Broken Down
Transmission front pump removal 700R4
I am trying to remove my front pump on my 1986 700R4 tranny. It calls for a special GM tool. Anyone have any tricks to get it out??? HELP im at a standstill on this tear down.... LMAO
kenm78 1982 Chevy 4X4 Project truck ![]() ![]() ![]() ![]() “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
Re: Transmission front pump removal 700R4
look for two of the bolt holes to be threaded and you can screw in bolts and hook a chain to them and pull it out. If that don't work then post your question here http://www.hotrodders.com/forum/transmission-rearend/
1970 GMC LWB ALL STOCK FOR NOW |
Middle-aged Curmudgeon
I've never had a pump that was really stuck in the case, even after sitting for a long time.
Remove all the bolts, then with the pan off, stick a big screwdriver up the back side and lever on it a little. They've always popped right out for me.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
Msgt USAF Ret
I had a trans shop tell me that the lock-up solenoid in the trans has to come out or it will break off when the front pump is pulled.
Here is a picture of the puller but at a cost of $90 bucks I would try one of the above methods.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
That is true. Solenoid has to come out first. Been there, done that, broke that <raising hand>.
And the filter...
Broken Down
All good to go now!!! I wasn't sure I thought I would mess somthing up back there but sure enough it worked. Got the trans torn all the way down to that bottom plate with all the small springs behind it thats going to be a pain!!!! Thanks all for your imput.
![]() Join Date: Jul 2004
You can make a tool to get the rear piston out. Get half a muffler clamp, the formed steel piece, (not the u bolt) drill a hole in the center and use a bolt or chunk of threaded rod and drill a hole in a piece of wood or steel.
Put the clamp in the tranny, curved part to the rear, run the bolt out the back thru the hole in the wood block and tighten the nut to squeeze the springs down.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#9 | |
Broken Down
Here's the tool that my stepdad built after we looked thru many books, forums, tool sites, & more. The one already posted in this thread will only work on the older 700R4's (87 & Back) from what we can tell. This was based on the 2 or 3 early 90 models that we have which do not have the groove/slot behind the splines and finding a factory tool using the same principal as this one designed for the 4L60E's.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
