08-24-2009, 01:30 AM | #1 |
what am i gonna run into body lifting....
ok,so i have a 4 inch lift for my 78 k10.i did 4" cause i didnt wanna have to extend driveshafts and all that good stuff,on a tight budget.
and i want to do a 3" or so body lift on it also for some good clearence on the 35" mud terrains i got. does body lift effect anything to do with the brake lines?will i have to extend them by adding the 3 inch body lift? whaty else will need to be done?i know the cumpers and radiator support. EDIT PICTURES------4 inch lift bfg 35 12.50 16.5 on eagle alloys. Last edited by dmartin1; 08-29-2009 at 11:33 PM. |
08-24-2009, 12:13 PM | #2 |
Re: what am i gonna run into body lifting....
brake lines yes maybe, you can buy the braded hose to go from the caliper to the hardline. also you will want to watch for the movement in you shifter(s). when you raise the floor it may cause the shifter to hit the floor faster in shift pattern because of the bend in the shifter. also steering shaft may have to be looked at.....fan shroud....watch for wiring not to get to tight (ground straps).....
that is all i can think of......i'm sure i missed something.......
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations) Perry, Ok. We're just two guys, trying our best. 72 cheyenne super https://67-72chevytrucks.com/vboard/...d.php?t=811512 55 chevy truck http://67-72chevytrucks.com/vboard/s...d.php?t=840174 Last edited by nvrsatisfied; 08-24-2009 at 12:16 PM. |
08-24-2009, 11:14 PM | #3 |
Grease Monkey
Brake line, no. There should be enough coiled up next to your master cylinder.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
08-25-2009, 01:05 AM | #4 |
And check the water hoses, But i think 35s fit with a 6in so you may only need a 2in body, I would check the lift/tire size chart, depends on how wide your tires are, do they fit now? And a pic would be cool, PIcs are cool.
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
08-25-2009, 11:35 AM | #5 |
more ideas than money
As stated above and add this:
Fuel filler, if you have a manual the clutch linkage will need to be adjusted.
Randy 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
08-25-2009, 11:53 AM | #6 |
huh ???
My blazer had 35's on it with just a 3 inch body lift when I bought it. They did rub the fenders at full turn though...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
08-29-2009, 10:39 PM | #7 |
yea,i was just mainly concerned with the whole brake line deal lol.those can be pretty costly,so ive heard.
yea im running only 4 inch suspension and am clearing bfg mud terrain t/a 35x12.50x16.5 on a 16.5 eagle alloy rim.worked out quite great. the rear lift cost me 30$(block) and the front was basically free,we took the overload springs off the back,cut a few inches off them,and used part of them for an add a leaf on each side.lifted it perfect,sits about 3/4 higher in the front,but its exactly where i wanted it. entire lift cost so far--- blocks 30$ u-bolts FREE front lift-FREE rims and tires-200$ not bad eh? ill have a few pictures of it with soemthing so you can see the heighth |
08-30-2009, 10:59 PM | #8 |
Bumpers will be a little low unless you make/buy brackets for them...or leave them as is...
I think everything has been mentioned except the fan shroud, you have to cut the bottom out..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-31-2009, 08:16 PM | #9 | |
Most of it has been mentioned already,but maybe some more detail is needed.
Brake lines- no, there is plenty coiled under the master cylinder, they will stretch out fine. Steering column- It will slide apart enough, but it may take some encouragement with a hammer. Fan shroud- is definately in the way. It is two pieces that are stapled together. A lot of guys just remove the lower half, but that can cause overheating problems. Lowering the bottom half and tying it back to the upper with some kind of spacer is far better. Fuel filler hose- Usually you just cut the rubber hose and splice it back together with a piece of steel tubing. Ground straps- most of the time there is enough slack, sometimes you need to move them closer. Transmission- Automatics need to have the linkage between the column and bellcrank extended by 3". Saw it in two and weld in a piece of round stock. Manuals need the same piece of round stock welded into the linkage between the pedal and the bellcrank. Radiator hoses usually have enough slack, sometimes they need to be loosened and rotated upward. Transfer case shifter- usually the hole needs to be enlarged in the floor. That's all I can think of right now...it looks worse than it is.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
