Old 07-30-2009, 03:29 PM   #1
Rob73-87
Rob73-87's Avatar
Chevy Small Block: 336 338 340 ???
Hi,
I have a bunch of old tired 305 cui small blocks (at least 4 !!) and I read about putting stroker kits (eagle) in them to get CIs like shown above...depending on overbore.
Now - what do you think about that? What about a 340ci ?
I know building 383s and similar stuff does make more sense - BUT I want to do something with those 305s.....
I can`t wait to hear your suggestions .... !
So just feel free to drop a line or two !!
Rob
1982 C-10 SWB (soon dropped, 383ci, but restored stock appearance)
1984 C-10 LWB, dropped, custom paint
1996 Plymouth Voyager (Daily Driver "The Mule")
2008 Caliber R/T (Daily Driver)
Rob73-87 is offline   Reply With Quote
Old 07-30-2009, 03:35 PM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Chevy Small Block: 336 338 340 ???
I hate to be the negative nancy....but you're still stuck with those tiny 305 bores, and SBC 23* heads have a hard time making power on them. I personally wouldn't ever dump a dime into a 305 when 350 blocks are so plentiful. Not saying you can't make a strong engine that way, but you'd have a much stronger motor spending that same amount of money on a 4"+ bore motor......
Now if you're just looking for something to do with an old 305......spray it till she pukes.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 07-31-2009, 12:09 AM   #3
texasfunk
texasfunk's Avatar
yea, i agree, the machine shops have so many 305's around here that they just use them for bolts now, and theres no making power with them, 350's are still plentiful and can be had pretty cheap, just a thought
texasfunk is offline   Reply With Quote
Old 07-31-2009, 12:20 AM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
No replacement for displacement. 350 rotating assemblies can be had all day long on craigslist for $100. Take the 4 305 blocks to the scrapper and you'll have enough money to buy one!
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-31-2009, 12:24 AM   #5
tomtuna1978
if the 305s are running motors... get a pare of vortec heads(your gonna prolly get em for a 350 anyways) and a decent roller cam/valve train(again needed for a 350), and sprey em all till they blow likeswb85 said and when your done with all the 305s, youve had a lot of fun and learning that way when you build a real motor(350-400) you can swap the parts you alredy have and itll all bolt togather ! ... just my 2 cents
tomtuna1978 is offline   Reply With Quote
Old 07-31-2009, 12:29 AM   #6
texasfunk
texasfunk's Avatar
id keep a set of 305 heads tho, put em on a 350 and you get a little better compression
Old 07-31-2009, 12:54 AM   #7
3r!c84
Badass
3r!c84's Avatar
lol but they will flow like crap on a 350
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-31-2009, 01:09 AM   #8
texasfunk
texasfunk's Avatar
who says? granted, it is true to some extent, but, depends mostly on the intake you use i got a set on my el camino, 383, port and polished and bigger valves, had a victor junior, and had no power up top, but switched to a performer rpm, and gained some, heard a weiand stealth would give some more, but not sure, the elky is a street car anyways, no need for top end
Old 07-31-2009, 08:48 AM   #9
swb85
swb85's Avatar
Doesn't matter what intake you use......by the time you spend the money to make the 305 heads "decent" with porting/polishing, valves/valvejob.....you've spent more money than a set of stock vortecs cost.....and the worked 305's still won't outperform vortecs. The only parts from a 305 worth saving is the crank and tins.
Old 07-31-2009, 03:38 PM   #10
Rob73-87
Rob73-87's Avatar
And the crank is "balanced the wrong way" - the counterweight is for the smaller 305 pistons, so I can`t use the crank in a 350....
So I will NOT put any money in those things - but I will keep em - maybe one day I will get a 350 for them or I will just need a mill for comuting ??!
Anyway, - thanks for your opinions !
Rob
Old 07-31-2009, 05:37 PM   #11
slugish
Slugish
Wink Re: Chevy Small Block: 336 338 340 ???
The person who built my engine is an old school gearhead > about my age , around 60 . Also held many drag records in this area back when . He said some of his best times were had with 305 heads on a 350 in old corvettes. He did it for compression > would shave them all that they would tolerate > would extensivelly port & polish them & create a screamer . His reputation was known for his head work . Of course this was before all the technologically advanced head design ther is available now . thought this was intereting & wanted to share .
slugish is offline   Reply With Quote
Old 07-31-2009, 11:22 PM   #12
texasfunk
texasfunk's Avatar
this is true, but, dads friend owns a machine shop, so he did everything for $100, and i didnt want to spend $ on a set of vortecs, i only did it for compression reasons, and its a street car, the heads are good for the lower RPM's
Old 07-31-2009, 11:40 PM   #13
3r!c84
Badass
3r!c84's Avatar
well for that price your good
-00 Saturn 5spd
1/4:13:90
