Old 11-24-2008, 09:56 PM   #1
sstpeach
6 cylinder engine decode
Looking to buy an engine from a guy. I'm told its a 65 chevy 230 ci. Can someone please validate the engine code?
3994257
thank you for any information
sstchester
sstpeach is offline   Reply With Quote
Old 11-24-2008, 11:21 PM   #2
tiggamonsta
tiggamonsta's Avatar
Re: 6 cylinder engine decode
According to my LMC catalog the 6 cylinder has a pad on the right side of the engine near the distributer with the engine numbers stamped.
1965 230 CID TA, TE, TG
1965 292 CID UH, UT
tiggamonsta is offline   Reply With Quote
Old 11-25-2008, 08:23 AM   #3
502tripower
502tripower's Avatar
Here are the suffix codes for 1958-1965 inline 6 and V8. Follow the link...
http://www.348-409.com/suffixsb.htm
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 11-26-2008, 05:22 AM   #4
sstpeach
Which to buy: 236 vs 260 6 cylinder
Can anyone offer advice between purchasing a 65 230 vs 260 engine? What's good vs bad between the two. Which has better history etc.
I'm going to back it up with a three speed column shift set up.
thank you!
Old 11-26-2008, 07:24 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Which to buy: 236 vs 260 6 cylinder
thank you!
I think you mean 230 and 250 engine.
Larger displacement is the only real advantage between the two. I'd choose the better deal without worrying about the size so much. Both are smooth runners and very durable.
Kevin -
My Instagram
Old 11-26-2008, 11:55 PM   #6
sstpeach
Yes, I'm sorry I meant 230 and 250.
65 and newer both have side mounts which is what I need. Just looking for a good strong motor to putter the truck for now. I kinda like the idea of going with what came with the truck for now.......
Old 11-29-2008, 07:06 PM   #7
Woogeroo
Talking Re: 6 cylinder engine decode
it seems someone else has had a similar problem with that number on the block :
http://67-72chevytrucks.com/vboard/s...ad.php?t=98969
this guy had that first number 3, turn out to be an 8(the rest is the same) :
http://67-72chevytrucks.com/vboard/s...ad.php?t=65240
Woogeroo is offline   Reply With Quote
Old 11-29-2008, 10:28 PM   #8
ol Curt
Junior Member
ol Curt's Avatar
I agree about the difference being minor. I have had both in the same truck, and could tell little difference between the two.
ol Curt is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
