Old 06-15-2015, 07:45 PM   #326
Jonlopes
Re: 8 lug wheels - what's on YOUR truck?
Originally Posted by viking427 View Post
ARE shows these in 17x8 and 17x9 "blank" (undrilled) stock. If ARE wont drill them to 8x6.5, many wheel places and machine shops have the proper indexing jig to do it properly and accurately, although it will add cost to the package.
True but I would imagine it would add $100/ wheel which will make them a $1200 set of wheels. I may consider this if I could actually see a picture of them mounted on something with 8 lugs but too big a gamble otherwise. From the 1 picture that does exist it looks like the "slots" are much larger on these than the classics and I am thinking what if that makes them look bad.
Also I like Ultra 50/51 wheels about 90% as much as I like slot wheels and a set of 4 is under $500 shipped AND they are available in 16x8 instead of 17X9.
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 06-15-2015, 10:48 PM   #327
tdangle
tdangle's Avatar
this is what I just put on my truck. Level 8 Punch and LT265/75 R16 Tires. I got the entire package from America's Tire.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-15-2015, 11:12 PM   #328
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
They cannot, the center of the wheel is to small to be drilled on the blanks apparently. I paid for 5 of the blanks and was denied on them being able to drill them. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 06-16-2015, 10:53 AM   #329
Mmorgan32
Mmorgan32's Avatar
Those look sick man. I love the level 8 wheels. What's your backspacing? How much out the door
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 06-16-2015, 12:55 PM   #330
tdangle
tdangle's Avatar
The wheels are 16 x 8.5 8-165.10 -6 the -6 is the offset I believe the backspacing is about 4 1/2" Really not a lot to chose from, but it really fits well on the truck, before it looked like too skinny of a tire set in too much. Now the wheels/tires fit very well. It was right at $1100 out the door with road hazard, new lugs everything. BTW the tires I got are GT Radial Adventuro AT3. They tried to talk me into a more expensive tire, but I really didn't need them as I will be lucky to put 5000 miles a year on the truck. At least for the next few years.
Terry
Old 06-16-2015, 01:20 PM   #331
kikkegek
kikkegek's Avatar
no idea what they are called, but I like them on our Monster 74 Suburban
16" rims and 35" tires
kikkegek is offline   Reply With Quote
Old 06-16-2015, 01:33 PM   #332
Cash3481
Loves all GMC trucks
Cash3481's Avatar
I think those are generally called "12 hole outlaws".
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
Old 06-16-2015, 06:37 PM   #333
drive-em
drive-em's Avatar
16x8 Wheel Vintiques
drive-em is offline   Reply With Quote
Old 06-16-2015, 09:29 PM   #334
Layne
Drive-em, those look great.
I'm having a hard time finding stock wheels for my '68 3/4 ton with clip style hubcaps.
I wonder if they could make me some?
Layne is offline   Reply With Quote
Old 06-16-2015, 10:23 PM   #335
drive-em
drive-em's Avatar
My caps did not fit real well. It took a little massaging and 3M double sided adhesive. I have seen clips that can be welded on to your wheels.
Old 06-16-2015, 10:27 PM   #336
Layne
Thanks. I'll look into it.
Old 06-17-2015, 05:06 AM   #337
raiderfan
raiderfan's Avatar
not a great pic, but the only one i found of my wheels......
raiderfan is offline   Reply With Quote
Old 06-17-2015, 02:36 PM   #338
viking427
Update: Spoke with Jeff, in the product design group at American Racing (now owned by "Wheel Pros" out of Lakewood Colorado). He was the one responsible for convincing their production dept. to release the (17") Ansen Sprint slotted wheel in our GM 8x6.5 pattern, with our exact 3/4 & 1 ton 67-72 trucks in mind. He was unaware ARE dropped production of this size. After investigating internally, he was informed sales of this pattern after 1.5 years of production (since Aug 2013) were too slow to warrant continued production of this size. HQ says they have no plans to resume production in the 8x6.5 pattern. And yes, the "blanks" are based on the lighter weight 5 lug (~2500 lb, less material) molds instead of the 8 lug molds, so they cant be drilled for 8 lug patterns. So this indeed echo's what others here have also discovered.
Under these dim circumstances, Id have to agree, the "Ultra 50" is probably one of the better wheels that captures the period correct custom wheel look in an 8x6.5 pattern. If anyone knows of a 16", 17", 18" (16.5" have been discussed extensively already) 8x6.5 slotted wheel or other era/period correct wheel, please share the info
"Ultra 50" on one of our members trucks here;
viking427 is offline   Reply With Quote
Old 06-17-2015, 02:46 PM   #339
BlacklandCamper
Originally Posted by K20chevy View Post
Dodge actually has 17x7, 17x7.5 and 17x8 stock steel wheels with the 8x6.5" bolt pattern. The only problem is that they have huge backspacing. I think about 6"! So on the old trucks you´d have to use spacers OR maybe you could "re-center" them for a little less backspacing.
