Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 99-06 Chevy and GMC Message Board
Old 06-25-2009, 09:04 PM   #1
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
removing clutch fan from 5.3
I know this is kind of the wrong thread but i figured this was the best place. My buddy has a 02(i think) gmc sierra. He's trying to remove the clutch fan and he can't figure it out. I'm trying to help over the phone since he lives in Tulsa, Ok and I'm in Omaha, Ne. Any help would be great. Thanks.
stealthy '69 is offline   Reply With Quote
Old 06-25-2009, 09:20 PM   #2
68 short step
Re: removing clutch fan from 5.3
if he doesnt have the "tool" that keeps the waterpump pulley stationary......what he can do is
-keep the serp. belt on
-clamp some vice-grips on the waterpump pulley.
-then rotate the fan clutch (to remove it)....the vice-grips will keep the pulley from spinning when it comes in-contact with the belt....what part of t-town?
68 short step is offline   Reply With Quote
Old 06-26-2009, 02:31 AM   #3
stealthy '69
'69 Chevy SWB
Cool thanks I'll let him know his options. I'm not sure if he's even gonna be removing it. He planned on putting an electic fan on it, but I think he's rethinking this. Oh by the way, he actually lives in Oakhurst, right outside of Tulsa.
Old 06-29-2009, 03:44 PM   #4
treman03
treman03's Avatar
I could never get mine off by holding it. I had to get a long bar, put it on the nut and hit it with a hammer to break it loose. Sounds bad but it didn't hurt a thing. Electric fan worked great on it also.
treman03 is offline   Reply With Quote
Old 07-01-2009, 12:08 AM   #5
LEEVON
LEEVON's Avatar
Don't know how I came up with this but I've changed water pumps a few times on 5.3's and I always take a double-loop of rebar tie wire, wrap it through the fan pulley then around the water pump and remove the nut. Works like a charm!
'17 Sierra Regular Cab ~ '15 Challenger R/T Scat Pack 392 ~ '11 Escalade ESV ~ '71 Cheyenne swb ~ '66 Country Sedan ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-25-2010, 05:53 PM   #6
Slammed67
Progress = 0%
Slammed67's Avatar
Thanks for the tip LEEVON. I just replaced my water pump gaskets and your trick worked like charm. However, I had use a quadruple-loop of wire because two strands kept breaking.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 09-25-2010, 08:19 PM   #7
truckdude239
truckdude239's Avatar
need a tool like this to hold pulley then the wrench for the fan bought ym set from snap on for 117 buxs come with pulley holder and 5 or 6 wrenchs for the fan clutchs
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
2003 Honda Accord 109k( brothers car)
2002 Sububran 5.3 225k
2000 Tahoe 5.3l 369k
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-26-2010, 12:00 PM   #8
Boog
primer is finer
Boog's Avatar
Having the right tool for the job is always better but not always practical for the shadetree to buy tools he may only use once. So we have to resort to improvisation. "necessity is the mother of invention" somebody once said.
Boog
69 Chevy stepside, 358/T350, 4.10 posi, 4.5/4 drop, rallys, poboy driver
09 Yukon SLT 4wd, 06 GMC crewcab Z71 5.3, 4.10
All GM..'nuff said,
Member of Jr Nation 88
Old 09-26-2010, 01:31 PM   #9
Thealien
Thealien's Avatar
I took an 18 inch 1" X1/8" piece of steel I had laying around. I welded a bolt through at the end closer to one side. I place the bolt through one of the 4 holes in the pulley and use a wrench on the clutch fan hex. While turning the hex in the direction to remove the fan the flat stock will brace against the hex enough allowing you to break it free, once loose I remove the flat bar and you can remove it the rest of the way because the belt will hold the pulley enough for removal.
Worked for me anyway.
Old 10-04-2010, 03:37 PM   #10
Shon
I just take my adjustable wrench, get it on the nut and wack with hammer. not to either side, straight down, loosens it and off it comes.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 10-04-2010, 05:07 PM   #11
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Run to to the parts store and borrow the tool.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
