06-18-2009, 01:23 PM | #1 |
dana 44 and a 205 transfer case
how much is a dana 44 and a 205 transfer case off of a 1969 gmc 4 wheel drive pick up worth???
06-18-2009, 11:52 PM | #2 |
Re: dana 44 and a 205 transfer case
Not sure on the 44, but for the 205 I wouldn't pay anything over 2-3 hundred. The 205's are tough and reliable but cost lots to fix. I'm in the process of rebuilding mine and I'm into it for over a grand.
06-19-2009, 02:02 AM | #3 |
If it were me I would get an NP 241 out of a later model Chevy. They have a passenger side drop, are light stong, cheap and plentiful. Plus the NP 241 has a 2.72 low range. GM transmissions only have 2 spline counts on the later ones 27 splines on the 350 and OD &00R4 and 4L60E transmissions and 32 splines on the 4spd manual and 400 turbo and 4L80E. You can change the output on a 465 4 spd to a 32 spline from the old 10 spline pattern.
06-19-2009, 05:41 AM | #4 | |
Tim |
06-19-2009, 05:41 AM | #5 |
I can't even begin to fathom how you could put over 1K into a 205.
Tim |
06-19-2009, 08:59 AM | #6 |
since gas prices jumped the "old" 4x4 stuff has dipped in value, I see 205's going for a couple hundred everytime I look, The D44 is is not really sought after anymore, most wheelers have a couple taking up space from there D66 swaps. I would say a hundred on one is a fair price?
I just bought a complete Suburban frame, 350 SBC/turbo 350, 305 TC, D44/12 bolt, 4 almost new 31/10.5 tires, and a body with title to scrap,with a ton of parts for 500.oo. I sold a 69 3/4 ton running gear 4.11's ,305 Tc, 4 speed, and stripped junk cab for 600.oo last summer? |
06-19-2009, 11:33 AM | #7 | |
Most guys who are upgrading are going the 203/205 doubler and Dana 60 rear end for durability. That doubler is over 200 lbs, a 203 is 200 lbs by itself. an NP 241 weighs 80 lbs and is strong enough for GM to install behind big blocks and diesels. For my money and the kind of 4 wheeling I do the 241 is perfect. I have a 700R4/NP241, driveshafts and a complete 27 spline 203 in the back of my truck now I got for free, just for helping a guy install a turbo 400 and a 203/205 doubler in his Blazer. Out west the 203/205 and Dana 60 front axles are the stuff that commands premium prices. The HD 44 front axles you can get for free a lot of times and never pay more than 100 dollars for one. Same with the 241, cheap, cheap, cheap. I am taking the 700R4/241 and installing it in my 1976 3/4 ton 4x4. It will replace a 350/203. I don't know where Mogadore is in Ohio, I grew up in Toledo. If you are in southern Ohio it may be easier to find. Last edited by justcuz; 06-19-2009 at 11:37 AM. |
06-19-2009, 03:48 PM | #8 | |
27 Spline input shaft - 145.00 Updated rear output shaft - 210.00 TH350 adapter plate - 100.00 (old one was cracked) Shift forks X2 - 75.00 ea. Shift collars X2 - 50.00 ea. I thought hell while I'm at it I might as well as convert the front output to a 30 spline, seeing how the 10 spline will be the weak link now. 27 Spline adapter between the tranny & t-case - 115.00 I think the rest was spent on MGD |
06-19-2009, 05:35 PM | #9 |
Bloodied Knuckles
wiw 1st post!! nice!!!
06-19-2009, 06:20 PM | #10 |
You can get 205's for about 100 bucks at the swap meets around here. I would much rather have a 205 than a 241, but to each his own.
06-19-2009, 08:26 PM | #11 |
69 came with closed knuckle d44 with drum brakes and rockwell t case. 205 were not used untill 1970.Location location location on wiw.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
06-19-2009, 08:59 PM | #12 | |
He's exactly right.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
06-19-2009, 09:32 PM | #13 |
My 69 had Disc brake big hub D44 8 lug, and a 205, Remember very few trucks are stock now after 40 years,
06-20-2009, 05:06 AM | #14 |
I think '69 was a split year for the front axles and t-cases. I know for sure that '69 Blazers (mid-year introduction) came with open knuckle drum brake front axles and NP205s. No closed knuckle axle or Rockwell case ever came in a Blazer.
