Old 07-10-2009, 08:02 PM   #1
Neon Beach
Dual Fuel Tanks
I have TBI, does that mean dual fuel pumps as well?
Former vehicles:
1978 Camaro Z/28
1973 Camaro Type LT
1969 Camaro
1986 Chevy Wrangler
www.uvtalk.com
www.rustfreerides.com
www.talktimmins.com
"Cops already? What are we, beside a Krispy Kreme?
Neon Beach is offline   Reply With Quote
Old 07-10-2009, 08:46 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Dual Fuel Tanks
Yes You have a pump inside of each tank. The fuel selector switch/valve also switches power to the appropriate pump when needed.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 07-10-2009, 08:48 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Dual Fuel Tanks
^^ Word.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-10-2009, 08:51 PM   #4
Neon Beach
Re: Dual Fuel Tanks
That's what I suspected. I have been running on the left tank most of the time and then it started running like crap. Hard to start, surging and sputtering from a stop. Switched to the right tank and it's much better.
And who was the genius that decided the pumps had to go inside the tanks?
Former vehicles:
1978 Camaro Z/28
1973 Camaro Type LT
1969 Camaro
1986 Chevy Wrangler
www.uvtalk.com
www.talktimmins.com
Old 07-10-2009, 08:57 PM   #5
BLE 'BURBAN
Re: Dual Fuel Tanks
THe pumps are kept cool by submerging them in the fuel.Also since they are designed to PUSH THE FUEL ranther than pull it, the closer to the source the better.
Old 07-10-2009, 09:02 PM   #6
Neon Beach
Re: Dual Fuel Tanks
Maybe so, but what a nightmare to change compared to a mechanical pump from days gone by.
Former vehicles:
1978 Camaro Z/28
1973 Camaro Type LT
1969 Camaro
1986 Chevy Wrangler
www.uvtalk.com
www.talktimmins.com
Old 07-11-2009, 11:42 AM   #7
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Dual Fuel Tanks
this is what you have to look forward to....
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 07-11-2009, 12:27 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
Re: Dual Fuel Tanks
I've unbolted the tank from the frame and dropped them down. I just disconnected the lines from the selector valve and pulled them over the frame when dropping the tank. Of course this is on an older carbureted truck.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 07-12-2009, 07:25 AM   #9
Tony_SS
Tony_SS's Avatar
Re: Dual Fuel Tanks
Are you serious? I have to pull the whole bed off to drop the tank? No way..
Tony_SS is offline   Reply With Quote
Old 07-12-2009, 08:48 AM   #10
68 TT
Still plays with trucks
68 TT's Avatar
Re: Dual Fuel Tanks
You don't have to pull the bed to drop the tank. You pull the bed instead of dropping the tank. It allows you access to the pump without unbolting the tank at all. A big plus if you have a 35-gallon tank nearly full of fuel that weighs over 200 pounds.
Pulling a few bolts off and lifting the bed is far easier than dropping the tank and takes far less time.
Dropping the tank is all the Suburban / Blazer guys have to look forward to.
Don't waste your time on any cheap off brand fuel pumps. I have seen far too many that were DOA or worked very poorly after installed right out of the box.
Get an AC Delco pump and avoid having to do this job twice.
I used it as an excuse to clean up and paint the frame & rear end while the bed was off. I probably removed five pounds of off road debris from the top of the fuel tank.
68 TT is offline   Reply With Quote
Old 07-12-2009, 04:21 PM   #11
BLE 'BURBAN
Re: Dual Fuel Tanks
I plan on making an access hole in the back of my Burb so I can get to the top of the tank to service the fuel pump without dropping the tank. I've got the idea's in my head so I know what I want it to look and work like. When I do finally get around to doing it, I'll post pics and a write up of it. But probably not until next summer.
Old 07-13-2009, 03:40 PM   #12
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Dual Fuel Tanks
This is how I changed them/drop the tank:
http://forum.73-87chevytrucks.com/sm...p?topic=9294.0
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD)
Captkaos Customs
Old 07-13-2009, 04:09 PM   #13
babyJay
babyJay's Avatar
Re: Dual Fuel Tanks
I didn't take the bed off, I just raised it (making sure I braced it good between frame and bed) up to access the fuel lines / pump assemblies. My Cat was right smack dab in the way of the bolts on the inside of the frame that held the tank brackets on, Impossible to get to.
I removed the nuts completely for the front-most bed bolts, and merely loosened the nuts on the 2 back bolts a good inch or more so the bed wouldn't shift around a lot.
Either route you take, it is bound to be no fun. Good Luck.
Jason
89 R3500 CC SRW
Old 07-13-2009, 04:28 PM   #14
Pyrotechnic
Re: Dual Fuel Tanks
This is the same method I used and it worked really well.
Old 07-13-2009, 09:07 PM   #15
Adams74Chevy
Adams74Chevy's Avatar
Re: Dual Fuel Tanks
My dad and I undid the straps instead of that way and well we were not having so much fun.
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2012 Kia Forte - cheap rice burning DD
Adams74Chevy is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
