Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer II
Old 02-18-2009, 10:33 PM   #1
chevymotocross
chevymotocross's Avatar
92 s10 blazer idle problems
I'm stumped with my fathers 92 s10 blazer with the TBI 4.3. The truck will not start cold without holding your foot on the pedal. Once started, it will idle, but very low, sometimes, it may even stall if put into gear too quickly. Once completely warmed up, it will idle, but still low. Engine runs strong otherwise.
I did voltage checks with the TPS, checks out fine. Did meter tests with the IAC, those tests came out fine as well.
Checked for vacuum leaks and found none.
What else should I be checking?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 02-19-2009, 09:25 AM   #2
BarryB
BarryB's Avatar
Re: 92 s10 blazer idle problems
Does that year have the cold start injector? I know some of the TPI had a cold start injector on them. I not sure but thats my .02 worth.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 02-19-2009, 02:52 PM   #3
Damien
Living the Dream
Damien's Avatar
Check the coolant temp sender. It serves the same function as a choke. It is on the top of the intake manifold near the t stat housing and has two wire coming out of it.
I can still count my vehicles on two hands.
Damien is offline   Reply With Quote
Old 02-19-2009, 03:13 PM   #4
speed
Junior Member
speed's Avatar
Did you check the fuel pressure before the regulator.
Jeff J
86 El Camino
81 Monte Carlo
81 Regal
04 Colorado
speed is offline   Reply With Quote
Old 02-19-2009, 05:25 PM   #5
chevymotocross
This was something I was thinking of checking next. I have to get those gauge adapters though so I can tap in a gauge.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
