Old 12-29-2008, 01:40 AM   #1
nuke1
nuke1's Avatar
Adjustable rear trailing arms how-to
ADJUSTABLE REAR TRAILING ARMS HOW-TO
MODS move if needed
I thought i would give a how-to on this. everyone on here has been very inspirational and helping of others. so here is something from me. I wanted to build adjustable trailing arms for a few reasons. i can alter the wheelbase, alignment is easier, and i added ballistic joints that are teflon lined for uninhibited wheel travel in the rear, there is no compression of a bushing. Well on to the build, if there are questions ask away, i will answer to the best of my knowledge, and please forgive me if i made a mistake.
Anyways, the first thing i did was lay down some white poster board on my bench, i taped it down so it would not move. I then traced out the original trailing arm for the angle and pivot points. once i did this i marked out my tubing i was using (2"x3"x3/16") and found where my new angle will be located.
Name:  IMG_5393 (Small).JPG
Once i marked out what and where my new trailing arms would be i proceeded to find the existing angle of the old trailing arms. i then used this angle to determine the pie cut i would need to kick up the rear of the arms. Sorry i did not show a pic of the angle finder.
Name:  IMG_5394 (Small).JPG
What i did now was to take a rachet tie down and squish the two ends together until my desried anlgle was acheived. Once it was acheived i then tack welded in two spots on the top of the cut so it did not move, do not fully weld up yet. and make sure that the arm is still square.
Name:  IMG_5395 (Small).JPG
i then cut the other arm with the same pie cut. once that is done i used the tie down againg to bring that one together, once it is i used C-clamps to clamp them together to make sure that they were the same angle. once this was done i tack welded the outsides of the arms. Then i removed the clamps and tack welded the inside of the arms, all the while making sure they are straight. once this is done i fully welded them up. at the same time, i made a boxing plate for the end of the arm and welded it in too.
Name:  IMG_5397 (Small).JPG
Name:  IMG_5398 (Small).JPG
James
1968 GMC "HAVOC" .
Owner of :FULL THROTTLE CONCEPTS!!!
follow us on facebook, instagram, and youtube.
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
Wife's 72' Chevelle SS: http://67-72chevytrucks.com/vboard/s...=1#post5246230
A 58' chev build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 12-29-2008, 01:55 AM   #2
nuke1
nuke1's Avatar
Re: Adjustable rear trailing arms how-to
Well, i had that end of the arms done for now so on to the other end, because i was using flex joints, i got some DOM tubing threaded to accept my joints, the threads are 1 1/4". the sleeves are 5 inches long. on the end of the sleeves i attached some square solid stock in a cross fashin, this was then welded up to the DOM tubing. i made a plate for the other end of the tubing as well, i cut a hole in it with a hole saw and my drill press. i proceeded to insert the section now into the arm. i drilled four holes in the arm that equates to where the solid stock will be. i left the end of the DOM tubing sticking out 3/16" for welding. i also welded the backside of it, but make sure that you get it square.
Name:  IMG_5400 (Small).JPG
Here it is welded up.
Name:  IMG_5402 (Small).JPG
Now back to the other end. I now needed some extra strength for where the springs and rearend sit. so i cut 2 pieces 3" by 17" in lenght. i then used C- clamps to hold these in place and bend them as needed. they are centered and fully welded all the way around. now all that is left is to drill the holes for the rear differential and spring. the spring hole i am gonna drill a hole on just the top and insert a bushing with threads in it that will be welded to the arm, for the bolt to attach through the top.
Name:  IMG_5404 (Small).JPG
One of the finished top with the joint
Name:  IMG_5405 (Small).JPG
and the final product
Name:  IMG_5403 (Small).JPG
James
1968 GMC "HAVOC" .
Old 12-29-2008, 02:00 AM   #3
nuke1
nuke1's Avatar
Here is a few more pics also, and a list of materials i used.
LIST:
Two 53.5 inch lengths of 2" x 3" x 3/16" tubing
2 Ballistic Joints
11 gauge sheetmetal
2 two 5 " lengths of DOM tubing
that is it, u can use whatever joints you want to, but this is what i did. and make sure you USE A SUFFICIENT WELDER TO DO THIS.
Anyways, thank you and enjoy
JAMES
James
1968 GMC "HAVOC" .
Old 12-29-2008, 02:43 AM   #4
joe231
joe231's Avatar
wow man!
very cool write up!
thanks!
how do you figure they compare to the stock ones, weight wise?
CHEVY ONLY
Old 12-29-2008, 03:09 AM   #5
nuke1
nuke1's Avatar
I will weigh them tomorow for you and let yo know.
