since sliced bread!
I Wanna Go Fast!!
Old 11-26-2008, 08:22 AM   #25
lolife99
Old Member
lolife99's Avatar
They are COOL on 60's Gasser cars,... just not my thing.
Keith
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
