Old 11-30-2008, 08:50 AM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Where is my 60-66 Chevy or GMC vin number?
I see this question come up alot, so I thought I would do a post with pics on where to find your 60-66 chev/gmc vehicle identification number.
First up is the 60 t0 63 chev and gmc.
The vin is located on the LH drivers door pillar.
Old 11-30-2008, 08:53 AM   #2
jonzcustomshop
1961 crewcab
Re: Where is my 60-66 Chevy or GMC vin number?
Next up is the 64-6
The vin is located on the LH driver door roof rail.
*** 64 gmc vins are located on the "b" pillar in the lh driver door frame***
Last edited by jonzcustomshop; 03-28-2009 at 06:32 PM. Reason: added info, and pic of 64 vin location
Old 11-30-2008, 08:57 AM   #3
jonzcustomshop
1961 crewcab
On all 7 years you can also find the vin number on the left hand frame rail in front of the A arm.
There is also one stamped on the top of the LH frame rail under the cab,
these shots are from my 65 1/2 ton long box.
Notice how they only stamp the year, assembly plant, and the sequential serial # on the frame rail.
the under cab shot is from a 66 frame I have, I have hi-lited where the vin is stamped, it is about 12 inches in front of the left hand rear cab mount on top of the frame rail
***** quoted from lil red 66!*****
"The GMC trucks of the same years, did not have the VIN or any portion of the VIN stamped on the frame, in any place."
Old 11-30-2008, 09:01 AM   #4
jonzcustomshop
1961 crewcab
Here are some vin number decoders:
For Chevrolet) http://www.americanclassic.com/paint.htm
For GMC) http://www.6066gmcguy.org/VinNumber.htm
Old 11-30-2008, 09:05 AM   #5
jonzcustomshop
1961 crewcab
Here is a decoder for Canadian 60-66 chev and gmc trucks:
This did not copy and paste like I wanted.
You can also use this link: http://www.oeltd.net/doc/6066gmc/VINs/gmc-canada.htm
pics of the chev and gmc vin tags are at the bottom of this page.
1960 - 1966 Canadian Chevrolet & GMC VIN
Chevrolet Truck
(1) The first digit indicates the model year
(2) The second digit indicates the body style
(3) The third & fourth digits indicate the series
(4) The fifth & sixth digits indicate the model
(5) The seventh digit indicates whether 4, 6 or 8 cylinder
(6) The remaining numbers indicate the particular truck
(7) The last letter indicates the GVW class
GMC Truck
(3) The third digit indicates GMC Truck
(4) The fourth & fifth digits indicate the series
(5) The sixth & seventh digits indicate the model
(6) The eighth digit indicates whether 4, 6 or 8 cylinder
(7) The remaining numbers indicate the particular truck
(8) The last letter indicates the GVW class
Body Style
C - Conventional Cab
P - Step Van / Package Delivery
L - Short Cab / Low Cab Forward
K - Four Wheel Drive
G - Van (lightweight) GVW Class
A - 6,000 & less
B - 6,001 to 10,000
C - 10,001 to 14,000
D - 14,001 to 16,000
E - 16,001 to 19,500
F - 19,501 to 26,000
G - 26,001 to 33,000
H - 33,001 & over
Model / Series Data
1960 - 1961
Chevrolet GMC Body Wheelbase GVW
C1402 C91402 Flat Face Cowl 115 inches 5200 GVW
C1403 C91403 Cab & Chassis
C1404 C91404 Stepside Pickup
C1405 C91405 Panel
C1434 C91434 Fleetside Pickup
C1503 C91503 Cab & Chassis 127 inches 5000 GVW
C1504 C91504 Stepside Pickup
C1534 C91534 Fleetside Pickup
C2502 C92502 Flat Face Cowl 127 inches 7500 GVW
C2503 C92503 Cab & Chassis
C2504 C92504 Stepside Pickup
C2534 C92534 Fleetside Pickup
1962
C1405 C91405 Panel
C1503 C91503 Cab & Chassis 127 inches 5200 GVW
P1342 P91342 Forward Control Chassis 102 inches 5400 GVW
P1345 P91345 Step Van Panel
P2342 P92342 Forward Control Chassis 104 inches 10000 GVW
P2345 P92345 Step Van Panel
P2542 P92542 Forward Control Chassis 125 inches
P2545 P92545 Step Van Panel
P2642 P92642 Forward Control Chassis 137 inches
P2645 P92645 Step Van Panel
C3602 C93602 Flat Face Cowl 133 inches 10000 GVW
C3603 C93603 Cab & Chassis
C3604 C93604 Stepside Pickup
C3605 C93605 Panel
C4102 C94102 Flat Face Cowl 133 inches 14000 GVW
C4103 C94103 Cab & Chassis
C4302 C94302 Flat Face Cowl 157 inches
C4303 C94303 Cab & Chassis
1963
C1402 C91402 Flat Face Cowl 115 inches 5000 GVW
C1405 C91405 Panel
K1403 K91403 Cab & Chassis 115 inches 5600 GVW
K1404 K91404 Stepside Pickup
K1405 K91405 Panel
K1434 K91434 Fleetside Pickup
K1503 K91503 Cab & Chassis 127 inches 5600 GVW
K1504 K91504 Stepside Pickup
K1534 K91534 Fleetside Pickup
K2503 K92503 Cab & Chassis 127 inches 7600 GVW
K2504 K92504 Stepside Pickup
K2534 K92534 Fleetside Pickup
P2342 P92342 Forward Control Chassis 104 inches 8500 GVW
C3604 C93604 Stepside Pickup 7800 GVW
C3605 C93605 Panel
C3803 C93803 Cab & Chassis 157 inches 10000 GVW
1964
G1205 G91205 Panel Body 90 inches 4850 GVW
C1405 C91405 Panel
K1405 K91405 Panel
P2342 P92342 Forward Control Chassis 104 inches 7000 GVW
P2535 P92585 Forward Control Panel Body 125 inches
P2635 P92685 Forward Control Panel Body 137 inches
C3605 C93605 Panel
1965
G1205 G91275 Panel 90 inches 5000 GVW
G1206 G91276/td> Suburban (Std.)
