Old 07-18-2009, 09:32 PM   #1
jess66chevy
LMC rear gas tank install
Has anyone done a LMC rear mounted gas tank? I bought it as a kit but there was no instructions. This is how it came out when I did it. Of course, there had to be alot of modification.
jess66chevy is offline   Reply With Quote
Old 07-18-2009, 10:20 PM   #2
70 Suburban
Rods
Re: LMC rear gas tank install
would be nice if you did a install tech kinda thing...
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 07-19-2009, 07:13 AM   #3
Apache63
1# Drobmember in Germany
Apache63's Avatar
Hereīs a few picīs of my LMC Gas tank kit!
thatīs my way to install the tank!!
Pat
Apache63 is offline   Reply With Quote
Old 07-19-2009, 10:08 AM   #4
70 Suburban
Rods
nice install. what did you have to do to get it in there
Old 07-19-2009, 11:16 AM   #5
joe231
joe231's Avatar
that looks nice fellas!!!!
CHEVY ONLY
Old 07-19-2009, 12:20 PM   #6
Apache63
Apache63's Avatar
thatīs really simple , put the tank under the frame , put the metal straps in place and bolt on the straps on the left side of the frame , on the right side of the frame drill two holes in the underside of the frame , drill upside two larger holes in the frame (see pic #2,it shows the passenger side with the two larger holes), put the bolt from the straps thru the frame on the right side and put the fasteners thru the frame on the bolts ! DONE!!!!!!
i hope you understand what i want to say!
Pat
Old 07-19-2009, 07:13 PM   #7
apachedaddy
apachedaddy's Avatar
apache63 the tank looks great but your going to run into issues when you go to install the bed. The first cross sill in front of the rear will hit the tank and fill neck without a ton of mods. jessy66 in the first pic has the right idea with the flush top mount. Hope it all works out for you.
apachedaddy is offline   Reply With Quote
Old 07-19-2009, 07:44 PM   #8
creep
Registered Loser
creep's Avatar
Attachment 479930
I don't know if that notch is a good idea. Seems like it would make the frame really weak.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 07-19-2009, 10:15 PM   #9
Captainfab
60-66 Nut
IMO the way Apache63 did his is the best way to install them regardless of bed crossmember interference. That can be dealt with. I would rather have the tank as high as possible. Just my .02
Old 07-19-2009, 10:20 PM   #10
jess66chevy
I had to cut the frame a little bit for the gas filler neck. The bed went on with no problems with the gas tank flush mounted.
Old 07-19-2009, 11:45 PM   #11
joe231
joe231's Avatar
CHEVY ONLY
Old 07-20-2009, 10:22 AM   #12
Chevy Fleetside
Chevy Fleetside's Avatar
Mine is done like Apache63. Some pictures are here. http://s49.photobucket.com/albums/f2...ucks/?start=40
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Truck pictures: http://s49.photobucket.com/albums/f2.../The%20Trucks/
Chevy Fleetside is offline   Reply With Quote
Old 07-20-2009, 10:49 AM   #13
ol Curt
Junior Member
ol Curt's Avatar
"thatīs really simple , put the tank under the frame , put the metal straps in place and bolt on the straps on the left side of the frame , on the right side of the frame drill two holes in the underside of the frame , drill upside two larger holes in the frame (see pic #2,it shows the passenger side with the two larger holes), put the bolt from the straps thru the frame on the right side and put the fasteners thru the frame on the bolts ! DONE!!!!!!"
Huh?
I think I need to see a close up of the bolts/holes!
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 07-20-2009, 11:01 AM   #14
Fred T
Cantankerous Geezer
Fred T's Avatar
You committed a major structural no-no with the way you cut the frame. I was looking at that last night, trying to come up with a solution that was feasible.
My first choice would be with a piece of round tube, say 4 or 6" diameter, welded to the inside of the frame. Something like the attached sketch.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-20-2009, 12:15 PM   #15
apachedaddy
True statment about the hight, but if it was me i would rotate the tank 180 so the filler neck is not over the mounting hole for the cross sill. Then the only mod would be to notch the center part of the sill.
Old 07-20-2009, 12:29 PM   #16
ol Curt
Junior Member
ol Curt's Avatar
Wouldn't that make it exiting very near the wheel well on the passenger side?
Old 07-20-2009, 12:46 PM   #17
joe231
joe231's Avatar
Huh?
I believe what Pat is saying, correct me if I'm wrong Pat, on the first side you have access to tighten the strap bolts but once the tank is in the way he didn't have the access he needed to tighten the bolts so he drilled two larger holes in the top of the frame rail so he could get a socket and extension in there to tighten the bolts on the lower side of the frame that holds the straps in place.......follow?
CHEVY ONLY
Old 07-20-2009, 12:59 PM   #18
Apache63
Apache63's Avatar
Yes , Joe youīre right !!
iīll take this week some picīs from the frame and tank!
the bed is already mounted and i fits perfekt !
but one cross sill i cut it into place to fit the gas filler neck!
picīs can say more then 1000 of words!!
Pat
Old 07-20-2009, 01:05 PM   #19
joe231
joe231's Avatar
cool!
can't wait
CHEVY ONLY
Old 07-20-2009, 01:09 PM   #20
Apache63
Apache63's Avatar
cool!
can't wait
iīm fast like a bullet!!!!
found some picīs on my PC , i hope it helps!!!
Pat
Old 07-20-2009, 01:15 PM   #21
joe231
joe231's Avatar
Pat, have you been holding out on us, or did I miss that you have a truck too?????
CHEVY ONLY
Old 07-20-2009, 01:30 PM   #22
Apache63
Apache63's Avatar
here take a look on my 63ī Longbed
http://67-72chevytrucks.com/vboard/s...107362&page=18
Pat
Old 07-20-2009, 01:39 PM   #23
ol Curt
Junior Member
ol Curt's Avatar
Ok, I get it now. If you knew or had marked the spots for the bolts couldn't you just place the bolts in the hole with the threads down and weld the head of the bolt to the frame without having to put more holes in the top of the frame?
Old 07-20-2009, 01:52 PM   #24
joe231
joe231's Avatar
i remember now!!
nice truck!
Pat
yeah, or even weld nuts on top of the lower lip of the frame.
CHEVY ONLY
Old 07-20-2009, 01:54 PM   #25
Apache63
Apache63's Avatar
i think it is possible to weld the boltīs to the frame !
but i donīt know if it is the best way !
so i only can say try try try which way is the best way for you!
Pat
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
