Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-15-2009, 08:42 PM   #1
rick1956
rick1956's Avatar
Wipers "Trying" not to park
Here's the deal:
I'm dealing with a 1984 C10 plain Jane pickup with no frills (or intermittent wipers).
I first noticed the problem when I had half of my cowling apart during a windshield replacement. Here's what happened: When I plugged the wiper motor back in with no arms attached, the wipers continued to run, although very slowly, when I turned the switch off. They would, of course, stop when I switched the key off.
I assumed it was a park circuit problem and replaced the wiper motor (yes, with a rebuilt). I didn't try the wipers without the arms afterward because they were already reattached when I swapped the wiper motor out.
Apparently, it's still the same. When I'm driving and "pulse" the wipers for one quick swipe, they go slightly past the "park" position and stop about 2 inches up from the bottom of the stroke. Sometimes 1 inch--Sometimes 3.
Any ideas? It's obvious that I've thrown my money away on a wiper motor that I probably didn't need to replace in the first place. What else could be the problem? I did notice a wire that has been altered on one of the wiper motor plugins, but I don't know what or why it was done. It looks like someone used it to tap into something else at one time.
Anything? Thanks fellers!
"No honey--Really--Those are just extra screws..."
rick1956 is offline   Reply With Quote
Old 02-16-2009, 02:12 AM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: Wipers "Trying" not to park
my '78 no delay has a similar problem.
i have to time it when i turn the wipers off otherwise the end up anywhere other than the park position
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-16-2009, 11:23 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a c/p from this website with a diagram. I have posted it many times but very few seem to access it.
http://rmcavoy.freeshell.org/electrical.html
Q - How is the windshield wiper motor wired ? How can the circuit be tested ?
A - Single speed wipers were base equipment on most early 60's GM vehicles. They have one (fused) power wire that is connected directly to the wiper motor. This wire is live whenever the ignition switch is on. A second wire connects the motor to the switch on the dash. When the wiper switch is turned on, it completes the circuit to ground (the dash). The single speed motor can be tested using the following procedure:
* Use a test light (or voltmeter) to check for power at the wiper motor. Do this with the ignition switch on (wiper switch can be on or off). No power at the motor is an indication of a bad fuse and/or wiring.
* Next, (with the ign switch still on) connect a jumper wire from the switch terminal on the motor to ground. That should cause the motor to run. If it doesn't then the motor is probably faulty.
* Finally, the wiper switch can be tested with an ohmmeter or continuity tester. Also make sure that paint or corrosion isn't keeping the switch housing from properly grounding to the dash.
Two speed wipers with washers were available as optional equipment on early 60's GM vehicles. They became standard equipment in 1965 or 1966. This system still uses the same basic wiring principles as the single speed wipers. There is still a power wire that feeds the wiper motor whenever the ignition switch is on. Except now there are three wires going to the switch. The switch grounds one wire for high speed operation. Two wires are grounded for low speed operation. The third wire grounds the washer solenoid to activate the washers. Note that many '75 and later vehicles used a small electric washer fluid pump mounted to the reservoir instead of the older wiper motor driven pump.
There are also 3 types of 2-speed wiper motors. One is a non-depressed park motor that is easily identified by its rectangular motor case. Another is a depressed park motor that has a round motor case attached to the gearbox at an angle. The third is a permanent magnet motor that has sort of a rounded 6-sided motor case. The diagram below illustrates the non-depressed park (rectangular case) motor. The washer has been omitted for clarity. The depressed park (round case) motor uses the same wiring concept except the terminals on the motor are arranged in a different order (3 Low, 2 Power, and 1 High). The permanent magnet motor (used primarily on 1978 & newer GM pick-up trucks) has separate terminals for the park switch and therefore uses a different wiring setup.
Testing the wiper motor independent of the switch:
The depressed park and non-depressed park 2-speed wiper motors can be bench tested independent of the dash switch by making the following connections:
* Ground the wiper motor housing.
* Connect a jumper wire from a +12V source to the #2 (Power) terminal on the wiper motor. It's the bottom terminal on the rectangular motor or the middle terminal on the round motor.
* Connect a jumper wire from ground to the #1 (High) terminal on the wiper motor. It's the middle terminal on the rectangular motor or the bottom terminal on the round motor. This should operate the motor at high speed.
* Leaving the above connections in place, add an additional jumper wire between the #1 (High) and #3 (Low) terminal. #3 is the top terminal on both the rectangular and round motors. This should operate the motor at low speed.
* On the rectangular case motor, leave the jumper between terminals #1 and #3 but disconnect it from ground. That should cause the motor to run (at low speed) until it reaches its park position at which point it should stop.
* On the round case motor, leave terminal #3 grounded but unhook the ground jumper from terminal #1. That should cause the motor to run (at low speed) until it reaches its park position at which point it should stop.
If the motor operates normally in the above tests but not when installed on the vehicle then the problem is most likely in the switch or maybe the wiring. Don't forget to check the fuse. The switch can be tested with an ohmmeter.
If the motor stops immediately when switched off (doesn't return to park position), first check the motor's ground strap. Since the motor is mounted on rubber cushions, it's grounded via a copper strap attached under one of the mounting screws. This is the ground for the park switch so the parking feature won't operate if the ground strap is missing, dirty, or corroded. If the ground strap checks out okay but the motor still doesn't go into park then the problem is most likely a worn out or dirty park switch. The park switch is located inside the motor's gearbox so some disassembly is required to check/clean the switch. I recommend consulting a good repair manual for the motor disassembly procedure.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-16-2009, 04:16 PM   #4
willett
willett's Avatar
hey thanks for the info!
i couldn't figure why my wipers don't work on high and i think i can solve the problem now!
not to steal the thread, but is there some kind of fuse for both the nigh and low speeds, or seperate fuses?
Old 02-16-2009, 05:35 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The wiper is controlled by a grounding wire switch which grounds the motor instead of the usual way of switching the positive side of the circuit. The motor is powered by a constant hot wire off the Key switch which runs through the fuse block. This wire is fused by a 10 amp fuse located above the signal flasher in the fuse block pictured below.
VetteVet
Old 02-16-2009, 09:12 PM   #6
willett
willett's Avatar
Old 03-04-2009, 08:27 AM   #7
rick1956
rick1956's Avatar
The problem has been fixed!
True to the average GM pickup truck, I suffered from a ground issue. It all boiled down to that one, stupid braided ground strap that GM decided would be all we need to successfully connect the ground between our firewalls and engine blocks.
'Lo and behold, mine wasn't connected.
The wipers now make nice, quick sweeps and stop where they're supposed to stop.
It kinda makes me wonder if that was the problem with my old 65 C10 that I had several years ago...
Old 03-04-2009, 11:39 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Thanks for the feedback. This is a common problem.
VetteVet
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
