Old 07-15-2009, 08:00 PM   #1
60ratrod
yes, i do
60ratrod's Avatar
stock 305 heads max lift
i was wondering what the max lift on a stock 305 head was?? cause i have already changed out the springs, locks and retainers to the ones listed as required/recommended for the comp cams xe268h. will i need to take them in to get machined for more lift or should i be fine?
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 07-16-2009, 07:20 PM   #2
Chevypoor
Chevypoor's Avatar
Re: stock 305 heads max lift
You need to measure this clearance. With valve springs off (exhaust and intake on #1) install the valves. Then install the valve seals. It helps to have a valve spring micrometer as it makes this alot easier. If you are carefull you can hold the valve tight on the seat while holding the retainer and the valve locks up in their groove. Now measure with a small rule the distance from the valve seat to the bottom of the retainer. Take the retainer off the valve and measure the how far the valve lock pocket projects below the bottom of the keeper. Measure the distance from the spring pocket to the top of the valve spring seal. Now add these last two measurements and then subtract this number from the distance from the valve spring pocket to the bottom of the retainer. This is your clearance from the valve seal at zero lift. Multply your rocker ratio times the gross lobe lift on your cam card. This your max valve lift. Subtract your max valve lift from your zero clearance. If you have atleast .070 left you are good. If not then you need to have your guides turned down until you achieve .070 clearance.
1990 S10 Reg. cab 2wd 2.5/ 700r4, lowered, soon to be a TBI 350/ 700r4
1993 2500 Reg. cab 4wd 6.5 turbo diesel/ 5spd, bigger turbo, Bull Moose pump, cold air intake, and a few other mods
1969 C10 Reg. cab 2wd 305/350, RHS heads, Voodoo Cam, Gilmer drive, 2400 stall, and lots of other goodies!
Chevypoor is offline   Reply With Quote
Old 07-16-2009, 07:51 PM   #3
purewhitemp5
The machine shop said with stock springs the max I could do was .480 with 305 heads.
purewhitemp5 is offline   Reply With Quote
Old 07-16-2009, 08:42 PM   #4
60ratrod
yes, i do
60ratrod's Avatar
well if 100% stock lift is .480, then i should be sittin pretty since i have swapped out to comp 981 springs(recommended/required for the xe 268h), but since i still have yet to install the springs on the other head then i'll do the measurements just to be safe. i gotta go to the LPH anyway to get some other items so i'll see if they have a micrometer and all that. i gotta get some easy outs since i found a broken bolt in one of the end exhaust bolt holes
Old 07-17-2009, 05:36 AM   #5
Chevypoor
Chevypoor's Avatar
The clearance of .070 is without the seal. With the seal I believe it is .040. Sorry about that... brain fart!
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