G1226 g91286 Suburban (Custom)
C1405 C91405 Panel
C1406 C91406 Suburban (Panel Doors)
C1412 C91412 W/S Cowl
C1416 C91416 Suburban (End Gate)
K1405 K91405 Panel
K1406 K91406 Suburban (Panel Doors)
K1416 K91416 Suburban (End Gate)
P1342 P91372 Forward Control Chassis 102 inches 5400 GVW
P1345 P91375 Step Van Panel
C2512 C92512 W/S Cowl
P2342 P92372 Forward Control Chassis 104 inches 7000 GVW
P2345 P92375 Step Van Panel
P2535 P92585 Step Van Panel (Sq. Front) 125 inches
P2542 P92572 Forward Control Chassis
P2545 P92575 Step Van Panel
P2635 P92685 Step Van Panel (Sq. Front) 137 inches
P2642 P92672 Forward Control Chassis
P2645 P92675 Step Van Panel
1966
G1206 G91276 Suburban (Std.)
G1226 G91286 Suburban (Custom)
C1405 C91405 Panel
K1405 K91405 Panel
P1345 P91375 Step Van Panel (Sq. Front)
C3605 C93605 Panel
Engines Available
1960-62
235 -6 Cyl. (std.)
283 - 8 Cyl (opt.)
1963
230 - 6 Cyl (std.)
292 - 6 Cyl (opt.)
283 - 8 Cyl (opt.)
153 - 4 Cyl (P1342/P91342)
1964
153 - 4 Cyl (Std. G1205/G91205 & P1342/P91342)
194 - 6 Cyl (Opt. G1205/G91205)
230 - 6 Cyl (Std.)
292 - 6 Cyl (Opt.)
283 - 8 Cyl (Opt.)
1965
153 - 4 Cyl (Std. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1345/P91375)
230 - 6 Cyl (Opt. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1345/P91375)
230 - 6 Cyl (Std.)
292 - 6 Cyl (Opt.)
283 - 8 Cyl (Opt.)
1966
194 - 6 Cyl (Std. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1335/P91385)
230 - 6 Cyl (Opt. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1335/P91385)
250 - 6 Cyl (Std.)
292 - 6 Cyl (Opt.)
283 - 8 Cyl (Opt.)
327 - 8 Cyl (Opt.)
Option engines were not available on all models
Page last updated:
12/19/2003 00:00:00
Last edited by jonzcustomshop; 11-30-2008 at 09:30 AM. Reason: added info and pics
Old 11-30-2008, 09:26 AM   #6
jonzcustomshop
1961 crewcab
According to the 6066gmcguy the panel and suburban vins are located on the Lh drivers door pillar, roof pillar, rear driver door pillar, or on the footwell by the GVW tag.
I have seen all 3 of the door pillar vin placements, but did not take pics.
If you have some pics to add please do.
Old 11-30-2008, 10:02 AM   #7
willyp
willyp's Avatar
thanks for the info, i was gonna ask this.
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 11-30-2008, 12:37 PM   #8
ol Curt
Junior Member
ol Curt's Avatar
Great Post! Keep up the good work.
ol Curt is offline   Reply With Quote
Old 11-30-2008, 01:02 PM   #9
joe231
joe231's Avatar
excellent thread!
