Old 10-12-2009, 07:38 PM   #1
Matt Man
Matt Man's Avatar
chevy c30 lift?
i know my signature says lowering my truck but im only considering that because i cant find any lift kits for it i dont want big but i would like the truck to sit like 2-3 in inches higher in the front without coil spacers. any ideas? i cant find anything.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 shorty 350/350C 12bolt, 10bolt, NP208
4" lift 33's
4.10's Detroit locker/Truetrac
Vintage Air
67 GMC Stepside Straight six/3 on the tree "The Peach"
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is online now   Reply With Quote
Old 10-12-2009, 08:07 PM   #2
royo
royo's Avatar
Re: Chevy c30 lift?
If its a smallblock put big block springs in it that will raise it up
nickle and dime
royo is offline   Reply With Quote
Old 10-12-2009, 09:40 PM   #3
Matt Man
Matt Man's Avatar
Re: chevy c30 lift?
no its a big block.
4" lift 33's
Vintage Air
Old 10-12-2009, 10:00 PM   #4
royo
royo's Avatar
Re: chevy c30 lift?
Ok then how about airbags?
nickle and dime
Old 10-12-2009, 10:11 PM   #5
skchevota
skchevota's Avatar
Re: chevy c30 lift?
big block springs, I think fab tec makes a lift spindle, or you can drop the front crossmember down from the frame. I have done this and it works very well. You use some 2"x3"x1/4' tubing as a spacer between the bottom of the frame and the top of the front x member, you will need longer bolts to hold it in place, then on the sides of the x member by the upper control arms, you can re drill the upper two holes. you will need to add a spacer to the bottom of the engine mount perches as well. For the steering, if you flip the centerlink around backward, it will make the tie rod angle livable. I did this on my truck befor I did the 4x4 swap.I had it this way for about 5 years. I ran that and a 3" block in the rear. I also had a body lift so my truck would clear 36" swampers. It drove great. The only thing I noticed was if I was at full lock turn in a parking lot, the inner tire to the turn would scrub more than stock, due to the differant angle on the steering. But it was no real big deal, I have driven factory built 4x4 IFS lifts with more scrub that it had. I would of kept it this way, But I rally wanted a 4x4.
skchevota is offline   Reply With Quote
Old 10-12-2009, 10:15 PM   #6
skchevota
skchevota's Avatar
Re: chevy c30 lift?
I just looked, yours is an 86. You can do as I stated, or fabtec makes a buch of stuff for thoes years. They even have long travel control arms.
Old 10-12-2009, 10:24 PM   #7
Matt Man
Matt Man's Avatar
Re: chevy c30 lift?
dude thank you so much i looked forever for something thanks!
4" lift 33's
Vintage Air
Old 10-15-2009, 11:11 PM   #8
shapinoweno
Re: chevy c30 lift?
so spindles for a 86 will fit the 67-72 trucks as well. also is there a difrence in the frontsuspension betweeen 1/2 3/4 and 1 ton 67-72 trucks? i have the fabtech long travel kit and im wondering if i can throw it on a 71 3/4 ton?
shapinoweno is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
