04-13-2009, 05:27 PM | #1 |
Im afraid of purple hangers..
396 Big Block starter? 1970? help?
http://static.summitracing.com/globa...i-356000_w.jpg
Ok, so i have this 70 gmc with a stock 396 with a automatic tranny. The starter has been chirping and today the solenoid started to spin with no flywheel engagement. So I crawled under her today to yank it out. taking off the heat shield from the starter. ( yes the battery is disconnected) and start to go after the positive cable and the ingnition wire. the cable post comes off in my hand with the bolt and nuts from the solenoid with out even using a wrench. So I have to take her off now for sure. As I get to the Staggered bolts holding her up backing them off one of the cast "ears" falls an inch from my forehead on the ground. Great this thing is in in pieces. So i take it to the "parts changers" to get a re-manned starter. And there computers are telling me that my truck only came with a 350 or 402. Nice to see there computers are up to date on motors. LOL So I call a mobile mech. I know who shoots me to his parts guy. They tell me that most of the starters they have to fit a big block are aluminum housings and not cast. He called the "warehouse" who works on there rebuilds and says they can fix mine if i send it out. So now that my short story is long. here are my questions. 1. Will they keep my Starter housing and just replace the cast nose housing and solenoid? 2. Is the attached picture i got from summit a high torque it looks alike to mine minus the yellow powder coat? 3. Could they substitue a high torque for a low one on me? 4. Is there any other year or make that i can use to chase down parts for my 396 out of my 1970 gmc c-20? Thanks |
04-13-2009, 05:32 PM | #2 |
its all about the +6 inches
Re: 396 Big Block starter? 1970? help?
your 70 has a 402, there computer is right.
They never made another 396 big block chevy after the end of the 1969 model year |
04-13-2009, 07:08 PM | #3 |
I built it
if you have a 168 tooth flywheel all the starters should be the same.(on a auto trany)
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
04-13-2009, 07:55 PM | #4 |
I stay away from the high torque starters. I had one eat up my new flywheel on my 68 Chevelle SS 396. Try a NAPA store, they have new starters that look and fit just like originals, on your 402. I assume this is a slant offset holes starter.
04-13-2009, 08:57 PM | #5 |
Active Member
Advanced Auto carries rebuilt delco remy starters for around 100 bucks with a lifetime warranty
I put one onto my big block and it works just fine
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
04-13-2009, 11:53 PM | #6 | |
T0804TBG was stamped on pass. side head plate Code Year Model CID HP Trans Comment TBG 1970 Truck 402 310 400 L-47 10, 20, 30 Ok now i feel like a rookie..... I sent the starter out to a shop to rebuild the starter from the truck. I didnt get a replacement. Im having mine rebuilt. So i need to rethink and check what the previous owner had installed? would it matter if it was a part for a 396 block? |
04-14-2009, 09:20 AM | #7 |
[QUOTE=bsgmcc20;3255907]So the Protect-O-plate should of said 402 and not L-47 396 like it says? ?
T0804TBG was stamped on pass. side head plate Code Year Model CID HP Trans Comment TBG 1970 Truck 402 310 400 L-47 10, 20, 30 Ok now i feel like a rookie..... [QUOTE] dont feel bad, its ok to learn, my dads 70 cst shows the option code L47 and shows a 396 but the L47 option code is for the 400 also his SPID shows he has west coast Jr Mirros and yet below the eyeline mirrors have been installed on it from day one so go figure lol..cant always trust what they tell ya
PROJECT CIRCUIT RIDER |
04-14-2009, 04:35 PM | #8 |
I'm almost certian that the casting numbers remained the same.
Either way, if it is original, it isn't a 396. |
04-14-2009, 05:35 PM | #9 | |
Moderator
[quote=70cstjr;3256266][QUOTE=bsgmcc20;3255907]So the Protect-O-plate should of said 402 and not L-47 396 like it says? ?
T0804TBG was stamped on pass. side head plate Code Year Model CID HP Trans Comment TBG 1970 Truck 402 310 400 L-47 10, 20, 30 Ok now i feel like a rookie..... Quote:
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-14-2009, 08:34 PM | #10 |
I had a cast iron nose starter on my '70 402. I had all sorts of hot start problems and ditched it for a CVR mini-starter. Best $150 I EVER spent. I had a battery with a failed cell, only 10.2 volts max, and it still cranked 'er up until I got a new battery.
04-14-2009, 09:32 PM | #11 |
Moderator
x2. A high-torque mini starter is the only starter I will buy from now on.
04-15-2009, 01:01 AM | #12 |
I bought a starter for my 402 at Kragen 8 years ago. Here about two weeks ago I took that old starter in with the receipt and walked out with a new one for 0 cash. I was so happy. I know Kragen will have one for your 396 or 402 BB. Good Luck!
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
04-15-2009, 01:17 AM | #13 |
If nothing else is wrong with your starter you should still be able to buy an new End frame for it. But by the time you buy a solenoid, brushes, bushing for the commutator end and drive you will probably have more in it than buying a top quality rebuilt starter.
04-15-2009, 01:24 PM | #14 | |
So I will see. Im just trying to keep this ol' dog as close to what orginal as i got it in. You know the old saying if its not broke dont fix it. I learned that a long time ago. If it is working why tear it all apart. atleast not yet that is... |
04-15-2009, 03:15 PM | #15 |
bbadfred
I never have had a problem with hi torque starters on big blocks unless you do not have the starter brace. Even with the two front bolts tight without the brace the starter can move sideways a bit and break flexplate teeth or break the starter drive. the brace fits on that long bolt on the starter and the holes in the block close to the starter.
04-18-2009, 11:15 AM | #16 | |
I am interested in that "starter brace" does anyone have a pic of one? I just got my starter back. new end frame and solenoid. I am only out $45. better than the 199. quote i got from the "parts changers" outlet. While i am under there bbadfred i will look for he bolt area you speak of and see if i can fab up a brace. thanks for the heads up on the support brace. |
04-18-2009, 11:26 AM | #17 | |
40.00 Labor doesn't sound out of line as it usually take about an hour for me to rebuild one. After reading about the troubles a lot of guys are having with the "high torque" gear reduction starters on some of the other boards I think I would rather have a good strong starter that was built for the application to begin with. |
04-18-2009, 11:31 AM | #18 | |
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
04-18-2009, 11:37 AM | #19 |
I think this should be the correct starter brace
http://gilbertautoparts.com/Starters...s/03965588.jpg Scroll down the page to starter braces http://gilbertautoparts.com/Starters...arts/index.cfm You should be able to order it at your local dealer. Last edited by mr48chev; 04-18-2009 at 11:39 AM. |
04-18-2009, 06:10 PM | #20 | |
now to the sadle tanks.... arg |
