Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-02-2009, 03:38 PM   #1
onlyifihadachevy
my gmc 2500
It began life as a 2wd and was mostly converted before i bought it. It only needed t case, front driveline, the lights set up and new tires. This build will be never complete until it gets sold, and consist of the stuff i brake or need done. by the way im 15 turning 16 in 10 days.
Some Pictures.
when we first got it.
The first time out, no front driveline.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 06-02-2009, 03:42 PM   #2
onlyifihadachevy
Re: my gmc 2500
The second time out the after.
trying to fix it and no fluid just mud, looking stuff.
More to come later.
My 72 thread
Old 06-06-2009, 12:16 AM   #3
onlyifihadachevy
Re: my gmc 2500
My dad and I worked on it some more and found the bearing near the yoke blew up. So we got everything out but the passager inter axle and ring and pinion because the po welded it together. So i will have some pics tomarrow.
My 72 thread
Old 06-06-2009, 03:03 AM   #4
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: my gmc 2500
OMG what a mofo!
jerk...
goodlookin muddin pics... but ya gotta get the front going...
good luck
p.s. what's with the rear end sitting so far "forward.."
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-06-2009, 11:22 AM   #5
onlyifihadachevy
Re: my gmc 2500
i think its the rear block, and i want to 4link it so im waiting till next weekend and if i don't have the money for the coilovers then i will get leaves. And im also Seeing about buying a shortbed 1/2t for 800 then i will get leaves for this and 4link that.
My 72 thread
Old 06-06-2009, 02:45 PM   #6
dammitmitchell
the pollock
Re: my gmc 2500
p.s. that's an awesome starter truck.. i dont thing you would ever willingly get rid of that
Army vet 02-08
Old 06-08-2009, 11:49 PM   #7
onlyifihadachevy
Re: my gmc 2500
after having my dad get some friends and they tried to get the passager axle shaft out, i put it back together and my dad is going to take it to my uncle shop to see if he can get it out. sorry no pics.
My 72 thread
Old 06-12-2009, 12:31 AM   #8
onlyifihadachevy
Re: my gmc 2500
well nothing has happened but i did try to run over a car in 2wd and no diff cover but didnt work it just pushed it, i even tried leaving on brake in 1st gear low range just hit it hard pushing it about 20 ft.
My 72 thread
Old 06-12-2009, 01:50 AM   #9
dammitmitchell
the pollock
Re: my gmc 2500
ha ha ha ive been DYING to do that !
hey if you want a38 in tire.. i got an extra one collecting dust!
Army vet 02-08
Old 06-15-2009, 11:55 PM   #10
onlyifihadachevy
Re: my gmc 2500
well later this week my truck should be getting fixed and today i started rewriting it. And with talking to my uncle and his employees saying the cast intake is rusting and some stuff is bad that i should take the cab off and restore it in places, that might take place. If so i will have some cooler stuff and maybe a paint job.
My 72 thread
Old 06-23-2009, 12:06 PM   #11
onlyifihadachevy
Re: my gmc 2500
This is what i broke on saturday should be all fixed today.
where i got it to
And how it looked on the trail
My 72 thread
Old 06-28-2009, 05:34 PM   #12
onlyifihadachevy
Re: my gmc 2500
i forgot to say i fixed most the bad wiring and i got the t case fixed i had to replace the 2 piece output housing with a one peice, i will thank right gear and axle and 4wheeler for the peice because it was off fourwheelers vehile i think they're running a 205 t case and right gear just gave me the piece. And i found out that the 2nd peice was cracked after i took it off, so next week i will fix the spring perches and get my driveline retubed. And put a motor in my new truck.
My 72 thread
Old 07-02-2009, 01:40 PM   #13
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: my gmc 2500
Nice looking truck bud. Looks good in the Mudd Good luck with the build and keep up the hard work!!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 07-02-2009, 09:23 PM   #14
onlyifihadachevy
Re: my gmc 2500
Everything is pretty much fixed of what i broke im going to maybe fix the rear perchs next week and the front end when i find a good deal. Until then im building my 69 for offroading.
My 72 thread
Old 07-06-2009, 12:12 PM   #15
onlyifihadachevy
Re: my gmc 2500
I have a front end its a d44, with 4.10s i belive.
My 72 thread
Old 07-08-2009, 01:10 PM   #16
onlyifihadachevy
Re: my gmc 2500
i gt the d44 bolted up and now i only need to put the hubs and little stuff to the front axle then wheeling, or towing depends on when i finish my 69. Im missing a passager motor mount bracket.
My 72 thread
Old 07-09-2009, 11:21 PM   #17
onlyifihadachevy
Re: my gmc 2500
My uncle made me make a list of what i need to do to it, and i really didn't find anything thats really hard just stuff that will take some time. I have to put fluid in the t case and trany and front end, turn it around tighten the bolts for my bumper lift it from the fork lift from the bumper and crossmember unbolt the u bolts and put the new axle in bolt it up. Measure drivelive have it made and do the brake lines and go wheeling.
My 72 thread
Old 07-14-2009, 11:07 PM   #18
onlyifihadachevy
Re: my gmc 2500
I have it moving under its own power, got the front put together and now i hae decided to keep the rear end in it because it has a locker and all it needs is the perchs and a brake a job which i will do soon, and the rear driveline.
My 72 thread
Old 07-14-2009, 11:41 PM   #19
70 beast
Certified Hobbiest
70 beast's Avatar
Re: my gmc 2500
What rear end do you have?
70 beast is offline   Reply With Quote
Old 07-15-2009, 12:17 AM   #20
onlyifihadachevy
Re: my gmc 2500
ho72 or ho52 because it isn't a 14 bolt and the diff cover looks stock but is pretty strong, i parked on it wasn't planning on it, thought it was the peice of wood and left it that way for about 30 mins and it didn't bend.
My 72 thread
Old 07-15-2009, 09:47 AM   #21
70 beast
Certified Hobbiest
70 beast's Avatar
Re: my gmc 2500
Eatons are awesome.
more ground clearance that a 14 bolt, removable third member and diff cover.
i picked mine up for dirt cheap and it had 4:57 gearing.
Old 07-15-2009, 09:48 AM   #22
70 beast
Certified Hobbiest
70 beast's Avatar
Re: my gmc 2500
what gears are you running in it?
Old 07-15-2009, 10:29 AM   #23
onlyifihadachevy
Re: my gmc 2500
4.10s going to be my tow rig and recovery rig when needed. I may switch out my rims and tires for some less aggresive tires.
My 72 thread
Old 07-15-2009, 11:44 AM   #24
70 beast
Certified Hobbiest
70 beast's Avatar
Re: my gmc 2500
thats what im doing with my 70. my pops and i are going to use it as a tow rig/camping rig. its 3/4 ton with detorits fr/rr and 4:56. hes looking to get some better tires for on/off road use since im taking back my 38's.
Old 07-15-2009, 09:09 PM   #25
onlyifihadachevy
Re: my gmc 2500
They have a lot of power for a 350 and the gears make them great for pulling stuff but have you thought about arb air lockers they're 700ea and detroits are a lot and with those you could use the compressor for air tools and airing up tires.
My 72 thread
Thread Tools
Display Modes