James
1968 GMC "HAVOC" .
Old 12-29-2008, 03:18 AM   #6
Frizzle Fry
Frizzle Fry's Avatar
That's sweet man! Great idea!
Frizzle Fry is offline   Reply With Quote
Old 12-29-2008, 03:44 AM   #7
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Very cool and a great way to replace rusted out arms. If you could figure a way to step them and adjust the pinion angle back into spec they would be an awesome alternative to drop block plus arms. The posibilites are really there for this idea. Again.. way cool
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 12-29-2008, 10:42 AM   #8
joe231
joe231's Avatar
cool, thanks!
CHEVY ONLY
Old 12-29-2008, 12:12 PM   #9
Shane
Shane's Avatar
Very very nice write up. Thanks!
Shane is offline   Reply With Quote
Old 12-29-2008, 12:38 PM   #10
SCOTI
SCOTI's Avatar
I was thinking the same thing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-29-2008, 06:56 PM   #11
72hotrodder
THE TOY STORE
72hotrodder's Avatar
is there anyway i can bookmard this thread of something
72hotrodder is offline   Reply With Quote
Old 12-29-2008, 11:13 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
You can subscribe to it through the forum, or you can bookmark it through your browser.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-29-2008, 11:43 PM   #13
protrash64
Resistance is Futile
protrash64's Avatar
What are you doing for the mounts at the front? I noticed that they were cut from the X-member. Nice work, time to go into production!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-30-2008, 12:36 AM   #14
nuke1
nuke1's Avatar
Originally Posted by joe231 View Post
wow man!
very cool write up!
thanks!
Weight wise, i weighed them tonite and they weighed 4 lbs less than the originals, so a savings of 8lbs, although i do not think that is gonna help me much with what i am doing, but every bit counts.
James
James
1968 GMC "HAVOC" .
Old 12-30-2008, 12:38 AM   #15
nuke1
nuke1's Avatar
The mounts on the front are being made from 3/16th steel plate, check my build up of HAVOC and this will explain more, the frame is no where near original any more, as for production, , there is always a possibility,
James
1968 GMC "HAVOC" .
Old 12-30-2008, 12:41 AM   #16
nuke1
nuke1's Avatar
the stepping of the arms would be easy, as for the pinion angle, well that is a different matter, where the arms are connected to the crossmember, is where my adjustability will be, but things can always change, if you had a set ride height in mind, you can set you pinion angle and weld them to match that, just a little more time, but not bad.
James
1968 GMC "HAVOC" .
Old 12-30-2008, 10:45 AM   #17
joe231
joe231's Avatar
thanks for the info
CHEVY ONLY
Old 01-16-2009, 02:03 PM   #18
NPilot1975
NPilot1975's Avatar
Great thread! I may have missed it but what was the actual angle that you used for your pie cut? I would love to build a set of these, although I don't think I would worry about the adjustable end.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 01-16-2009, 04:13 PM   #19
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good! I have to follow this one..
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-19-2009, 02:27 PM   #20
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Iffin I had the equipment and know-how would be making a set for my '67 as well.
How much time & money do you have invested in this? I know the new trailing arms are quite expensive. As far as the adjustable ends where do you find those?
Great write up, thanks for sharing with everyone.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 01-20-2009, 01:27 AM   #21
nuke1
nuke1's Avatar
hey guys, total investment for the control arems with the end links is about 140 dollars as for time about 6 hours, the adjustable ends are from ballistic fabrication and as for the pie cut, i figured out my angle with an angle finder, what you could do is bend a wire the original bend of the arms and now use it for you bend, but you have to use the other side of it, i am not sure that makes sense, i will try to get a pic of what i mean for tomorow night for you , is that ok.
JAMES
James
1968 GMC "HAVOC" .
Old 03-04-2009, 11:26 AM   #22
joe231
joe231's Avatar
Any update on the wire guide?
CHEVY ONLY
Old 03-04-2009, 12:03 PM   #23
nuke1
nuke1's Avatar
i will do it today, sorry for the delay
James
1968 GMC "HAVOC" .
Old 03-04-2009, 12:06 PM   #24
MickMc
MickMc's Avatar
Attachment 415993
Do you have any other pictures of the "on the end of the sleeves i attached some square solid stock in a cross fashin,"?
Maybe a couple of pictures will clear it up for me.
Mick
MickMc is offline   Reply With Quote
Old 03-04-2009, 01:14 PM   #25
SCOTI
SCOTI's Avatar
Mick
Looking @ the pics, it seems that he inseted square solid steel into the end of the sq tubing & plug welded it from each side of the tubing to hold it in place.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
