Old 09-23-2009, 07:38 PM   #1
Number21
Number21's Avatar
70's 1 ton VS early 90s 1 ton trucks?
As I understand it they kept the square body on the 1 ton trucks until 1991, right? I'm curious what the differences and upgrades might be between the 73-80 style truck and a 1991 model? Did the frame ever change?
I'm starting to restore my '79 1 ton, but I'm thinking I might be better off starting with the newest one I can find. I know people like to swap the early 90s front end onto the older trucks, but I prefer the 73-80 body style. Would it be just as easy to swap an old front end onto the newer truck?
Number21 is offline   Reply With Quote
Old 09-23-2009, 09:45 PM   #2
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Re: 70's 1 ton VS early 90s 1 ton trucks?
The only big differences(to me) other than obvious body and grille changes in the newer trucks is in 1985 GM started using a hydraulic slave clutch instead of the mechanical linkage used on 1973-1984, and in 1987 TBI(throttle body injection) came out and replaced carburetors. I don't believe the frame itself changed, just different length wheelbases.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 307/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 fire truck 478M V6/5 spd 1200 gallon pumper
Robert1970C20rstbukt is offline   Reply With Quote
Old 09-23-2009, 10:34 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
It really depends on what your goals and priorities are. If you can find a clean late model 1 ton you might save a lot of time and money.
You will need the entire front clip, core support, and frame horns to do the 73-80 conversion.
Articles-
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-23-2009, 10:58 PM   #4
dan76
Older one tons are cooler; but the newer models feature extended cabs..... which are nice for families.
dan76 is offline   Reply With Quote
Old 09-23-2009, 11:02 PM   #5
Dooley
Dooley's Avatar
While GM continued to make 4 door square body trucks until 91 the 1988 model year was the last year for 2 door square body pickups and this was in 4 wheel drive only.
Here is a pic of my 1988 V30 2 door regular cab pickup built in May 1988.
Dooley is offline   Reply With Quote
Old 09-24-2009, 03:38 AM   #6
nekkidhillbilly
also got the 4l80e on the last year
2004 2500 hd dmax cc 4x4
2008 saturn aura xr
1966 buick gran sport
1984 k20
nekkidhillbilly is offline   Reply With Quote
Old 09-24-2009, 04:06 AM   #7
Number21
Number21's Avatar
Ahhh...poop. I was hoping I could find a 2 door 2WD '91 on craigslist. Just hoping for something that hasn't been sitting out in a field for quite as long as mine has. My '79 is still a pretty good starter for a restoration though. I plan on buying a few more old junkers and parting them out to get everything I want...
Old 09-24-2009, 07:53 AM   #8
Keith Seymore
Keith Seymore's Avatar
Dooley - is your truck VIN'd and registered as a 1988 model year vehicle? Does it have 1988 (or 1987) model year literature in the glove box?
I thought 1987 was the last model year for 2 door R/V pickups.
Everybody - there were no (significant) frame changes between '73 and '91 for the C/K/R/V models, btw.
K
Chevrolet Flint Assembly
1979-1986
1986 - Present
Old 09-25-2009, 01:42 AM   #9
Dooley
Dooley's Avatar
K
My 1988 V30 2 dr regular cab pickup is just that, a 1988 V30. It has 1988 in the Vin, in the glovebox, on the title, on the build tag, on the EPA sticker, and the door id. It was built in May 1988 and is mentioned in the 1988 R/V model literature.
Old 09-25-2009, 07:30 AM   #10
Keith Seymore
Ah - I think it's coming back to me now.
Maybe the breakpoint was not 2 door vs 4 door, but the last 1/2 or 1/2 and 3/4 tons were in '87 and we continued the "heavy duty" R/V trucks into 1988.
It's all a bit fuzzy. That was 20 years ago!
K
1979-1986
1986 - Present
Old 09-28-2009, 04:03 AM   #11
Dooley
Dooley's Avatar
K
My truck was built in Janesville. Here's a page from 1988 GMC R/V literature. It mentions the V series regular cab and that 4x4 and dual rear wheels were standard.
Old 09-28-2009, 07:23 AM   #12
Keith Seymore
Thanks. I remember now. It was the dual wheels that was significant.
So - '87 was the last year for R/V two door pickups with the exception of dual wheeled vehicles (GMT400 "LD" pickups introduced in 1988). The R/V Suburban and Blazer, and 4 door pickups carried on through '91 with the GMT400 versions being introduced in 1992.
Makes sense (...well, not really...).
K
1979-1986
1986 - Present
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
