Old 09-28-2009, 08:01 PM   #1
BIGBLU 72
BIGBLU 72's Avatar
6 lug disc brake conversion
Im sure that this has been talked about on here, but i have to ask. what are my options for swaping the 6 lug drums on my 68 for 6 lug discs. 5 lug discs are not an option! what will i need, how much is it gunna cost me and are there any pics?
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 09-28-2009, 08:05 PM   #2
Terakilla
Terakilla's Avatar
Re: 6 lug disc brake conversion
Try classicperform.com or any board vendor.
1970 Chevy C10 Short Stepside 4.3L LT
1965 Shelby Cobra AC 427 Comp Car
1965 Sunbeam Tiger 305
1984 Dodge D150 5.9L Magnum
1995 Dodge 3500 V10
1991 Ford 250 460
Terakilla is offline   Reply With Quote
Old 09-28-2009, 08:14 PM   #3
mclairmo
Buy a new kit, forget about piecing together a used set. I went with used stuff and cost me same as a new kit would have cost and took me way more time to complete.
mclairmo is offline   Reply With Quote
Old 09-28-2009, 08:16 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Try the parts board....VA72C10 has a nice setup for sale minus the Booster/MC/ prop valve....http://67-72chevytrucks.com/vboard/s...d.php?t=363986
Geoff with a G
1968 Chevy C10 SWB The Mistress FOR SALE
1972 Custom Deluxe C20 Suburban
Current Resto: 1966 Mustang-Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-28-2009, 08:24 PM   #5
lolife99
67-72 only
lolife99's Avatar
Look at Nate's truck,...
http://67-72chevytrucks.com/vboard/s...d.php?t=353633
Keith
Drum to Disc Brake Conversion Info Here:
60-62
63-66
67-70
Old 09-28-2009, 11:10 PM   #6
BIGBLU 72
BIGBLU 72's Avatar
Not really wanting to drop the truck or drop a load of cash ( im a college student and $500 is a load of cash to me LOL)...... any swaps from late model trucks?
Old 09-28-2009, 11:55 PM   #7
texanidiot25
Eat My Rust
texanidiot25's Avatar
For 500?
Junk yard 73-87 "heavy half ton" spindles, for the 1.5" wide disk brakes, matching calipers. Get 73-87 outter tie rod. Keep your stock tie rod end and use which ever has the correct threads. We believe on my truck that the tie rods were swapped in my truck's past and were put on wrong... But I used the 'stock' outer and '73-87 outter with teh CPP conversion tie rod sleeve. CPP 6-lug rotors. New brake lines. Put the 73-87 ball joints into your stock arms, and put in the 73-87 spindle, newly made conversion tie rod, and you can start driving there. Yes, it is highly reconmended to swap the MC and prop valve, but you can live with out it for the time beeing. I run the setup as is and I do pizza delivery. Trust me, this truck has NO problem coming to a stop. And it's seen a few thousand miles. Even in the wet it's still very stable and easy to work with out locking up. And far better than any drum brake setup can offer.
The disk brake MC and Prop valve can be pulled from a 73-87 donor, but it take a bit of work to make sure all the geometry works in the brake linkage in some cases. Or you can surf the board and find a good deal on a 67-72 setup as well. I got my MC and prop valve for $60 bucks. Just haven't had the down time to get to my dad's to swap it all in and put in some new hard lines (just to optimize the setup to it's best).
Spent maybe 400-500 and was dirt easy to do once you got the parts list figured out.
<PhillipT> And when I say "We" I'm referring to my dad and I... I am not crazy...
1969 Chevy CST/10 "OrangeCrush" Check it out!
Small Block 350, Turbo 350, former 6-lug D60 rear, now a 3.73 12 bolt And... RUST!
Paranoia is a disease unto itself, and may I add,
the person standing next to you, may not be who
they appear to be, so take precaution.
-Sathington Willoughby
texanidiot25 is offline   Reply With Quote
Old 09-30-2009, 11:15 AM   #8
BIGBLU 72
BIGBLU 72's Avatar
thanks! that sounds like the route that i will take on this project
Old 09-30-2009, 11:17 AM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I spent 4 times that amount on my ECE conversion, including rebuilding the front end....completely. Sounds like a very good plan....one I didn't have at the time.
Member Nr. 2770
'69 C-10 SWB; 350/TH400 - under reconstruction.
Old 04-13-2011, 04:56 PM   #10
clean68sbc
bigblue72 im having the same dilema swapping over just went and got 69or 70 spindles and bought sixlug rotor from lmc truck went to put em on the upper and lower balljoints are different sizen im in high school moneys tight so do i have to get the 69upper and lower balljoints?went to advanceauto 71-75 upper and lowers dont fit for somereason ? any help would be greatly appreciated. and waiting on the 69 balljoints to come in is there any difference between the 69 and like the other guy said 73-87 balljoint diameter???? pls help
clean68sbc is offline   Reply With Quote
Old 04-13-2011, 07:12 PM   #11
BIGBLU 72
BIGBLU 72's Avatar
Well i ended up saving my money for a complete kit but there are differenced between the 67-70 balljoints and then 71-72 ball joints i think? what year is your truck? im sure some one will jump in with more information on the subject
Old 04-13-2011, 08:17 PM   #12
lolife99
67-72 only
lolife99's Avatar
Lots of info here:
http://67-72chevytrucks.com/vboard/s...68&postcount=4
Most all questions answered.
If not,... ask away.
Keith
60-62
63-66
67-70
Old 04-16-2011, 12:22 PM   #13
clean68sbc
yes my truck is a 68 c10 heavy half ton
Old 04-16-2011, 01:20 PM   #14
lolife99
67-72 only
lolife99's Avatar
pls help
'69 balljoints will be the same as your '68 balljoints.
Ball joint break down:
UPPERS:
65-70
71-72
73-87
LOWERS:
65-70
71-87
Like your other thread,... what year spindles do you have?
(donor truck year?)
I'd like to help,... but we gotta have more info!
Keith
60-62
63-66
67-70
Old 04-17-2011, 11:34 AM   #15
clean68sbc
the donor truck was a 72 so im goin to have to get 72 upper and lower balljoints correct? and 72 tie rods correct? do i need outers and inners or wut?
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
