Old 02-06-2009, 06:02 PM   #1
swb85
On a budget like Fred Sanford
swb85's Avatar
370ci LS build-up
This isn’t at all truck related (going in my camaro), but figured you guys would enjoy. Before I start, some specs:
-370ci, 12:1 compression
-LS6 crankshaft
-Clevite H-series coated bearings
-Scat 4340 rods, 6.125” long, bushed for floating pins
-Mahle forged/coated flat top pistons, -4cc reliefs, 436g weight
-custom hydro roller cam, LS7 lifters, Comp 7.375” Hi-Tech pushrods, factory LS rockers
-PRC 220cc cnc ported heads, 57cc chambers, 2.02/1.575 valves, dual springs/titanium retainers (good to .660” lift), flow ~320cfm at .600”
-ported Fast 92mm intake, 92mm PTM throttlebody
-NOS direct port nitrous setup (good for 300 shot)
-42lb injectors/custom rails
Shooting for around 500rwhp on motor and somewhere between 650-750 on spray. On with the build!!
6.0 truck block fresh from the machine shop. Was bored/honed with torque plates to 4.03", decks cleaned up and squared, line bore checked, new cam bearings installed.
Here's the pile-o-parts we're starting with!
After a thorough cleaning of the block, we flip 'er upside down and get to work.
On the motors I build, I like to install the cam first. Easier to guide it through the bearings this way IMO, so it gets thoroughly cleaned and doused in assembly lube (I use Royal Purple assembly lube) and it's ready to stab. The Clevite H-series main bearings are also installed at this time.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 02-06-2009, 06:03 PM   #2
swb85
swb85's Avatar
Re: 370ci LS build-up
The LSx cam is held in place with a retainer plate, similar to sbc roller motors. Cam endplay measured .006", just right.
Here's the freshly polished and balanced LS6 crank being used. The stroke is standard LSx at 3.622".
The bearings are coated in lube, the crank is carefully laid in place and the main caps are torqued to spec. Main bearing clearances were set at .0025", endplay at .005".
Old 02-06-2009, 06:04 PM   #3
swb85
swb85's Avatar
Time for the piston/rod assemblies. This motor will see up to a 200 shot of nitrous, so the top and second compression rings are appropriately gapped to .024" and .028" respectively. The bores/piston skirts are coated in 30wt oil before carefully tapping the pistons home.
Once all the holes are stuffed, the rods are torqued to spec. Rod bearing clearances were set at .0025", rod side clearance at .023".
Next, deck height is measured. This is a very important measurement for figuring compression ratio. After measuring several spots on the piston, they are .012" above deck, right about where I want them for this build.
Old 02-06-2009, 06:05 PM   #4
swb85
swb85's Avatar
And our shortblock is assembled!!! Time for some paint......
After a fresh coat of chevy orange, it's time to install the lifters and degree in the cam. The ICL measured at 107 degrees, close enough to the advertised 106 degrees that I do not need to advance/retard cam timing. LS lifters are held in place by these plastic trays.
Old 02-06-2009, 06:06 PM   #5
swb85
swb85's Avatar
Time for the gaskets and heads to go on. The gaskets are multi-layered steel and are installed dry. The heads are torqued down with ARP bolts.
Old 02-06-2009, 06:07 PM   #6
swb85
swb85's Avatar
She looks purty so far huh?
Stay tuned, lots more to come.
Old 02-06-2009, 06:14 PM   #7
Brad
Out of the carpool lane.
Brad's Avatar
Sweet! I'm looking forward to more!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 02-06-2009, 06:14 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
VERY NICE !!!
Don't know the cam specs and as it's a custom grind I'm sure you wanna keep those to yourself, but is that cam going get the dynamic compression down to premium pump gas territory ? 12:1 on the street has got to be fun.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 02-06-2009, 06:23 PM   #9
swb85
swb85's Avatar
Cam is big (240's/250's @.050"), dynamic compression is 8.65:1. That's getting close to the limits of pump gas, but with a good quench pad (.041") and tune it'll work for my app. The tank in the back will get 92, the little tank in the front will get 110.
Old 02-06-2009, 06:45 PM   #10
68c10owner
68c10owner's Avatar
With your tight quench and aluminum heads that have the fast burn chamber I`d say you`ll be ok. Thats a nice engine you built there. i would love to build something like that for my 84 but maybe just a bit milder.
Anthony
78 C10 SWB
68c10owner is offline   Reply With Quote
Old 02-08-2009, 12:15 AM   #11
Captainfab
60-66 Nut
At the risk of asking a dumb question....I know very little about the LS engines, but is it common to have the piston above the deck? are they this way from the factory also?