CHEVY ONLY
Old 11-30-2008, 01:38 PM   #10
LILRED66
LILRED66's Avatar
jonzcustomshop:
Thanks for your tireless contribution to this subject. Perhaps this will become a sticky. In any case, you have covered the subject very well and I appreciate your efforts.
PS...you must have had a house full of company over the holidays and decided to "hole-up" on the computer to pass the time. Thanks again for your contribution.
LILRED66 is offline   Reply With Quote
Old 11-30-2008, 01:40 PM   #11
65ShortStep
Great Job!
Maybe one of the mods should sticky this.
65ShortStep is offline   Reply With Quote
Old 12-01-2008, 09:41 PM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Very nice write up !!!
I waved my wand, and have made it STICK !!!
John
What the Heck is that ??
60-66 on FACEBOOK
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
My DOOM Buggy Build
Project 'Z069' LS7 Powered '69 Stingray(Father-n-laws)
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 12-02-2008, 10:57 AM   #13
jchav62
1962 C-10
jchav62's Avatar
Excellent post! Nice work, jon.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
2004 GMC Sierra 2500HD LB7 Duramax/Allison
jchav62 is offline   Reply With Quote
Old 12-08-2008, 05:53 PM   #14
55Series2
Just to point out that GM can be inconsistent, on the '64 Chevy cab I recently asked this question about I found it on the LH rear door pillar, not above the door.
John
Albuquerque, NM
'55 2nd Series 3100
'57 Ford RanchWagon
07 H-D Electraglide UltraClassic
55Series2 is offline   Reply With Quote
Old 12-08-2008, 06:50 PM   #15
jonzcustomshop
1961 crewcab
I am going to check out some 64's at the wrecking yard, I changed the gmc pic to note that 64 gmc is on the rear driver door pillar, and I think that chevy will turn out the same way for 64. I will update as soon as I get a pic.
Old 01-29-2009, 01:26 PM   #16
Joey~AP
TexasBowhunter
Joey~AP's Avatar
I need to find my VIN, bein that I reframed.
Joey~AP is offline   Reply With Quote
Old 02-01-2009, 08:28 PM   #17
2manyprojects
2manyprojects's Avatar
I looked at a 64 Chevy I'm swaping some stuff for, yesterday. It was on the B pillar. I thought it was missing at first.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
2manyprojects is offline   Reply With Quote
Old 02-02-2009, 12:29 AM   #18
LILRED66
LILRED66's Avatar
Here are two of my '64 Chevy C10 cabs and both have the VIN on the underside of the driver side door jamb, roughly in the center of the door opening.
Old 02-13-2009, 05:21 PM   #19
Woogeroo
Everyone who contributed to this thread, thanks.
I've already sent a few folks to this thread who emailed me asking about this very thing.
Good job everyone.
-W
Woogeroo is offline   Reply With Quote
Old 02-28-2009, 12:24 PM   #20
Redline
Redline's Avatar
First Chevy truck, Having trouble with my VIN 3C254S118673..... can someone help me figure this out??
Thanks,
Redline
Redline is offline   Reply With Quote
Old 02-28-2009, 01:44 PM   #21
jonzcustomshop
1961 crewcab
on post # 4 of this thread there is a link to a vin decoder...
yours codes out to a 63 pickup 3/4 ton stlouis,mo. the sequintial # is 118673
Old 02-28-2009, 02:55 PM   #22
Redline
Redline's Avatar
I saw that and did that, but I was trying to code it out with your post 5, and it wasn't making since to me.... Since this truck is dually one done I'm trying to find the VIN on the chassy to see what year it is also... Thanks for your help, I'll keep searching on the frame
Thanks,
Redline
Old 02-28-2009, 05:49 PM   #23
jonzcustomshop
1961 crewcab
ok.. the post # 5 is for canadian trucks only.
if your frame is a 60-66 there should be the vin by the left front A arm, and under the cab on the lh side...
if the frame is a later one, there still should be a vin under the cab on the drivers side... that was pretty much a standard for gm frames, and I have seen quite a few different frames with a vin there.
Old 03-01-2009, 08:44 PM   #24
Redline
Redline's Avatar
I'm glad I joined this forum!! Everybody has been a big help so far just wanted to say thanks....
So I found a number on the driver side frame.... still having trouble figuring it out.... So here it is for some folk a whole lot smarter than me 3829595 9 28 62
Thanks again,
Redline
Old 03-01-2009, 09:48 PM   #25
jonzcustomshop
1961 crewcab
here is what comes up with the decoder... which just confuses it even more
VIN 3829595 9 28 62
Model Year 1963
Chassis (unknown code)
Body Style Panel
Series (unknown code)
Assembly Plant Norwood, OH
Sequential Number 5 9 28 62
Is there any sign of the body being off the frame?
maybe this frame was on a different vehicle... the cab vin, and the frame vin should match....
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