The coolest would actually be to use the old center caps on these wheels somehow....
I have a set of the 17 dodge wheels on my 71, and had to put 1/4 spacers on the back to keep them from rubbing on the inner wheel well. I've been looking at putting some thicker spacers on it to get them flush, and allow the room for the late '90s style center caps.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline   Reply With Quote
Old 06-17-2015, 03:11 PM   #340
BlacklandCamper
Originally Posted by gripnrip View Post
70, can you tell me where people get the lugnuts for these wheel? Thanks.
Someone on this site pointed me to these a while back.
http://www.ezaccessory.com/GM_9_16_E..._p/98-0009.htm
Old 06-18-2015, 01:47 PM   #341
74chevrolet
17" steel d window 255/50 in front 275/50 in back. front lowered 2.5 with pol kit, and gmc paul 1"spring. rear still stock
74chevrolet is offline   Reply With Quote
Old 06-18-2015, 05:54 PM   #342
Jonlopes
Those are the exact pictures that sold me on the Ultra 50's. Once I get my motor sorted out I plan to get a set of those in 16x8 and mount some 285-75r16's. My truck is running that tire size now with 0 offset 16x8 wheels and no rubbing at all. The Ultras are -6mm offset so they will move the wheel/ tire out about 1/4 inch so that should not effect the fitment.
The only thing I would change is the Ultra center caps seem to have fake hub nuts molded into them for decoration. I may end up changing them out for plain chrome.
Old 06-18-2015, 06:22 PM   #343
viking427
Dug a little deeper on sources of classic slotted mag wheels in modern sizes (ie. sizes you can actually still find quality radial road tires for). "US Mags" brand, now owned by MHT wheel, has the "U433 Indy" wheel available in custom builds; Its a forged two piece welded wheel blank drilled to your specs 8 lug x 6.5 BC, 16x8, 17x8 etc. Should be more than strong enough for even serious towing or off-roading. Problem is they cost a fortune - 16x8 = $875/ea, 17x8 = $700/ea. As usual, no 8 lug pics to be found anywhere, but heres a 5 lugger with the larger 4.5" center bore for perspective. Nice looking wheel though..
Old 06-18-2015, 06:58 PM   #344
Jonlopes
There is a website that specializes in classic used wheels with a set of 16x8.5 original slot wheels that have been restored in 8 lug for "Only" $2600
Old 06-18-2015, 09:18 PM   #345
Mayo
Cool Truck
Mayo's Avatar
Those wheels look great drive-em. I've been thinking about getting a set of them for winter wheels and I think I'm sold now.
Layne, I bought a set of 68 3/4 ton hubcaps that need refinishing but intend to eventually mount them on a set of Wheel Vintiques. I was planning on tapping out the rims and screw on a set of spring clips like Delmo does on his rims and people do with the GM Transport wheels.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 06-19-2015, 04:49 PM   #346
markmdz
i put these on a little over a week ago. I don't think they look too bad. Definitely not period correct, but they'll do for now. ...now the truck is begging for an elevation change though.
As soon as my 2/4 drop springs come in they'll be put under the truck to hopefully close up a large portion of that wheel gap.
markmdz is offline   Reply With Quote
Old 06-19-2015, 04:57 PM   #347
jimbosprint
jimbosprint's Avatar
Chrome 16" rims that were on the truck when I bought it (not sure what brand or model). I polished them up so they look a lot better, but they are still rusty in places.
jimbosprint is offline   Reply With Quote
Old 06-19-2015, 05:06 PM   #348
sboris
sboris's Avatar
Cool Re: 8 lug wheels - what's on YOUR truck?
First thing ill buy when i win the lottery.. Sweet lookn
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 06-19-2015, 05:26 PM   #349
keith cservak
Originally Posted by Shaky View Post
Later model stock steel wheels with 73-87 hub caps. I don't like 'em. I'm thinking of calling up stockton and having a set of smooth steelies made up.
I know this is an old thread just wondering if you still have this truck and if so what can you tell me about the brush guard is it factory.
Keith.
keith cservak is offline   Reply With Quote
Old 02-26-2016, 03:59 PM   #350
1970 charlie
1970 charlie's Avatar
Originally Posted by stllookn View Post
mr bowtie....this is what you are looking for...I'm still waiting for tires for them. They are 1.5" wider than the widest stock wheel but only a "purist" would know the difference. Powder coated in Argent Silver.
A deep dish and hubcaps rule.
1970 charlie is offline   Reply With Quote
