Old 07-27-2009, 10:54 PM   #1
OrrieG
OrrieG's Avatar
Sanderson compressor same mounting as GM?
My donor truck came with a factory AC compressor assumed to be non-functional since it was residing in the bed. My used Vintage Air system uses a Sanderson Compressor. Question is will the GM brackets work for the Sanderson? Thanks
OrrieG is offline   Reply With Quote
Old 07-28-2009, 07:28 AM   #2
blackdiesel
blackdiesel's Avatar
Re: Sanderson compressor same mounting as GM?
Don't think so. New brackets come with the vintage air kit to put the conpressor on the motor. If you didn't get them with your use unit. Check out Alan Groves brackets, They make brackets for anything.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 07-28-2009, 08:25 AM   #3
Houston54
Vintage air has a bracket that will adapt the Sanden style compressor to the GM bracketry or even to their serpentine set-up if that is what you are running. I believe Alan Grove is the manufacturer of the brackets.
Houston54 is offline   Reply With Quote
Old 07-28-2009, 11:25 AM   #4
OrrieG
OrrieG's Avatar
Thanks for the replys, it confirmed that you toss the stock stuff. VA also has instructions for and modifing the PS bracket to fit (for a 74 setup which I am using). I am taking the Harrison compressor I have by a AC shop to see if it can be tuned up and converted for R134 for less than a new one.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
