Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 04-05-2009, 03:21 PM   #1
piecesparts
Parts and more parts
piecesparts's Avatar
What HP is really in the 91 Silverado 350/5.7 engine.
Does anyone really know what the early 90s 5.7 engines, with TBI systems had for horsepower ratings? I had the impression that these engines were low compression, low HP rated and this supports their longivity. The numbers that I have heard are around 160 HP from the new car lot. Yet, there are individuals that have psted the numbers as high as 210 hp from the dealers.
Does anyone know the real numbers.
I am looking to replace the 275,000 mile engine in my truck and I am looking at a setup from Pace Performance. This new setup has around 265 HP complete from the crate. This will have the Edelbrock multi-point fuel injection, to assist in the improvement
piecesparts is offline   Reply With Quote
Old 04-05-2009, 03:55 PM   #2
combustion
Re: What HP is really in the 91 Silverado 350/5.7 engine.
when i was at tech school, a base 88 1500 short bed made 143 wheel. i remember this kid thought he was hot stuff with his beefy sounding rig. but it was a turd indeed lol. im assuming 160? it has the same pos tbi injection
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 04-05-2009, 05:33 PM   #3
The 4.3 V6 was rated at 160, the 5.0 was 175. I think the 350 was rated around 190-200 depending on what model you got.
1981 GMC High Sierra SWB Stepside
"Whitey" 2002 Chevy Silverado 1500 SWB W/T
Board Vendors
Palf70Step is online now   Reply With Quote
Old 04-05-2009, 05:44 PM   #4
cjracing15
cjracing15's Avatar
Originally Posted by combustion View Post
pos tbi injection
Why you be hatin on tbi?
The fleet
94 Chevy 4x4 reg cab
2012 Camry (wifes car)
1977 SWB stepside
cjracing15 is offline   Reply With Quote
Old 04-06-2009, 03:59 AM   #5
combustion
i didint mean to insult anyone, but to me its a glorified carburetor. i walwyas have problems with those systems. im wondering if it is just my luck assume? i prefer multi point better. much more tunability.
Old 04-06-2009, 09:40 AM   #6
piecesparts
As I said guys, my truck yhas 275,000 miles and the truck is still strong. I want to update the engine and even look at something that has some more performance.
Combustion is right to some degree about the TBI, however it is a solid system. There are better and more efficient systems in the world.
The Throttle body was a poorly designed idea, of having two injectors spraying onto the butterflies of the unit. That in itself creates a poor fuel dispersion system. The install of a TB Spacer allows for that dispersion to increase, since it has a way to mixing up the fuel and air again. The multipoint injection gets the same amount of fuel to each and every cylinder that a carb or a center mounted TBI unnit soes not, so effectively MORE horsepower is available. The end cylinders are not starved like a center mounted unit does.
Old 04-06-2009, 10:29 AM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Throttle body spacer (AIRRAID, for example) is legitimate. Don't even think about using a Tornado device. It's all hype, to me. It sounds logical, but it didn't work when I tried it out. Good thing it had a 30-day money-back warranty. I was driving enough to do a good test of it, too.
Member Nr. 2770
Old 04-06-2009, 04:07 PM   #8
kevinr1970
Everything I had read had the -89-91 Burb's with either 190 or 210. I didn't pay attention but I "assume" it had to to with light duty vs. heavy duty.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 04-06-2009, 08:33 PM   #9
cjracing15
cjracing15's Avatar
Hey you didn't insult me, I just like the tbi system for a daily driver because of the simplicity of the system. I know tbi has its problems but it is simple to work on and the parts are cheap thats all I am sayin.
The fleet
1977 SWB stepside
Old 04-11-2009, 01:38 PM   #10
'65 Super Sport 327 700R4
whats that smell?
'65 Super Sport 327 700R4's Avatar
The Heavy Duty 3/4 and 1 tons had 190 Horsepower 350's and the 1/2 ton and light 3/4 ton's (7200 GVW) had 200. These were the figures for '95 TBI engines.
-Erik
'29 Chrysler model 65 all original, 2nd owner ***FOR SALE***
'63 Impala SS 283, 3-on-the tree, flowmaster 2 1/4" dual exhaust, performer intake, edelbrock 600 carb, chrome 15x8 rally's
'65 Impala SS, built 332, 700R4, 3.73, 2 1/2" mandral bent duals w/H pipe, Flowmaster 40-series deltaflows, MSD Mallory, too many modifications to list
'72 Chevy Suburban 4x4, NP205, TH350, balanced 357 (.040 350), 268 high energy cam, 9.2:1 comp, 1.94/1.50 heads (ENGINE BUILT BY THE GREAT RAYZOR or if you know him RAY, WHO POSTS ON THIS BOARD AND CHEVYTALK), 3/4 ton leaf springs, 4" lift, 35/12.5/16.5 Grabber MT's, Rancho shocks, Rancho dual steering stabalizer, American Eagle 143's 16.5x9.75 6 lug, 4.10's, 12 bolt rear limited slip, Dana 44 front limited slip. Carter 600, performer intake, headers and flowmaster exhaust system very soon.
'74 GMC 1500 Super Custom, Factory 3/4 ton springs, built 400sb w/3947040 heads, 475 hp, 750 edelbrock, ceramic headers, TH350, B&M holeshot 2000, 2 1/2" duals w/ H-Pipe, 40-series delta-flow Flowmasters, Gibson tips, Fey Outlaw 8" drop bumper.
'95 Impala SS Flowmaster cat-back, K&N, 255/50/17 G-Force T/A, Dark cherry metallic, 27,000 miles, extreamly fun vehicle
'95 Chevy K2500, ex-cab, long bed, 350, AT, Flowmaster cat-back, 265/75/16 Mud Kings, 16x7.5 Centerline HT cast
wheels, Leer high rise canope, bed liner w/ mat, loaded.**FOR SALE**
'65 Super Sport 327 700R4 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
