Old 09-03-2009, 07:08 PM   #1
rage777
rage777's Avatar
electric cooling fan
i have a 72 c10 with a 402 BB. i currently have a standard non clutched fan. my shroud is a bit beat up and the top mounting tabs broke so i had to mount it a little higher than normal. this has given me a gap between the radiator and the shroud at the top. not good for air flow. i want to switch to electric fans but as we all know they are pretty expensive. i have seen a few posts on getting elec. fans at the junkyards. i'm just unsure what year/model i should be looking for. am i better off just spending the $300 + on a new setup?
1972 Chevy C10 Long Bed
454 Big Block
Turbo 400 3 Speed
Dual Flowmaster
Edelbrock 750 Carb
Power Steering
Disc front brakes
Drum rear brakes
B&M Floor Shifter
rage777 is offline   Reply With Quote
Old 09-03-2009, 07:30 PM   #2
big_al_71
big_al_71's Avatar
Re: electric cooling fan
Spend the money and get your self a dual flexalite one time expense...Miami summer 95 degrees hot as hell a/c on and a fully built 406 and my engine does not go past 160 degrees.....Trust me!!!!
Aluminum four core radiator to boot.....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-03-2009, 07:44 PM   #3
mclairmo
IMO, you should buy a new/used shroud, buy a new clutch and buy a new/used clutch fan. Will probably cool better than most electric fans and will cost a little less.
mclairmo is offline   Reply With Quote
Old 09-03-2009, 07:44 PM   #4
cparman
sharp as a marble
I am getting ready to order a non polished Stainless cooling fan shroud from CLASSIC HEARTBEAT. The add says the it will accept two 12" cooling fans. My plan is to buy the shroud, buy two 12" 1630 CFM SPAL cooling fans, and a SPAL controller to see if I can suck the chrome off the front bumper. Yes this an expensive way to go. My last car had two 11" spal fans on it and it would " keep up " with NE FLA heat, but did not help the ZZ502 be cool. Do your homework, and understand the wiring to the controller, and the 12" fans. Truck will run cool, and so will you.
cparman is offline   Reply With Quote
Old 09-03-2009, 09:09 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i wouldn't bother either. Get the proper clutch assembly and shroud and call it good for another decade or two
Old 09-03-2009, 10:07 PM   #6
BCOWANWHEELS
electric fans are nothing but expensive and troublesome and they dont cool from my experience. i have a brand new electric fan i,ll sell you CHEAP.....
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-03-2009, 10:18 PM   #7
jugernot
Life, Be In It.....
jugernot's Avatar
Here is a write up from another member. I bought a similar set up, but have not hooked it up yet.
http://67-72chevytrucks.com/vboard/s...d.php?t=216128
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 09-03-2009, 10:27 PM   #8
2tons of fun
the square ford tuarus fans are real good 2 speed units, make sure you grab the relay that goes with it, they will draw an ass load of juice to start up.
the volvo fans are bigger one speed square fans and dont draw as much but you will still need at least a 30amp relay.
i ran 2 kragen specails as pushers, black majic or some knock off and was happy, they are a open fan body, no shroud.
2tons of fun is offline   Reply With Quote
Old 09-04-2009, 01:27 AM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
You can use a 95 XR7 4.6 2 speed fan. Same as the Mark VIII. Its almost a drop in deal. Rock auto has the fans for about $80. I put one in my truck and it works great
http://www.thehollisterroadcompany.com/MarkVIII.html
dwcsr is offline   Reply With Quote
Old 09-04-2009, 08:25 AM   #10
1-PU70
1-PU70's Avatar
I just did the Ford Contour fans in my Jeep. It has a mild 350. I was running a 7 blade fan with a clutch. It doesn't cool any better or worse then before but one side affect was it made way less noise then before. Even with both fans running its way quitter then a stock fan and clutch. Something to think about.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