Tim |
06-20-2009, 10:44 PM | #15 |
yea im not exactly sure what the transfer case is... ill take a picture and post it
06-21-2009, 07:47 AM | #16 |
Here in The Buckeye State there not worth mutch. Your very lucky to get $100 out of a 44 with discs and the NP205 about $200 but only if it's a 32 spline!
1949 Five Window, 1973 Step Side, 2000 Z71 |
06-21-2009, 09:43 AM | #17 |
Post Whore
Assuming it is the closed knuckle Dana 44 that is pretty worthless. Anyone wanting to buy a Dana 44 will want an open knuckle with disk brakes. The closed knuckle has a terrible turning radius compared to the open knuckle axle.
Assuming it has the Rockwell transfer case that is probably worth a bit to someone who has damaged their Rockwell and want to stay stock for an easy swap. I'd say it is worth $100 to $200 to the right buyer. Here is what a Rockwell looks like And here is what a closed knuckle axle looks like
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
06-21-2009, 11:56 AM | #18 |
That one is married to the trans right? I think they only did that for a year or two with the Rockwell. Since the Rockwell is not that desireable, it may not be worth much, but to a purist restoration guy that is gold right there!
Anybody know for sure what 67-69 t-case setups were? My recollection is prior to 67 all were divorced and Rockwells. 67-69 used a few different t-cases, Dana 20's, Rockwells and 205's as I recall some married, some divorced. After 1969 (starting 70 model year) all were married and either 205's or 203's. I ask because I recall a 1967 1/2ton 4x4 we had on base in 1972/73 that had a 6,3spd. and a divorced Dana 20 in it. We used it (mainly) to tow those big purple K extinguishers back and forth to the flight line. Too bad rockwell did not design the rear output to come out of the top, instead of the bottom. The rear driveshaft was always too low in my opinion. Last edited by justcuz; 06-21-2009 at 11:58 AM. |
06-21-2009, 04:27 PM | #19 |
its an open knuckle axle and it is definatly a np 205
06-21-2009, 06:38 PM | #20 |
Are you trying to sell these items?
If so then I suggest that you become a paid subscriber to the board in order to post it.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
06-21-2009, 09:58 PM | #21 |
i mean i will sell them but ill probably end up putting it on craigs list... its a whole truck with a clean title
09-02-2009, 10:16 PM | #22 | |
In reality, if you're not converting; Bearing & Gasket kit - 150.00 <-this should be all you need 27 Spline input shaft - 145.00 <- not needed Updated rear output shaft - 210.00 <- not needed TH350 adapter plate - 100.00 (old one was cracked) <- not needed Shift forks X2 - 75.00 ea. <- not needed unless they're damaged Shift collars X2 - 50.00 ea.<- not needed unless they're damaged 27 Spline adapter between the tranny & t-case - 115.00<- not needed Standard rebuild parts costs (IMO) --> $150. If you need the forks and collars --> add $250. If you want to convert to 27 spline --> add $570 I did find my adapter's coupler sleeve was damaged, that ran me an extra 90. bucks... so $250. out the door for me.
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
09-03-2009, 12:22 PM | #23 |
205's were not produced until 69
ron |
09-03-2009, 01:32 PM | #24 |
I looked at a 69 K20 former brush fire truck with a 307, sm465, np205, ho52, closed knuckle d44. My point is that the sm465/np205 combo came in the 69s as well as Rockwell t221s. I'm thinking that some of the late t221s were mounted to sm465s.
Currently truckless, previous trucks: 67 K20, 87 K10 aka V10 & 72 C10 |
09-03-2009, 05:24 PM | #25 |
Page intentionally left blank.
Ahhhh, the real "nuts and bolts" of the cost!
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams '67 GMC 4x4, 305 V6! Or all the parts for anyway... '17 Subaru Outback. '18 Toyota Tacoma TRD Off Road. '99 Ducati 900SS. |
