Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 05-05-2009, 02:46 PM   #1
catch-22
Does a 96 GMC Sierra have in Cabin Air Filters?
Can someone confirm for me if my 1996 Sierra has Cabin Air Filters? If it does where are they? My A/C seems to not blow very hard anymore - its cold but not much pressure on high. The floor blows the strongest but the dash and windshield vents don't seem as strong as they used to be. I was hoping that a cabin air filter replacement will be the cure. If not, what else should I check?
catch-22 is offline   Reply With Quote
Old 05-05-2009, 05:40 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Does a 96 GMC Sierra have in Cabin Air Filters?
I don't think there are any cabin filters in these trucks. I would suspect that the door(s) that deflect air may not be working properly. I don't have any way to prove/disprove that the door would be the issue. Maybe Chevy Tech will be reading this and have some input.
Member Nr. 2770
Old 05-05-2009, 07:48 PM   #3
ChevyTech
The think the first year there were cabin air filters in GM trucks was 1999, and NOT all 1999 trucks had filters.
By 2004 GM stopped putting cabin air filters in the trucks.
My first guess would be the “recirc” door aka fresh air door, is not operating correctly. Each time you shut off the engine the fresh air door should open if it is not already open. When you change settings from recirc to max ac the door should open, and if you listen carefully you should be able to hear it.
Another possibility is that there is debris like leaves and seeds blocking air flow. I have seen blower motor fans fully of leaves and AC evaporators plugged up with cottonwood seeds.
It is also possible that the mode door in the heater box is damaged or catching.
Old 05-05-2009, 08:03 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Thanks for the input.
Member Nr. 2770
Old 05-05-2009, 08:16 PM   #5
ChevyTech
You’re welcome. A thank you is always appreciated.
This happened to be one of the few posts I read today.
Old 05-06-2009, 09:42 AM   #6
catch-22
Thanks for the reply - Where is the “recirc” door aka fresh air door located, how do I get at it? I would guess its vacuum operated - so with the truck running the vacuum should close the door. Shut the engine off and door should open - correct? If this is the problem - how hard is it to replace?
Old 05-06-2009, 10:14 AM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=257463
This thread is from the past couple of weeks and will tell you a whole lot about what operates the door you are asking about. Chevy Tech explained it and there are pix to go along with it.
Post #9 is where the good stuff kicks in and it starts to gel.
Hope it helps.
Member Nr. 2770
Old 05-06-2009, 01:26 PM   #8
Unkle Fester
Ignorance is Bliss
Unkle Fester's Avatar
I have a 98 GMC Sierra and the recirc vent is right side under the dash of the passenger side. Right behind the blower (big round thing sticking into the footspace) It's a squarish looking grill. when recirc is on, grill looks open, fresh air - it is closed.
I only know because I have water leaking into mine...
I think my '90 burban was in the same place, can't see it changing that much.
Hope that helps
Unkle Fester is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