This ought to be a strong engine....
Old 02-08-2009, 06:54 PM   #12
LEEVON
LEEVON's Avatar
nice build! can't wait to see what it does in the car.
'19 Silverado Trail Boss ~ '15 Challenger R/T Scat Pack 392 ~ '11 Escalade ESV ~ '87 Silverado swb 4x4 ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 02-08-2009, 07:31 PM   #13
hotrod 80
mini truck racer
hotrod 80's Avatar
Nice build . My next one will be a LS motor .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 02-08-2009, 10:09 PM   #14
Green Machine
Green Machine's Avatar
Sweet engine build - I'd love to do one of those someday, keep us posted !
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-09-2009, 10:26 AM   #15
swb85
swb85's Avatar
Yep. Around .006"-.008" above deck is about normal on LS motors with a stock rotating assembly.
Old 02-09-2009, 10:35 AM   #16
swb85
swb85's Avatar
Steam tubes, knock sensors/harness, oil and cam sensors installed.
....and a quick teaser of what goes on top. I haven't plumbed the direct port system yet, just had to set it on to see how it looks.
Will keep updating as I go!
Old 02-09-2009, 01:42 PM   #17
70rs/ss
70rs/ss's Avatar
With the knock sensors and the computer running the show, you'll be able to get away with the compression, but the computer may pull a bit of timing out and that could hurt performance, right?? Just wondering, that is a super sweet build and i too will do one, i have a 5.3 now, and the used 6.0's are getting super affordable, i was just a little freaked about an LS build, but I have seen enough of them, they are not entirely foreign from a Gen I SBC, like I originally thought when they first started coming out. I think i'll build a 6.0 hopped up, but with a carb?! EFI still freaks me out (I know, I am a carb cavemen, but old habits are hard to kill!)
70rs/ss is offline   Reply With Quote
Old 02-09-2009, 04:05 PM   #18
swb85
swb85's Avatar
I do all my own fuel injection tuning---I'll be controlling the show, not the computer/knock sensors. I'm getting away with this much compression because of several variables including quench, chamber design, dynamic compression, precise fuel control/distribution, weight/gearing of vehicle etc. This isn't one of those deals that ya slap together and expect it to work, I spent 9 months planning this one.
Thanks for the compliments everyone, I'll keep going with the pics!
Old 02-09-2009, 06:28 PM   #19
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
probably a stupid question but are the steam tubes the same as steam holes in a 400ci? purpose wise that is
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 02-10-2009, 11:13 AM   #20
swb85
swb85's Avatar
Very close to the same purpose. You can see the tube that connects to the front of each head in the pic above. This is the highest point in the system, which allows trapped air bubbles out and a path back to the radiator.
Old 02-10-2009, 10:35 PM   #21
GMC70c20
thats a pretty bad a$$ setup but I just have one qeustion, why did you go with prc ported heads instead of L92's? I am puting a ls3 6.2 in my truck also, the reason why I ask is because the L92's at .600 lift flow 325 cfm stock.
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 02-11-2009, 12:09 PM   #22
swb85
swb85's Avatar
Valid question. Currently the only composite FI (non-carb style) intake available that fits the L92/LS3 square intake ports is the factory L76/LS3 intake. That intake falls flat on it's face above ~6400rpm. This motor will make power to 7000+rpm. The carb style intake would require cutting the cowl on my 4th gen and run an elbow.....didn't want to go that route yet, it's still a "street" car (to me anyway).
Secondly, those L92's flow a ton of air but do so with a 260cc intake runner and a big 2.16" intake valve. My heads flow about the same as stock L92's, but do it with a much smaller 220cc runner and 2.02 valve.......much better port velocity, cylinder filling and torque for the smaller cubes I'm running. I would like to do a larger cube motor with L92 heads and a carb style intake someday.......
Old 02-23-2009, 01:52 PM   #23
swb85
swb85's Avatar
*UPDATE*
Windage tray, pickup tube and pan are back on, along with front cover and crank pulley. Front/rear cover alignment with the pan rails is critical on LS motors, as the pan is a structural piece of the block. The lower bellhousing bolts actually thread into the oil pan.
I'm now in the middle of the nitrous plumbing on the intake (still have the fuel left to do on the passenger side), once I get that done the motor is getting close to completion!!
Old 02-23-2009, 11:14 PM   #24
swb85
swb85's Avatar
Finally finished the intake and set it on!
Old 02-24-2009, 12:54 AM   #25
Pyrotechnic
Where are you going to move the coils and what are you doing for spark plug wires ?
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
