Old 01-09-2009, 02:30 AM   #1
Thadious
Cummins 4BT in a '47 Chevy
The build that I'm currently working on is a '91 S-10 with a 4.3 V6 / TH700R4 under a '47 3/4 ton Chevy pickup. I've been considering changing the motor to a Cummins 4BT with the same tranny and I'm wondering if anyone has ever tried it or knows what the potential pitfalls of using this engine is?
I know the chassis will support a 350 and that a 350 is about 28" in height and the 4BT is almost 36"... does anyone know if this will be an issue?
Cheers and Thanks,
Ted.
Thadious is offline   Reply With Quote
Old 01-09-2009, 09:29 AM   #2
Lextech
Lextech's Avatar
Re: Cummins 4BT in a '47 Chevy
I am not familiar with diesel engines (I'm assuming it's a diesel)---But, I would be cautious of the weight of the engine and the tremendous torque that the diesel makes. Is the S10 frame and front suspension up to the task?
Jeff
Lextech is offline   Reply With Quote
Old 01-09-2009, 10:13 AM   #3
thirdstreettito
Resident of Here
thirdstreettito's Avatar
http://www.4btswaps.com/forum/index.php
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-09-2009, 02:52 PM   #4
Terraizer
A Cummins 4Bt dry weighs 727LBs nearly double what your 350 chevy weighs. I'am building a 1937 International D-15 pickup on a Cut down 1987 S-10 chassis with a Cummins 4BT and NV4500 but haven't got to mounting engine and trans yet, i do plan to use 3 Gen F body Iroc coils they have a higher spring rate then the S-10 coils. The plan is to get the engine as far off the front axle as i can so it won't steer as heavy. The 4BT is a very large and tall engine, they are also not balanced very well unlike the 6BT's in the dodges so they are noisey and rattle pretty good. If you are building a truck you want very quite inside the 4Bt is not a good choice.
1971 Chevy C-20 2x4 Grandpas old truck soon to be 4wheeldrive
Terraizer is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
