Old 03-27-2009, 11:16 PM   #1
sstpeach
Pictures of Correct 6 cylinder engine mounts?
Does anyone have a photo of the correct engine mount for a six cylinder to install in my 66? I have a 77 year 250 straight six to install but the 77 engine mounts don't work to the truck and the original flat mounts from 66 don't work to my newer straight six engine.
sstpeach is offline   Reply With Quote
Old 03-28-2009, 02:26 AM   #2
Heater63
Heater63's Avatar
Re: Pictures of Correct 6 cylinder engine mounts?
I will get you some tommorow or Sunday, and will have to go out in the cold to do it!
292 + TKO500
Heater63 is offline   Reply With Quote
Old 03-28-2009, 04:38 PM   #3
kizer
Its Deja Vu time again
kizer's Avatar
Not 100% sure what you need, but since my front clip is off and the motor is still intact I figured I'd share. I needed to take some photos anyways for my memory sake before I tear it all off, strip and paint.
Keep in mind this supposed to be a 66 Chevelle 250 in a 65 C10.
1st is head one, 2nd-3rd are passenger side, 4th is drivers so you could see around the fuel pump.
Let me know if you need anything pictures or measurements since its pretty to access everything with the clip gone.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 03-28-2009, 09:45 PM   #4
sstpeach
Those pictures are exactly what I needed, thanks for the sanity check on my end!
The mount that bolts to the engine block, correct me if I'm wrong here but is that peculiar to a mid 60's block only or will that also bolt up to my 70's straight six?
steve
Old 03-29-2009, 12:34 AM   #5
Heater63
Heater63's Avatar
Way to go Kizer! LOL. It was friggin cold when I went out to take pictures, and dang if you didn't beat me too it!
Steve, My pics are just the same, but I will email them to you anyway. I have your email from the other post.
The block casting for the L6 short deck (230, 250) was the same from 60s, 70s, and 80s until they quit building them. Your motor mounts-to-block should fit all. They only difference as I know it is the passenger side of the Tall deck 292 where the motor mount is moved forward.
Heater
292 + TKO500
Old 03-29-2009, 10:40 AM   #6
sstpeach
LOOKING TO Purchase: 6 cylinder engine mounts
Thanks all for the photos. You've confirmed my truck has the wrong perches in it from the previous owner. I would give my buddy a holler who I purchased the truck from but he's currently stationed in Japan with the Marines.
Tried to upload a photo to show you my truck but its giving me a security token alert, I've sent an e-mail to the site requesting correction.
Old 03-29-2009, 10:46 AM   #7
joe231
joe231's Avatar
Re: LOOKING TO Purchase: 6 cylinder engine mounts
that means your pictures are too big, you need to resize them
the V8 and the I-6 (except the 292) perches are the same....
CHEVY ONLY
Old 03-29-2009, 10:54 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
sstpeach you must be a subscribing member to make a "wanted to buy" post. Please consider supporting the forum by subscribing.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-29-2009, 11:02 PM   #9
kizer
kizer's Avatar
I'm glad the pictures worked out for you. I was more or less winging it.
Old 04-15-2009, 08:20 PM   #10
the lights
the lights's Avatar
I am looking at a 292 to replace my 327 would it be easier to find a 250 because of the motor mounts, or will a 292 bolt in with relatively easy modification?
the lights is offline   Reply With Quote
Old 04-16-2009, 10:18 AM   #11
Heater63
Heater63's Avatar
The 230 and 250 should be much easier to find because they were in cars too, the 292 was only in trucks, and they are much more scarce. Here in Texas I had to look for some time to find a good one; I'm about to send it to the machine shop; meanwhile, my old 230 I will give to someone if they come get it.
The 230, 250 should mount on the small block frame perches with no mods; The 292 has staggered mounts requiring the passenger side frame perch to be relocated forward.
Unless your 327 is exploded, or already bored .060 and trashed again, it is a popular block. I recommend you rebuild the 327. It has more performance and economy than the L6 plus, more options, parts are cheaper and easier to find. (I have one-'68 Camaro)
If you need torque for hauling/pulling a load, find a 292.
292 + TKO500
Old 04-16-2009, 04:10 PM   #12
the lights
the lights's Avatar
I talked to the guy with the six cylinder and he says its a 265? I need something to drop in the truck that runs because its my daily driver. I do plan on rebuilding the 327. So does a 265 use the same mounts as a 250?
Old 04-17-2009, 06:43 AM   #13
Fred T
Cantankerous Geezer
Fred T's Avatar
I never heard of a Chevy six that was a 265. Before 63 was the 235 and the 261, truck engine that was later replaced by the 292. the new family debuted in 62 with the 194, then the 230, 250 and the 292 was the last.
Mounts for the older 235/261 are different, the block is wider. The new family all use the same mounts, except for the 292 with the passenger side mount moved ahead one cylinder.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-17-2009, 09:04 AM   #14
l79m20
265 was a GM V8
l79m20 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
